I am facing an issue when using the mcsqs code. I am trying to generate sqs supercell for modeling a random solution of vacancies in a sublattice of a hexagonal material. I first generated with Vesta a 4x4x1 supercell of the original unit cell. The final supercell has 192 atoms.
In the sublattice of interest (64 carbon atoms), nearest neighbour distance is 3.34 angstrom so that I am generating the clusters.out with corrdump as
corrdump -l=rndstr.in -ro -noe -nop -clus -2=6.68 -3=6.68
but when running
mcsqs -n=192
I get the message “Impossible to match point correlations due to incompatible supercell size.” As you can see from the rndstr.in file that I copy paste at the bottom (as a new user I cannot attach), I am trying to model a small concentration of vacancies, namely 0.046875, which should give 3 vacancies in the original 64-atoms sublattice of carbon atoms.
What am I missing? Thanks a lot for your help.
Cesare Roncaglia
rndstr.in file:
13.370212 13.370212 19.933262 90.000000 90.000000 120.000000
1 0 0
0 1 0
0 0 1
0.0000000000 0.0000000000 0.2500000000 Al
0.0000000000 0.2500000000 0.2500000000 Al
0.0000000000 0.5000000000 0.2500000000 Al
1.0000000000 0.7500000000 0.2500000000 Al
0.2500000000 0.0000000000 0.2500000000 Al
0.2500000000 0.2500000000 0.2500000000 Al
0.2500000000 0.5000000000 0.2500000000 Al
0.2500000000 0.7500000000 0.2500000000 Al
0.5000000000 0.0000000000 0.2500000000 Al
0.5000000000 0.2500000000 0.2500000000 Al
0.5000000000 0.5000000000 0.2500000000 Al
0.5000000000 0.7500000000 0.2500000000 Al
0.7500000000 0.0000000000 0.2500000000 Al
0.7500000000 0.2500000000 0.2500000000 Al
0.7500000000 0.5000000000 0.2500000000 Al
0.7500000000 0.7500000000 0.2500000000 Al
0.0000000000 0.0000000000 0.7500000000 Al
0.0000000000 0.2500000000 0.7500000000 Al
0.0000000000 0.5000000000 0.7500000000 Al
1.0000000000 0.7500000000 0.7500000000 Al
0.2500000000 0.0000000000 0.7500000000 Al
0.2500000000 0.2500000000 0.7500000000 Al
0.2500000000 0.5000000000 0.7500000000 Al
0.2500000000 0.7500000000 0.7500000000 Al
0.5000000000 0.0000000000 0.7500000000 Al
0.5000000000 0.2500000000 0.7500000000 Al
0.5000000000 0.5000000000 0.7500000000 Al
0.5000000000 0.7500000000 0.7500000000 Al
0.7500000000 0.0000000000 0.7500000000 Al
0.7500000000 0.2500000000 0.7500000000 Al
0.7500000000 0.5000000000 0.7500000000 Al
0.7500000000 0.7500000000 0.7500000000 Al
0.0833330000 0.1666680000 0.0710700000 C=0.953125, Vac=0.046875
0.0833330000 0.4166680000 0.0710700000 C=0.953125, Vac=0.046875
0.0833330000 0.6666680000 0.0710700000 C=0.953125, Vac=0.046875
0.0833330000 0.9166680000 0.0710700000 C=0.953125, Vac=0.046875
0.3333330000 0.1666680000 0.0710700000 C=0.953125, Vac=0.046875
0.3333330000 0.4166680000 0.0710700000 C=0.953125, Vac=0.046875
0.3333330000 0.6666680000 0.0710700000 C=0.953125, Vac=0.046875
0.3333330000 0.9166680000 0.0710700000 C=0.953125, Vac=0.046875
0.5833330000 0.1666680000 0.0710700000 C=0.953125, Vac=0.046875
0.5833330000 0.4166680000 0.0710700000 C=0.953125, Vac=0.046875
0.5833330000 0.6666680000 0.0710700000 C=0.953125, Vac=0.046875
0.5833330000 0.9166680000 0.0710700000 C=0.953125, Vac=0.046875
0.8333330000 0.1666680000 0.0710700000 C=0.953125, Vac=0.046875
0.8333330000 0.4166680000 0.0710700000 C=0.953125, Vac=0.046875
0.8333330000 0.6666680000 0.0710700000 C=0.953125, Vac=0.046875
0.8333330000 0.9166680000 0.0710700000 C=0.953125, Vac=0.046875
0.0833330000 0.1666680000 0.4289300000 C=0.953125, Vac=0.046875
0.0833330000 0.4166680000 0.4289300000 C=0.953125, Vac=0.046875
0.0833330000 0.6666680000 0.4289300000 C=0.953125, Vac=0.046875
0.0833330000 0.9166680000 0.4289300000 C=0.953125, Vac=0.046875
0.3333330000 0.1666680000 0.4289300000 C=0.953125, Vac=0.046875
0.3333330000 0.4166680000 0.4289300000 C=0.953125, Vac=0.046875
0.3333330000 0.6666680000 0.4289300000 C=0.953125, Vac=0.046875
0.3333330000 0.9166680000 0.4289300000 C=0.953125, Vac=0.046875
0.5833330000 0.1666680000 0.4289300000 C=0.953125, Vac=0.046875
0.5833330000 0.4166680000 0.4289300000 C=0.953125, Vac=0.046875
0.5833330000 0.6666680000 0.4289300000 C=0.953125, Vac=0.046875
0.5833330000 0.9166680000 0.4289300000 C=0.953125, Vac=0.046875
0.8333330000 0.1666680000 0.4289300000 C=0.953125, Vac=0.046875
0.8333330000 0.4166680000 0.4289300000 C=0.953125, Vac=0.046875
0.8333330000 0.6666680000 0.4289300000 C=0.953125, Vac=0.046875
0.8333330000 0.9166680000 0.4289300000 C=0.953125, Vac=0.046875
0.1666680000 0.0833330000 0.5710700000 C=0.953125, Vac=0.046875
0.1666680000 0.3333330000 0.5710700000 C=0.953125, Vac=0.046875
0.1666680000 0.5833330000 0.5710700000 C=0.953125, Vac=0.046875
0.1666680000 0.8333330000 0.5710700000 C=0.953125, Vac=0.046875
0.4166680000 0.0833330000 0.5710700000 C=0.953125, Vac=0.046875
0.4166680000 0.3333330000 0.5710700000 C=0.953125, Vac=0.046875
0.4166680000 0.5833330000 0.5710700000 C=0.953125, Vac=0.046875
0.4166680000 0.8333330000 0.5710700000 C=0.953125, Vac=0.046875
0.6666680000 0.0833330000 0.5710700000 C=0.953125, Vac=0.046875
0.6666680000 0.3333330000 0.5710700000 C=0.953125, Vac=0.046875
0.6666680000 0.5833330000 0.5710700000 C=0.953125, Vac=0.046875
0.6666680000 0.8333330000 0.5710700000 C=0.953125, Vac=0.046875
0.9166680000 0.0833330000 0.5710700000 C=0.953125, Vac=0.046875
0.9166680000 0.3333330000 0.5710700000 C=0.953125, Vac=0.046875
0.9166680000 0.5833330000 0.5710700000 C=0.953125, Vac=0.046875
0.9166680000 0.8333330000 0.5710700000 C=0.953125, Vac=0.046875
0.1666680000 0.0833330000 0.9289300000 C=0.953125, Vac=0.046875
0.1666680000 0.3333330000 0.9289300000 C=0.953125, Vac=0.046875
0.1666680000 0.5833330000 0.9289300000 C=0.953125, Vac=0.046875
0.1666680000 0.8333330000 0.9289300000 C=0.953125, Vac=0.046875
0.4166680000 0.0833330000 0.9289300000 C=0.953125, Vac=0.046875
0.4166680000 0.3333330000 0.9289300000 C=0.953125, Vac=0.046875
0.4166680000 0.5833330000 0.9289300000 C=0.953125, Vac=0.046875
0.4166680000 0.8333330000 0.9289300000 C=0.953125, Vac=0.046875
0.6666680000 0.0833330000 0.9289300000 C=0.953125, Vac=0.046875
0.6666680000 0.3333330000 0.9289300000 C=0.953125, Vac=0.046875
0.6666680000 0.5833330000 0.9289300000 C=0.953125, Vac=0.046875
0.6666680000 0.8333330000 0.9289300000 C=0.953125, Vac=0.046875
0.9166680000 0.0833330000 0.9289300000 C=0.953125, Vac=0.046875
0.9166680000 0.3333330000 0.9289300000 C=0.953125, Vac=0.046875
0.9166680000 0.5833330000 0.9289300000 C=0.953125, Vac=0.046875
0.9166680000 0.8333330000 0.9289300000 C=0.953125, Vac=0.046875
0.0000000000 0.0000000000 0.0000000000 Zr
0.0000000000 0.2500000000 0.0000000000 Zr
0.0000000000 0.5000000000 0.0000000000 Zr
1.0000000000 0.7500000000 0.0000000000 Zr
0.2500000000 0.0000000000 0.0000000000 Zr
0.2500000000 0.2500000000 0.0000000000 Zr
0.2500000000 0.5000000000 0.0000000000 Zr
0.2500000000 0.7500000000 0.0000000000 Zr
0.5000000000 0.0000000000 0.0000000000 Zr
0.5000000000 0.2500000000 0.0000000000 Zr
0.5000000000 0.5000000000 0.0000000000 Zr
0.5000000000 0.7500000000 0.0000000000 Zr
0.7500000000 0.0000000000 0.0000000000 Zr
0.7500000000 0.2500000000 0.0000000000 Zr
0.7500000000 0.5000000000 0.0000000000 Zr
0.7500000000 0.7500000000 0.0000000000 Zr
0.1666680000 0.0833330000 0.1309100000 Zr
0.1666680000 0.3333330000 0.1309100000 Zr
0.1666680000 0.5833330000 0.1309100000 Zr
0.1666680000 0.8333330000 0.1309100000 Zr
0.4166680000 0.0833330000 0.1309100000 Zr
0.4166680000 0.3333330000 0.1309100000 Zr
0.4166680000 0.5833330000 0.1309100000 Zr
0.4166680000 0.8333330000 0.1309100000 Zr
0.6666680000 0.0833330000 0.1309100000 Zr
0.6666680000 0.3333330000 0.1309100000 Zr
0.6666680000 0.5833330000 0.1309100000 Zr
0.6666680000 0.8333330000 0.1309100000 Zr
0.9166680000 0.0833330000 0.1309100000 Zr
0.9166680000 0.3333330000 0.1309100000 Zr
0.9166680000 0.5833330000 0.1309100000 Zr
0.9166680000 0.8333330000 0.1309100000 Zr
0.1666680000 0.0833330000 0.3690900000 Zr
0.1666680000 0.3333330000 0.3690900000 Zr
0.1666680000 0.5833330000 0.3690900000 Zr
0.1666680000 0.8333330000 0.3690900000 Zr
0.4166680000 0.0833330000 0.3690900000 Zr
0.4166680000 0.3333330000 0.3690900000 Zr
0.4166680000 0.5833330000 0.3690900000 Zr
0.4166680000 0.8333330000 0.3690900000 Zr
0.6666680000 0.0833330000 0.3690900000 Zr
0.6666680000 0.3333330000 0.3690900000 Zr
0.6666680000 0.5833330000 0.3690900000 Zr
0.6666680000 0.8333330000 0.3690900000 Zr
0.9166680000 0.0833330000 0.3690900000 Zr
0.9166680000 0.3333330000 0.3690900000 Zr
0.9166680000 0.5833330000 0.3690900000 Zr
0.9166680000 0.8333330000 0.3690900000 Zr
0.0000000000 0.0000000000 0.5000000000 Zr
0.0000000000 0.2500000000 0.5000000000 Zr
0.0000000000 0.5000000000 0.5000000000 Zr
1.0000000000 0.7500000000 0.5000000000 Zr
0.2500000000 0.0000000000 0.5000000000 Zr
0.2500000000 0.2500000000 0.5000000000 Zr
0.2500000000 0.5000000000 0.5000000000 Zr
0.2500000000 0.7500000000 0.5000000000 Zr
0.5000000000 0.0000000000 0.5000000000 Zr
0.5000000000 0.2500000000 0.5000000000 Zr
0.5000000000 0.5000000000 0.5000000000 Zr
0.5000000000 0.7500000000 0.5000000000 Zr
0.7500000000 0.0000000000 0.5000000000 Zr
0.7500000000 0.2500000000 0.5000000000 Zr
0.7500000000 0.5000000000 0.5000000000 Zr
0.7500000000 0.7500000000 0.5000000000 Zr
0.0833330000 0.1666680000 0.6309100000 Zr
0.0833330000 0.4166680000 0.6309100000 Zr
0.0833330000 0.6666680000 0.6309100000 Zr
0.0833330000 0.9166680000 0.6309100000 Zr
0.3333330000 0.1666680000 0.6309100000 Zr
0.3333330000 0.4166680000 0.6309100000 Zr
0.3333330000 0.6666680000 0.6309100000 Zr
0.3333330000 0.9166680000 0.6309100000 Zr
0.5833330000 0.1666680000 0.6309100000 Zr
0.5833330000 0.4166680000 0.6309100000 Zr
0.5833330000 0.6666680000 0.6309100000 Zr
0.5833330000 0.9166680000 0.6309100000 Zr
0.8333330000 0.1666680000 0.6309100000 Zr
0.8333330000 0.4166680000 0.6309100000 Zr
0.8333330000 0.6666680000 0.6309100000 Zr
0.8333330000 0.9166680000 0.6309100000 Zr
0.0833330000 0.1666680000 0.8690900000 Zr
0.0833330000 0.4166680000 0.8690900000 Zr
0.0833330000 0.6666680000 0.8690900000 Zr
0.0833330000 0.9166680000 0.8690900000 Zr
0.3333330000 0.1666680000 0.8690900000 Zr
0.3333330000 0.4166680000 0.8690900000 Zr
0.3333330000 0.6666680000 0.8690900000 Zr
0.3333330000 0.9166680000 0.8690900000 Zr
0.5833330000 0.1666680000 0.8690900000 Zr
0.5833330000 0.4166680000 0.8690900000 Zr
0.5833330000 0.6666680000 0.8690900000 Zr
0.5833330000 0.9166680000 0.8690900000 Zr
0.8333330000 0.1666680000 0.8690900000 Zr
0.8333330000 0.4166680000 0.8690900000 Zr
0.8333330000 0.6666680000 0.8690900000 Zr
0.8333330000 0.9166680000 0.8690900000 Zr
