I am interested in running diffusion simulations of molecules through porous frameworks by using smd/umbrella sampling. I have borrowed some impiration from the tutorial of Simon Gravelle on Free Energy calculations (Free energy calculation -) and also tried to use the fix smd in cfor mode with the keyword tether enabled. From my understanding the two fixes should do the same in the way I specified them but I get significantly different values when computing the PMF with the wham algorithm.
In the zipfile I have included the data files and the input and in each subfolder the results of the smd/spring forced diffusion. For simplicity a have applied the fix nvt only to the diffusing molecule.
smd_spring_issue_LAMMPS.zip (130.0 KB)
Judging from the results it seems that the fix smd gives the more realistic results since diffusion is experimentally observed and the values of the spring-simulation seem to be to large.
I am unsure if I am overlooking some differences how each fix works or if this is a bug. I am using the 29Aug2024 version for consistency reasons.
Maybe someone knows what is going on here?
Kind regards
Jakob
