apology for the confusion sir,radius of gyration actually include center of mass calculation,so it was there in my mind,however,let me share the full problem
1. Initialization
units lj
atom_style bond
2. Read data file (must define 8000 atoms, 7200 bonds, 0 angles)
read_data polymer.data
3. Nonbonded interactions: purely repulsive LJ (WCA)
pair_style lj/cut 2.5
pair_modify shift yes
type 1 is the only bead type
pair_coeff 1 1 1.0 1.0 2.5
4. Bonded: FENE bonds
bond_style fene
Kremer–Grest parameters: K=30, R0=1.5, epsilon=1, sigma=1
bond_coeff 1 30.0 1.5 1.0 1.0
special_bonds lj 0.0 1.0 1.0
5. Mass
mass 1 1.0
6. Neighbor settings
neighbor 0.3 bin
norm = normalize by # of atoms (yes or no)
thermo_style custom step pe ke etotal temp press density
report instantaneous thermo values every 100 steps
thermo 10
normalize thermo properties by number of atoms (yes or no)
thermo_modify norm yes
define time step
timestep 0.001
Energy minimization settings
min_style cg
min_modify dmax 0.1 # maximum allowed move distance per atom per minimization step
e_tol (energy tol), f_tol (force tol), maxiter, maxeval
minimize 1.0e-4 1.0e-6 10000 100000
After minimization, you may want to zero velocities (they are meaningless after minimization)
velocity all zero linear # remove any net momentum
velocity all zero angular # for molecular systems; optional if atom_style bond
velocity all create 4.0 12345 mom yes dist gaussian
#fix eq all nvt temp TEMPR TEMPR 0.1
run 1000 steps in the NVT ensemble
(this equilibrates thermostat)
run 10000
reset_timestep 0
restart 100 res/reseq
run 1000 more steps in the NVT ensemble
run 100000
#clean
unfix eq
here the script to equilibrate the system at the temp(lj),this create restart file every 100 step.
then i read the last restart file for the production run in following
define units
units lj
specify periodic boundary conditions
define atom_style
atom_style bond
specify interaction potential
pairwise interaction via the Lennard-Jones potential with a cut-off at 2.5 lj-sigma
specify parameters between atoms of type 1 with an atom of type 1
epsilon = 1.0, sigma = 1.0, cutoff = 2.5
#pair_coeff 1 1 1.0 1.0 2.5
add long-range tail correction
Read restart file
read_restart res/prr.838194
specify parameters for neighbor list
rnbr = rcut + 0.3
neighbor 0.3 bin
specify thermodynamic properties to be output
pe = potential energy
ke = kinetic energy
etotal = pe + ke
temp = temperature
press = pressure
density = number density
output every thousand steps
thermo 100
define time step
timestep 0.001
#reset time steps to zero
reset_timestep 0
dump 1 all custom 100 f.dat id type xu yu zu vx vy vz
#For writing restart files in every NRST steps
#In integral multiples of NRST restart file is written
restart 139600 res/prr
(this is data production, from which configurations are saved)
Every time system runs NRST step from the last configuration
run 1396000
#write_dump all custom final.dump id type xu yu zu
reading last restart file from the equilibration step produce the inconsistent image flage which might be creating issue in com calculation and hance in radius of gyration
