Incorrect args for pair coefficients
Dear Lammps user,
I stuck in the same problem again and again and can not understand what to be done. My system is ZnO, glucose and water. I have used CHARMM ff for glucose and water and reaxff for ZNO. I am getting the error in the 1st pair_coeff command.
The error is: ERROR: Incorrect args for pair coefficients (…/pair_lj_charmm_coul_charmm.cpp:246)
Last command: pair_coeff * * lj/charmm/coul/charmm 100.0 2.0 C C C C C C H H H H H H H H H H H H H H O O O O O O O NULL NULL
My input script is:
REAX potential for ZnOH2 system
units real
atom_style charge
read_data out-vmd-chrg.data
pair_style hybrid lj/charmm/coul/charmm 8.0 10.0 reax/c NULL lj/cut/coul/cut 10.0
pair_coeff * * lj/charmm/coul/charmm 100.0 2.0 C C C C C C H H &
pair_coeff * * reax/c ffield.reax.ZnOH O Zn
pair_coeff *18 19 lj/cut/coul/cut 1.0 1.0
pair_coeff *18 20 lj/cut/coul/cut 1.0 1.0
pair_coeff *18 21 lj/cut/coul/cut 1.0 1.0
pair_coeff *18 28 lj/cut/coul/cut 1.0 1.0
pair_coeff *18 29 lj/cut/coul/cut 1.0 1.0
neighbor 2 bin
neigh_modify every 2 delay 10 check yes page 100000
dump 1 all xyz 10 file2.xyz
dump_modify 1 element C C C C C C H H H H H H H H H H H H O O O O O O
minimize 1.0e-10 1.0e-10 10000 10000
and the masses are arranged in the following way in my data file:
Masses
1 12.011000 # C1 of glucose
2 12.011000 # C2 ‘’
3 12.011000 # C3 ‘’
4 12.011000 # C4 ‘’
5 12.011000 # C5 ‘’
6 12.011000 # C6 ‘’
7 1.008000 # H1 ‘’
8 1.008000 # H1o ‘’
9 1.008000 # H2 ‘’
10 1.008000 # H2o ‘’
11 1.008000 # H3 ‘’
12 1.008000 # H3o ‘’
13 1.008000 # H4 ‘’
14 1.008000 # H4o ‘’
15 1.008000 # H5 ‘’
16 1.008000 # H6R ‘’
17 1.008000 # H6S ‘’
18 1.008000 # H6o ‘’
19 1.008000 # HW1 of water
20 1.008000 # HW2 of water
21 15.999000 # O of water
22 15.999000 # O1h of glucose
23 15.999000 # O2h ‘’
24 15.999000 # O3h ‘’
25 15.999000 # O4h ‘’
26 15.999000 # O6h ‘’
27 15.999000 # OR ‘’
28 15.999000 # OW of ZNO
29 12.000000 # Zn of ZNO
With regards
Sasthi
Dear Lammps user,
because it is incorrect. there is nothing in the documentation, that describes this as a correct input. besides aren’t the CHARMM force field parameters already in the data file?
beyond that, it is a bad idea to mix ReaxFF with other force fields. the cross-interactions are going to be inconsistent and there is the problem, that you must not do charge equilibration on the charmmFF atoms, but excluding them makes the ReaxFF atoms “blind” for the charges from CHARMM, especially water. and doing the cross-interactions with lj/cut is even worse.
