I have built lammps with kim support.
However, I get an error saying,
ERROR: Incorrect args for pair coefficients (…/pair_kim.cpp:336)
Is there a way to fix it?
Swayam
Swayam
Can you send the input file you are working with? I'll take a look when I get a chance and see if I can spot anything.
Cheers,
Ryan Elliott
Hi Swayam,
If your script still looks like it did in your last post:
lmp.command("pair style kim KIMvirial model_Ar_P_Mors")
lmp.command("pair_coeff * * Ar Ar")
Then the problem is that your pair_coeff line should read as follows instead:
lmp.command("pair_coeff * * Ar")
Sorry we didn't catch this when answering your previous question. If you're now using multispecies potentials, please refer to the pair_coeff docs (http://lammps.sandia.gov/doc/pair_coeff.html) for the proper format.
Dan
Hi, thanks for your suggestion.
However, I still have the problem same problem.
My current script reads:
lmp.command(“pair_style kim KIMvirial model_Ar_P_Morse”)
lmp.command(“pair_coeff * * Ar”)
and, I still get the same error as,
Regards,
Swayam
Ah,
I see now, the Model name needs to be:
Hi Ryan,
thanks, however it still does not seem to work. Don’t you think, since the error is in pair_coeff, it could be in that line? My current script reads:
lmp.command(“pair_style kim KIMvirial ex_model_Ar_P_Morse”)
Regards,
Swayam
Hi Swayam,
As a first step, we should probably check that you’re able to successfully run the KIM example bundled with LAMMPS. My best guess is that either the example Model you’re using didn’t get compiled or wasn’t installed correctly. Did you do something like make examples
when you compiled and installed the KIM API?
Dan
