Can anybody give me a hint on how to fix the mistake?
it works for me with the current verison of LAMMPS (22 Apr 2016).
could it be that you are using an old version of LAMMPS (prior to about
mid-september 2015), but are consulting the online documentation (which
always describes the current version of LAMMPS)?
Thank you, this is the case. We have 3 Feb 2015 version. Although
pair_coeff 1 1 Be.eam.fs Be Be
looks now strange for myself. Should not it be
pair_coeff * * Be.eam.fs Be NULL
this is for you to say. the syntax is correct for both variants.
instead? And how do I check that the potentials have been assigned as
expected?
either you upgrade to the current version of LAMMPS or consult the manual
that was bundled with your version of LAMMPS.
