I am having some issues understanding why atoms around the edge of a periodic simulation box are not in BCC orientation when I orient outside the typical [100] orientations. I have done some reading on this and found that the box should be a multiple of the minimum periodic distance. Periodic distance is then calculated as (SQRT(h^2 + k^2 + l^2). For example the [1 1 0] orientation would be a min periodic distance of (sqrt(2). I tried testing this for the iron BCC structure below and noticed that the default LAMMPS spacing was unexpected for the z direction. As such I modified the lattice command with the spacing term as below. I think make a region that is 20 x 20 0 x 20 with lattice units. Spacing in this case is 4.964, 4.05314. 7.0204 and box size is 99.28, 81.1, 140.4 as expected. However I am still seeing a few atoms on the outer layer not being in the expected BCC orientation (97% BCC).
What am I missing?
------------------------ INITIALIZATION ----------------------------
atom_style atomic
atom_modify map hash
variable latparam equal 2.866
----------------------- ATOM DEFINITION ----------------------------
lattice bcc ${latparam} orient x 1 1 1 orient y 1 -1 0 orient z 1 1 -2 spacing 1.732051 1.414214 2.44949
region whole block 0 20 0 20 0 20
create_box 1 whole
create_atoms 1 region whole
mass 1 55.85
Liam
