Dear LAMMPS experts,
I’m using LAMPPS for the Gay-Berne uniaxial ellipsoidal particles to simulate Smectic-A liquid crystals. But I found that the density of the system cannot converge to the correct value even I manually set the degree of freedom of the particles.
The problem is that, the default degree of freedom (DOF) for Gay-Berne model in LAMMPS was set to be 6 (three translational and three rotational DOF). While I believe that the DOF for my uniaxial ellipsoidal particles should be 5.
Hence, when I use NpT/asphere ensemble to equilibrate the system without changing DOF, the average temperature calculated was six fifths of the value I set and, the pressure and density was also wrong because of that. The input file “Input_no_change_of_DOF” for this simulation is attached below.
However, when I manually set the DOF to be 5, I can get the correct temperature and pressure but the density I get is still the same wrong value as before. Hence I suspect that the system did not change the DOF in the integration loop but only change the DOF when calculating the output p and T. The input file “Input_DOF_changed” is also attached below. Currently I have no idea how to fix this thus I need a bit of help.
It is most appreciated if you could provide any suggestions or spot anything wrong in my input file.
Below are the two input files attached.
