I am trying to calculate dipole moment of TIP4P/2005 water molecule in a bulk systems using LAMMPS (16 Mar 2018). It is reported in the literature that the dipole moment of TIP4P/2005 water should be around 2.34 Debye at room temperature, whereas I am getting it around 3.2 Debye. I get the same dipole moment for an individual water molecule whether I run the simulation for single molecule or for a bulk system. I would like to know where am I making mistake in the input script? Could you please help me to sort this out? The following is my input script that I have used to calculate the dipole moment of single water molecule:
units real
kspace_style pppm/tip4p 1e-4
atom_style full
pair_style lj/cut/tip4p/long 1 2 1 1 0.1546 8.5 8.5
bond_style harmonic
angle_style harmonic
pair_modify tail yes
read_data one.data
pair_coeff 1 1 0.1852055 3.1589 #O-O
pair_coeff 1 2 0.00000 0.000 #O-H
pair_coeff 2 2 0.00000 0.00000 #H-H
bond_coeff 1 0.00 0.9572
angle_coeff 1 0.00 104.52
# create groups ###
group ox type 1
group hy type 2
group water type 1 2
set group ox charge -1.1128
set group hy charge 0.5564
velocity all create 298.0 4928459 rot yes dist gaussian
neighbor 3.0 bin
neigh_modify delay 1 every 1 check yes
timestep 1.0
fix constrain water shake 1.0e-3 2 0 b 1 a 1
fix corre water nvt temp 298.0 298.0 1.0
#dipole calculation
compute dip water chunk/atom molecule
compute myChunk water dipole/chunk dip
fix diplo water ave/time 1 1 1 c_myChunk[*] file dipole-bulk.out mode vector
dump trje all custom 1 watnvt.lammpstrj id type x y z vx vy vz
dump_modify trje sort id
run 10
