Dear Alex,
Thank you for your convenient code. It has helped me a lot. But when doing a POP calculation taking SOC effect into account, I got the following error: IndexError: arrays used as indices must be of integer (or boolean) type. If the SOC is not included, this error won’t appear and the calculation can proceed normally. I’m wondering if the error is due to improper configuration of my parameters.
input and log files are as follows:
setting.yaml:
# general settings
scattering_type: [POP]
doping: [1e18]
temperatures: [50, 100, 150, 200, 250, 300, 350, 400, 450, 500]
bandgap: 1.23
# electronic_structure settings
interpolation_factor: 50
# materials properties
static_dielectric:
- [16.653, -0.081, -1.159]
- [-0.081, 12.017, -0.332]
- [-1.215, -0.332, 10.388]
high_frequency_dielectric:
- [4.621, 0.001, 0.028]
- [0.001, 4.168, 0.001]
- [-0.028, 0.001, 4.109]
pop_frequency: 25.40
# performance settings
write_mesh: true
#energy_cutoff: 1.3
#nworkers: 4
amset.log:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ SCATTERING ~~~~~~~~~~~~~~~~~~~~~~~~~~~
Scattering mechanisms to be calculated: POP
Initializing POP scattering
- average N_po: 0.0276
- w_po: 159.6 2pi THz
- hbar.omega: 0.1050 eV
Forking 80 processes to calculate scattering
- time: 50.4155 s
Scattering information:
- # ir k-points: 18315
Calculating rates for spin-up band 1
- # k-points within Fermi-Dirac cut-offs: 0
- time: 0.0599 s
Calculating rates for spin-up band 2
- time: 0.0072 s
Calculating rates for spin-up band 3
- time: 0.0023 s
Calculating rates for spin-up band 4
- time: 0.0026 s
Calculating rates for spin-up band 5
- time: 0.0026 s
Calculating rates for spin-up band 6
- time: 0.0110 s
Calculating rates for spin-up band 7
- time: 0.0069 s
Calculating rates for spin-up band 8
- time: 0.0072 s
Calculating rates for spin-up band 9
- time: 0.0094 s
Calculating rates for spin-up band 10
- time: 0.0186 s
Calculating rates for spin-up band 11
- time: 0.0023 s
Calculating rates for spin-up band 12
- time: 0.0060 s
Calculating rates for spin-up band 13
- time: 0.0027 s
Calculating rates for spin-up band 14
- time: 0.0026 s
Calculating rates for spin-up band 15
- time: 0.0026 s
Calculating rates for spin-up band 16
- time: 0.0022 s
Calculating rates for spin-up band 17
- time: 0.0021 s
Calculating rates for spin-up band 18
- time: 0.0026 s
Calculating rates for spin-up band 19
- time: 0.0030 s
Calculating rates for spin-up band 20
- time: 0.0026 s
Calculating rates for spin-up band 21
- time: 0.0030 s
Calculating rates for spin-up band 22
- time: 0.0026 s
Calculating rates for spin-up band 23
- time: 0.0026 s
Calculating rates for spin-up band 24
- time: 0.0033 s
Calculating rates for spin-up band 25
- time: 0.0021 s
Calculating rates for spin-up band 26
- time: 0.0022 s
Calculating rates for spin-up band 27
- time: 0.0033 s
Calculating rates for spin-up band 28
- time: 0.0025 s
Calculating rates for spin-up band 29
- time: 0.0025 s
Calculating rates for spin-up band 30
- time: 0.0035 s
Calculating rates for spin-up band 31
- time: 0.0045 s
Calculating rates for spin-up band 32
- time: 0.0035 s
Calculating rates for spin-up band 33
- time: 0.0025 s
Calculating rates for spin-up band 34
- time: 0.0039 s
Calculating rates for spin-up band 35
- time: 0.0021 s
Calculating rates for spin-up band 36
- time: 0.0021 s
Calculating rates for spin-up band 37
- time: 0.0053 s
Calculating rates for spin-up band 38
- time: 0.0025 s
Calculating rates for spin-up band 39
- time: 0.0036 s
Calculating rates for spin-up band 40
- time: 0.0021 s
Calculating rates for spin-up band 41
- time: 0.0024 s
Calculating rates for spin-up band 42
- time: 0.0036 s
Calculating rates for spin-up band 43
- time: 0.0025 s
Calculating rates for spin-up band 44
- time: 0.0025 s
Calculating rates for spin-up band 45
- time: 0.0027 s
Calculating rates for spin-up band 46
- time: 0.0025 s
Calculating rates for spin-up band 47
- # k-points within Fermi-Dirac cut-offs: 17929
Scattering process ended with error:
File "/public/home/hpc222211023/.local/lib/python3.8/site-
packages/amset/scattering/calculate.py", line 579, in
scattering_worker
rate = calculate_rate(
packages/amset/scattering/calculate.py", line 681, in
calculate_rate
property_mask, band_kpoint_mask, band_mask, kpoint_mask =
tbs.get_masks(
packages/amset/electronic_structure/tetrahedron.py", line 849, in
get_masks
self.tetrahedra[spin][tetrahedra_mask],
type
exiting
ERROR: amset exiting on 16 Nov 2023 at 17:27
packages/amset/scattering/calculate.py", line 499, in
_get_rate_from_queue
result = self.out_queue.get(timeout=10)
File "/public/home/hpc222211023/.conda/envs/py38/lib/python3.8/mu
ltiprocessing/queues.py", line 108, in get
raise Empty
_queue.Empty
During handling of the above exception, another exception occurred:
raise Empty
_queue.Empty
raise Empty
_queue.Empty
raise Empty
_queue.Empty
raise Empty
_queue.Empty
File "/public/home/hpc222211023/.local/bin/amset", line 8, in
<module>
sys.exit(cli())
packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
packages/amset/tools/run.py", line 139, in run
runner.run()
packages/amset/core/run.py", line 65, in run
mem_usage, (amset_data, usage_stats) = memory_usage(
packages/memory_profiler.py", line 379, in memory_usage
returned = f(*args, **kw)
packages/amset/core/run.py", line 120, in _run_wrapper
amset_data, scattering_time = self._do_scattering(amset_data)
packages/amset/core/run.py", line 275, in _do_scattering
scatter.calculate_scattering_rates(), scatter.scatterer_labels
packages/amset/scattering/calculate.py", line 381, in
) = self.calculate_band_rates(spin, b_idx)
packages/amset/scattering/calculate.py", line 481, in
ir_idx, rate = self._get_rate_from_queue()
packages/amset/scattering/calculate.py", line 510, in
return self._get_rate_from_queue()
[Previous line repeated 2 more times]
packages/amset/scattering/calculate.py", line 519, in
raise result[0]
type
