I would like to run Indirect Umbrella Sampling (INDUS) in NPT simulation following the article of Patel Varilly Chandler and Garde (JStatPhys 2011). It is therefore necessary to include the forces coming from biaising potential to virial expression of internal pressure (Eq.17) in order to correctly simulate the NPT ensemble using Parrinello Rahman method.
In LAMMPS manual, for compute pressure command, it is written “If no extra keywords are listed, the entire equations above are calculated. This includes a kinetic energy (temperature) term and the virial as the sum of pair, bond, angle, dihedral, improper, kspace (long-range), and fix contributions to the force on each atom.” But I think that forces coming from an addforce fix are not accounted for in pressure computation, and that “fix” refers to SHAKE-like commands.
I have tested it on a simple example, of a single LJ atom in a cubic box, without any initial velocity. Compute pressure command prints a pressure equal to 0, even if I add a force through addforce fix. My version of LAMMPS has been downloaded the 22nd July 2016. Would you have any idea of how to implement this modification without rewriting the fix NPT command? In particular in the case of GPU package?
Thanks a lot,
Romain
Hereafter are my input and initial configuration files:
variable temperature equal 0.8
variable Ftype equal 1
variable Feps equal 1.0
variable Fsig equal 1.0
variable dumptime equal 1
variable thermotime equal 1
variable damp equal 100
processors * * *
units lj
atom_style full
bond_style harmonic
angle_style harmonic
pair_style lj/cut 4.0
read_data data.input.txt
neighbor 2.0 bin
pair_coeff {Ftype} {Ftype} {Feps} {Fsig}
pair_modify mix arithmetic
group fluid type ${Ftype}
neigh_modify delay 5
neigh_modify one 4000
fix 0 fluid addforce 1.0 1.0 1.0
fix 1 fluid nvt temp {temperature} {temperature} ${damp}
compute temp_pres fluid temp
compute Pres all pressure temp_pres
dump dmp all custom ${dumptime} dump1.lammpstrj id type x y z vx vy vz
dump_modify dmp flush yes sort id format “%d d .6f .6f .6f .6f .6f %.6f”
thermo ${thermotime}
thermo_style custom step temp epair c_Pres c_Pres[1] c_Pres[2] c_Pres[3]
thermo_modify flush yes
run 10
write_data data.end1.txt
And initial configuration:
1 atoms
1 atom types
0 10 xlo xhi
0 10 ylo yhi
0 10 zlo zhi
Masses
1 1.0
Atoms
1 1 1 0 1 1 1
