Hello all,
I created induced dipole style polarization pair style for lammps. Unfortunately it can only work in serial because of memory and cpu time constraints and also the virial/pressure is most likely off. I mainly use it for simulations with a couple thousand atoms and box lengths of ~25 angstroms and it works well enough for my purposes.
The code is here: http://code.google.com/p/lammps-induced-dipole-polarization-pair-style/
Building it works normally, you might want to use make serial though. Examples are in /polarization and I also put a thesis whose 8th chapter talks about some of the implementation details in there. You probably want a coulombic cutoff of around 12 angstroms so the static electric field is fairly accurate. The polarization routines are copied from MPMC (also on google code) btw.
Adam Hogan
Undergraduate Researcher
University of South Florida
