Initial model of particles of different sizes
Dear LAMMPS users,
I want to establish the initial model of particles with different sizes at a low solid volume fraction (say 0.15). Since the size of small particles is much smaller than large particles, in the initial model established by using “create_atoms”, there might be small particles located inside larger particles. Could you please tell me how to avoid this situation?
Thank you in advance.
Best wishes,
Ann
After creating large particles you can use create_atoms overlap to set the minimum distance between created particles and the new ones.
You can also use delete_atoms overlap to remove overlapping particles.
See the examples/srd/in.srd.mixture file in the LAMMPS source code for an example of how to use that.
It helps. Thank you so much!
OK. Thank you so much for your reply.
