Hello everyone,
I have a question regarding thermal conductivity measurement with rNEMD method, given in this link. I can see that here, fix thermal/conductivity
has been used twice with the same fix number. Apparently, the second time is to zero the energy accumulation. I am not sure why we have to use this command twice and with the same fix number. Basically, in my view is a waste of time. I have tried using this command only one time, but the thermal conductivity results seem to double in value, which is not correct. Also, I am not sure which result for these two runs is correct. I have to run this command for about 1000 ps to get the true values. So, basically, I am confused about which of these fix 3 commands should be run for this amount of time (1000 ps).
I will appreciate any help on this.
Thank you very much.
