Hi,everyone. The fix deposit command keyword region use a geometric shape. I want to insert atoms randomly at several fixed points. Is there any method I can use?
You can use the create_atoms command to place atoms at fixed points (for instance using a predefined lattice) with the subset keyword to only populate a fraction of these points. See create_atoms command — LAMMPS documentation
