Inserting molecules into a LAMMPS (output) data file with constraints?
Dear LAMMPS Users and Developers,
I have a LAMMPS input file that creates two copper slabs (below each other) and then minimize the structure by cg and after that I run an NVT simulation using Nosé-Hoover thermostat.
My goal is to insert oxygen molecules into this optimized structure in a specific way:
-oxygen molecules should be at least 3.5 Å from each other
-oxygen molecules should be at least 6 Å from copper atoms
I checked the molecule command but do not know how I could define the distances between the molecules-molecules (O2-O2) and molecules-atoms (Cu-O2).
I use ReaxFF.
Thank you for your help,
Patrik
PS. I could not attach my file so I copied the input:
LAMMPS Input Script for Two Flat Copper Slabs with ReaxFF Potential and Charge Equilibration
Set units and atom style
units real
atom_style charge
Define the simulation box
lattice fcc 3.615 orient x 1 -1 0 orient y 1 1 -2 orient z 1 1 1
region total_box block -161 161 -161 161 -40.5 40.5 units lattice
create_box 1 total_box
Create the first copper slab in the lower half of the box
region slab1 block -20 -8 -20 -8 -1.5 1.5 units lattice
create_atoms 1 region slab1
mass 1 63.546
Create the second copper slab in the upper half of the box
region slab2 block -20 -8 -20 -8 -6 -3 units lattice
create_atoms 1 region slab2
Define the reactive force field
pair_style reaxff lmp_control
pair_coeff * * ffield.reax.cuo Cu
Charge equilibration for ReaxFF
fix 2 all qeq/reax 1 0.0 10.0 1e-6 param.qeq
Minimize the structure using conjugate gradient method
min_style cg
minimize 1e-4 1e-6 1000 10000
Define the simulation settings
timestep 0.001
thermo 100
Apply Nosé-Hoover thermostat for NVT ensemble to equilibrate at 300K
fix 1 all nvt temp 300.0 300.0 50
Run the equilibration
run 10000
Output final configuration
write_data final_configuration_middle.data
You can try using the create_atoms command with:
  • a molecule template (to insert molecules)
  • the overlap keyword with a value of 3.5 A (to avoid overlap between atoms)
  • the region style (to place your molecule only in a region far from the walls)
edit: sorry I meant the random style with a region-ID, not the region style
On top of @simongravelle suggestions:
  • Define a region that is exactly 3.5 A above the Cu surface.
  • From the volume of the region to be filled with O2 molecules and the density you want to achieve, determine how many molecules to insert.
  • You can’t attach files, but you can read the forum guidelines. Please format your post accordingly.
Sorry, how should this command look like?
Can the oxygen be created by molecule command if I would like to apply charge atom_style?
I mean I get an error (" Invalid bond type in Bonds section of molecule file: 1 1 1 2 (src/molecule.cpp:1087) ") for the Bonds style for the following oxygen molecule:
#LAMMPS oxygen DATA file
2 atoms
1 bonds
0 angles
Coords
1 -1.49100 2.13600 0.01500  # ID Type Charge x y z
2 -0.29300 1.59000 0.01500  # ID Type Charge x y z
Types
1	1 #O
2	1 #O
Charges
1	-0.82000
2	-0.82000
Bonds
1 1 1 2
Angles
For ReaxFF you do not define bonds since ReaxFF computes them on the fly. So your molecule file also must not define a bond yet your header says there is one bond.
Thank you for your answer!
If I do not define Bonds then I have to load the parameters for oxygen in the line pair_coeff. When I try it, I get the error:
ERROR: Incorrect args for pair coefficients (src/REAXFF/pair_reaxff.cpp:280)
Last command: pair_coeff * * ffield.reax.cuo Cu O # placeholder, change with actual coefficients
I used the following settings:
pair_style reaxff lmp_control  # change as per your system
The force field file contains Cu and O exactly with these characters.
What did I do wrong?
It’s difficult to analyze errors from small pieces of code, but if I refer to your original post, it seems that you have only 1 atom type, but the way you write your pair_coeff suggests you have 2. Therefore, LAMMPS is complaining.
Note that this issue is unrelated to your original question, and therefore should not be part of the same post.
