Hi all,
I was trying to install Lammps in CentOs6.4. I have got this error,
mpirun -g -O -I/tmp/fftw-2.1.5/prefix/include -DFFT_FFTW -DOMPI_IGNORE_CXX_SEEK -DOMPI_SKIP_MPICXX -DFFT_FFTW -M …/angle_charmm.cpp > angle_charmm.d
mpirun -g -O -I/tmp/fftw-2.1.5/prefix/include -DFFT_FFTW -DOMPI_IGNORE_CXX_SEEK -DOMPI_SKIP_MPICXX -DFFT_FFTW -c …/angle_charmm.cpp
/usr/bin/mpdroot: open failed for root’s mpd conf filempiexec_batista (init 1208): forked process failed; status=255
make[1]: *** [angle_charmm.o] Error 255
make[1]: Leaving directory `/tmp/lammps-23Sep13/src/Obj_linux’
make: *** [linux] Error 2
[root@…4517… src]#
Is that may be a problem that I have not configure openmpi, it was automatically configured when another software was installed ? Although “mpirun” command is running in terminal.
I have tried to solve by creating mpd.conf at /etc/ and by writing the secrete word in that file. But in that case error is “did not find secrete word”
My make file is here :
CC = mpirun
CCFLAGS = -g -O -I/tmp/fftw-2.1.5/prefix/include -DFFT_FFTW -DOMPI_IGNORE_CXX_SEEK -DOMPI_SKIP_MPICXX
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = mpirun
LINKFLAGS = -O -L/usr/lib64/openmpi/lib -L/tmp/fftw-2.1.5/prefix/lib
LIB = -lpthread -lstdc++
SIZE = size
ARCHIVE = ar
ARFLAGS = -rc
SHLIBFLAGS = -shared
MPI_INC =
MPI_PATH =
MPI_LIB =
JPG_INC =
JPG_PATH =
JPG_LIB =
Please make comment.
Cheng
Hi all,
../angle_charmm.cpp > angle_charmm.d
../angle_charmm.cpp
/usr/bin/mpdroot: open failed for root's mpd conf filempiexec_batista
(__init__ 1208): forked process failed; status=255
make[1]: Leaving directory `/tmp/lammps-23Sep13/src/Obj_linux'
[[email protected]... src]#
AIIIIIHHHHH!!!! *never* compile software as root. *ever*! that is a
very, *very* bad idea. there is nothing in LAMMPS requires superuser
access.
no. the problem is that you are trying to use "mpirun" as a compiler.
"mpirun" command is running in terminal.
mpirun is used to run the resulting executable, not to compile.
secrete word in that file. But in that case error is "did not find secrete
word"
your problem is not a LAMMPS problem, but a mixture of an MPI problem
and not knowing what you are doing.
unless there is a special reason to compile LAMMPS for yourself, you
are likely better off to use the pre-compiled RPMS from here:
http://git.icms.temple.edu/rpm/
