Hello
I have used the following steps to build LAMMPS:
1.sudo apt-get update
2.sudo apt-get install build-essential
3.sudo apt-get install build essential mpich-bin libmpich1.0-dev mpi-doc fftw2 fftw-dev libxaw7-dev
and everything was fine up till here.
4. in the src directory I have type : make serial
and the trouble began.
Now the process hadn’t terminated for about more than an hour ( and thus I had close the terminal ) . It had started building LAMMPS (what I guess) but didn’t terminated and the same expression repeated after few cycles i.e.
make[1]:leaving directory '/home/internet/Desktop/lammps/src/obj_serial
make[1]:entering directory '/home/internet/Desktop/lammps/src/obj_serial
make[1]
File ‘write_restart.cpp’ has modification time 1.9e+08 s in the future
and some files “.cpp” were read and the same repeated and hadn’t halted.
Please give your suggestions to rectify this problem.
Hello
Now the process hadn't terminated for about more than an hour ( and thus I
didn't terminated and the same expression repeated after few cycles i.e.
make[1]
File 'write_restart.cpp' has modification time 1.9e+08 s in
the future
and some files ".cpp" were read and the same repeated and hadn't halted.
please consult a local linux expert. your machine setup is broken
and has a system time set to way back in the past.
this has *nothing* to do with lammps.
sorry, you should not try compiling a software on your own,
if you have no linux skills. there are tons of people around
that have them and for whom (because they are local) it is
*much* easier to help you than via a mailing list and from
halfway around the globe. this is just common sense.
