I am new to Open KIM and am trying to install the KIM-API to use KLIFF. I am trying to build from v2.2.1 from source, however I can’t seem to get it to work
Below are the steps I performed on my cluster
mkdir kim-api && cd kim-api
wget https://s3.openkim.org/kim-api/kim-api-2.2.1.txz
tar -Jxf kim-api-2.2.1.txz && cd kim-api-2.2.1
mkdir build && cd build
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=$PWD
make
make install
make test (all the tests pass!)
source bin/kim-api-activate
I cant do sudo ldconfig, in lieu of that I have a module file that appends the below variables
|prepend-path| PATH /home/kavalurav//kim-api/kim-api-2.2.1/build/utils |
|prepend-path| LD_LIBRARY_PATH /home/kavalurav//kim-api/kim-api-2.2.1/build:/home/kavalurav//kim-api/kim-api-2.2.1/build/lib64/:/home/kavalurav//kim-api/kim-api-2.2.1/build/libexec |
|prepend-path| LIBRARY_PATH /home/kavalurav//kim-api/kim-api-2.2.1/build:/home/kavalurav//kim-api/kim-api-2.2.1/build/lib64/:/home/kavalurav//kim-api/kim-api-2.2.1/build/libexec |
|prepend-path| PKG_CONFIG_PATH /home/kavalurav//kim-api/kim-api-2.2.1/build/pkg-config |
|prepend-path| CPLUS_INCLUDE_PATH /home/kavalurav//kim-api/kim-api-2.2.1/cpp/include|
However, when I try to run
kim-api-collections-management install user SW_StillingerWeber_1985_Si__MO_405512056662_006 I get errors about missing files, I am slowly working through them, so far I have done this from the build dir/install directory
cp cmake/CMakeFiles/Export/share/cmake/kim-api/kim-api-targets.cmake cmake
cp ../cmake/item-info.txt.in cmake
cp cmake/build-tree-package-config-files-items/item-wrapper.cpp.in cmake
However, now I am stuck on
[kavalurav@scfocus18 build]$ kim-api-collections-management install user SW_StillingerWeber_1985_Si__MO_405512056662_006
Downloading.............. SW_StillingerWeber_1985_Si__MO_405512056662_006
CMake Warning at /lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-pre-2.2-compatibility.cmake:51 (message):
Pre 2.2.0 KIM-API package behavior is deprecated and will be removed in
3.0.0. Please update your CMakeLists.txt file to use a find_package()
signature similar to one of the following:
find_package(KIM-API 2.2 REQUIRED CONFIG)
find_package(KIM-API-ITEMS 2.2 REQUIRED CONFIG)
See the examples in the KIM API source package for more details.
Call Stack (most recent call first):
/lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-config.cmake:52 (include)
CMakeLists.txt:37 (find_package)
-- The CXX compiler identification is GNU 8.2.0
-- The C compiler identification is GNU 8.2.0
-- The Fortran compiler identification is GNU 8.2.0
-- Check for working CXX compiler: /usr/nic/compiler/gcc/8.2/bin/c++
-- Check for working CXX compiler: /usr/nic/compiler/gcc/8.2/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/nic/compiler/gcc/8.2/bin/gcc
-- Check for working C compiler: /usr/nic/compiler/gcc/8.2/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working Fortran compiler: /usr/nic/compiler/gcc/8.2/bin/gfortran
-- Check for working Fortran compiler: /usr/nic/compiler/gcc/8.2/bin/gfortran -- works
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Checking whether /usr/nic/compiler/gcc/8.2/bin/gfortran supports Fortran 90
-- Checking whether /usr/nic/compiler/gcc/8.2/bin/gfortran supports Fortran 90 -- yes
-- Found xxd: (/bin/xxd)
CMake Error at /lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-items-macros.cmake:673 (message):
Unable to locate 'collections-info' utility
/lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-items-macros.cmake:814 (_determine_collection_install_prefix_and_output_name)
/lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-items-macros.cmake:114 (_add_kim_api_library)
/lstr/home/kavalurav/kim-api/kim-api-2.2.1/build/cmake/kim-api-pre-2.2-compatibility.cmake:82 (add_kim_api_model_library_pre22)
CMakeLists.txt:47 (add_kim_api_model_library)
-- Configuring incomplete, errors occurred!
See also "/tmp/kavalurav/kim-api-build-y2bNN94oSy/SW_StillingerWeber_1985_Si__MO_405512056662_006/build/CMakeFiles/CMakeOutput.log".
Aborting!
I am clearly missing some step, would appreciate any insight!
