Dear lammps users, I wanna install LAMMPS (stable release 2022) on Linux and install some packages like GPU and KSPACE. I have tried two different approaches.
In the traditional method, I ran these lines in terminal
make yes-GPU
I installed the packages that I wanted.
then I run, make mpi, but I get this error:
(base) system1@System1:~/Downloads/lmp 2022/lammps-stable(1)/lammps-23Jun2022/src$ make mpi
Gathering installed package information (may take a little while)
make[1]: Entering directory ‘/home/system1/Downloads/lmp 2022/lammps-stable(1)/lammps-23Jun2022/src’
make[1]: ‘lmpinstalledpkgs.h’ is up to date.
Gathering git version information
make[1]: Leaving directory ‘/home/system1/Downloads/lmp 2022/lammps-stable(1)/lammps-23Jun2022/src’
Compiling LAMMPS for machine mpi
make[1]: Entering directory ‘/home/system1/Downloads/lmp 2022/lammps-stable(1)/lammps-23Jun2022/src/Obj_mpi’
Makefile.package.settings:5: …/…/lib/electrode/Makefile.lammps: No such file or directory
Makefile.package.settings:6: …/…/lib/atc/Makefile.lammps: No such file or directory
Makefile.package.settings:9: …/…/lib/qmmm/Makefile.lammps: No such file or directory
Makefile.package.settings:11: …/…/lib/poems/Makefile.lammps: No such file or directory
Makefile.package.settings:12: …/…/lib/plumed/Makefile.lammps: No such file or directory
Makefile.package.settings:15: …/…/lib/mscg/Makefile.lammps: No such file or directory
/bin/sh: 1: Syntax error: “(” unexpected
…/…/lib/quip/Makefile.lammps:17: *** Environment or make variable QUIP_ROOT must be set… Stop.
make[1]: Leaving directory ‘/home/system1/Downloads/lmp 2022/lammps-stable(1)/lammps-23Jun2022/src/Obj_mpi’
Makefile:376: recipe for target ‘mpi’ failed.
when I try to install lammps with CMAKE, I get error too.
I wrote cmake-gui …/cmake
in the window, I selected the packages but in the log file I can see that a package can not be downloaded (the link that can not be downloaded is Downloading https://download.lammps.org/thirdparty/opencl-loader-2022.01.04.tar.gz)
error in configuration process, project files may be invalid
when I type cmake …/cmake
– The CXX compiler identification is GNU 7.5.0
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Running check for auto-generated files from make-based build system
– Found OpenMP_CXX: -fopenmp
– Found OpenMP: TRUE found components: CXX
– Found JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so
– Could NOT find FFMPEG (missing: FFMPEG_EXECUTABLE)
– Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.6m.so (found version “3.6.9”)
– Setting default Kokkos CXX standard to 14
CMake Error at /home/system1/Downloads/lmp2022/lammps-stable(1)/lammps-23Jun2022/lib/kokkos/CMakeLists.txt:75 (cmake_minimum_required):
CMake 3.16 or higher is required. You are running version 3.10.2
– Configuring incomplete, errors occurred!
See also “/home/system1/Downloads/lmp2022/lammps-stable(1)/lammps-23Jun2022/build/CMakeFiles/CMakeOutput.log”.
See also “/home/system1/Downloads/lmp2022/lammps-stable(1)/lammps-23Jun2022/build/CMakeFiles/CMakeError.log”.
I appreciate your help in advance
