I am trying to install the lammps atc package on a windows operating system using cygwin, but it doesn't work.
Has anyone done this, and could explain me how to do it?
Volker
P.S.
I have created the 'libatc.a'-file in the lammps/lib/atc directory by
using cygwin & the command 'make -f Makefile.g++'
I don't know what to change in the 'Makefile.lammps' file in the
lammps/lib/atc directory for 'user-atc_SYSPATH ='
I always get the error for the invalid fix style for 'fix ... atc ...' when running an example.
USER-ATC is included in the windows packages from here:
http://git.icms.temple.edu/rpm/windows.html
i don't know about cygwin. i use a mingw64 cross compiler on linux.
there are some tweaks to makefiles to accommodate this.
Volker
P.S.
running an example.
did you also install the USER-ATC package in the src directory?
