Dear lammps users
Can anybody please let me know which integrator schemes are used in NPT and NVT ensembles in lammps? I read the manual but could not get a clear cut idea.
thanks.
Rajesh Kumar
Dear lammps users
thanks.
Rajesh Kumar
Dear lammps users
idea.
read here: http://lammps.sandia.gov/doc/run_style.html
if that is not what you are looking for, perhaps you should describe
in more detail, what you are looking for.
Dear Axel,
Thanks for quick response. Actully, I want to know which integrator algorithms are used with fix NPT and fix NVT commands in lammps? I didnt get the meaning of line " The time integration schemes closely follow the time-reversible measure-preserving Verlet and rRESPA integrators derived by Tuckerman et al in (Tuckerman)." Is it verlet or rRESPA which one is used with fix npt and fix nvt commands?
Dear Axel,
either! fix npt and fix nvt are implemented to be compatible with both.
Dear Axel,
I simply used commands “fix 1 all npt temp 300 300 0.00799999 x 0 0 0.5 y 0 0 0.5”. Now how will I know which integrator lamps is going to use for this? Please explain.
Dear Axel,
I simply used commands "fix 1 all npt temp 300 300 0.00799999 x 0
0 0.5 y 0 0 0.5". Now how will I know which integrator lamps is going to
Dear Axel,
What I got after going through run_style is that unless we specify a particular run style, velocity-Verlet is the default integrator. Am I right?
Dear Axel,
i am not in the reassuring business (i would make a ton more money if i was).
do you have any particular reason to not believe the documentation?
