--- clusters ----
I know XSEDE's Stampede uses Intel Phi coprocessors.
Alas, no benchmarks yet.
http://lammps.sandia.gov/bench.html
Has anyone tried running LAMMPS with USER-INTEL or KOKKOS?
--- desktop machines ---
I have been asked for suggestions to by a new workstation and I am
generally curious whether or not it makes any sense to buy and set up
this kind of specialized hardware on a desktop?
To be slightly less vague: my own usage scenario would be a
(coarse-grained) system with 10^5-10^6 Lennard Jones particles
(without long-range electrostatics, but I imagine other users on the
mailing list might be curious about long-range electrostatics
performance as well). In our case, we probably want to keep the total
cost well below $8000.
Any suggestions would be welcome, even if they have nothing to do with
Intel Phi.
Thanks!
Andrew
--- clusters ----
oops. Vague. My apologies. I meant with Intel Phi coprocessors.
Thank you for your thorough answer.
Andrew
(Your workstation (i7+GTX980) is approximately what we can afford to
buy, so this information is perfect for me.)
Hi Andrew,
Most of the focus for the Intel package thus far has been for soft matter with long-range electrostatics, although this is changing... Here are a few benchmarks that include Stampede (which is nice for comparisons of GPU vs Xeon Phi in parallel):
https://sites.google.com/site/wmbrown85/brown_hpcuf_54.pdf
slides 17, 19, 23, and 24. The missing numbers on 24 (hw unavailable at time) are 2.84X and 9.29X respectively.
I typically only work with server/cluster/hpc parts - (that have ECC, higher core counts, etc).
If you want to send an input script to me directly, I can take a look and get back to you. For simulating with few atoms on many-core there might also be some options to improve overall throughput that I believe could work well with Phi.
Also if you want, I can add you to my announcement list for changes in the Intel package for LAMMPS (although it is probably just as easy to check bug fix page).
Best, - Mike
Dear Michael
Thank you for the link. This is helpful. I will forward this to
several people.
Andrew
