To find out the interaction energy (vdwl) in LAMMPS, I created a spherical nanoparticle and a water molecule. What I found out that this energy decreases with increase in distance of water molecule from the nanoparticle which is obvious. But when I am increasing the nanoparticle size the energy varies. I am doing this so that I can compare this Molecular mechanics energy with the obtained energy from quantum mechanics. I did this to avoid using the mixing rule for nanoparticle and water interaction.
Also, is it okay to use any mixing rule even though nanoparticle ( vashsihta potential)uses one potential and water (lj potential)uses some other potential?
Thank You!
you are not making *any* sense here.
other potential?
what kind of formula would you apply? how can you mix epsilon and
sigma of a lennard jones potential with a potential that doesn't use
those?
Dear Sir,
Thank you for the reply.
The question I asked meant that to define the pair coefficient between a nanoparticle and atoms of water, LB mixing rule was used in most of the papers i.e we have a copper nanoparticle with lj parameters and water with lj parameters. But to cross check that I have done quantum mechaincs energy calculation which should match the energy obtained from LAMMPS if the mixing rule approximation is correct. Thank you!
Dear Sir,
this is not a LAMMPS question, but a question about validity and
comparability of different methods. this is off-topic for this list
and besides, there is no way to answer this question at this general
level.
