Hello every lammpser
Recently I used the the lammps to simulate the deposition process of molecule GaAs on GaAs substrate.
I set the substrate GaAs(001) with the type 1 for Ga and type 2 for As.
For the deposited molecule, I make a dimer GaAs in .txt and use the molecule command.type 3 for Ga and type 4 for As.
The .txt for GaAs is:
#dimer molecule
2 atoms
1 bonds
Coords
1 0 0 0
2 1.69 0 0
Types
1 3
2 4
and the deposition command is
#--------- Define the deposited atoms----------------------------
group addatoms type 3 4
fix 4 addatoms nve
molecule dimer molecule.dimer
#--------- Deposite the atom the deposited atoms----------------------------
fix 5 addatoms deposit 3200 3 2500 12345 region slab near 0.1 mol dimer vz -0.5 -0.5
fix 6 addatoms wall/reflect zhi EDGE
But there are some errors :
Read molecule template dimer:
1 molecules
0 fragments
2 atoms with max type 2
1 bonds with max type 0
0 angles with max type 0
0 dihedrals with max type 0
0 impropers with max type 0
ERROR: Invalid atom type in fix deposit mol command (…/fix_deposit.cpp:118)
Last command: fix 5 addatoms deposit 3200 3 2500 12345 region slab near 0.1 mol dimer vz -0.5 -0.5
So I wanna know how to deal with this problem.
Thanks for your help
LI
