Hello!
I try to use forcefield by Susanna Monti et al in my research [1]. When I implement it in lammps, I have an error “prot_DNA_wat.reax:272: Invalid force field file format (src/REAXFF/reaxff_ffield.cpp:584)” in line 272 ( 64 ! Nr etc). I have no idea what’s the nature of this problem. I have 64 parameter-sets which correspond the headline and correspond columns count.
[1] Phys. Chem. Chem. Phys., 2013, 15, 15062 (Exploring the conformational and reactive dynamics of biomolecules in solution using an extended version of the glycine reactive force field - Physical Chemistry Chemical Physics (RSC Publishing))
I’m sorry, but as the new user I can’t upload files. I have to copy-paste file contents here:
Reactive MD-force field: prot_ff + GFA WGG WG Hobza_DB. March20 2012
39 ! Number of general parameters
50.0000 !Overcoordination parameter
9.5469 !Overcoordination parameter
1.6725 !Valency angle conjugation parameter
1.7224 !Triple bond stabilisation parameter
6.8702 !Triple bond stabilisation parameter
60.4850 !C2-correction
1.0588 !Undercoordination parameter
4.6000 !Triple bond stabilisation parameter
12.1176 !Undercoordination parameter
13.3056 !Undercoordination parameter
-40.0000 !Triple bond stabilization energy
0.0000 !Lower Taper-radius
10.0000 !Upper Taper-radius
2.8793 !Not used
33.8667 !Valency undercoordination
6.0891 !Valency angle/lone pair parameter
1.0563 !Valency angle
2.0384 !Valency angle parameter
6.1431 !Not used
6.9290 !Double bond/angle parameter
0.3989 !Double bond/angle parameter: overcoord
3.9954 !Double bond/angle parameter: overcoord
-2.4837 !Not used
5.7796 !Torsion/BO parameter
10.0000 !Torsion overcoordination
1.9487 !Torsion overcoordination
-1.2327 !Conjugation 0 (not used)
2.1645 !Conjugation
1.5591 !vdWaals shielding
0.1000 !Cutoff for bond order (*100)
1.7602 !Valency angle conjugation parameter
0.6991 !Overcoordination parameter
1.8512 !Valency/lone pair parameter
0.5000 !Not used
20.0000 !Not used
5.0000 !Molecular energy (not used)
0.0000 !Molecular energy (not used)
0.7903 !Valency angle conjugation parameter
11 ! Nr of atoms; cov.r; valency;a.m;Rvdw;Evdw;gammaEEM;cov.r2;#
alfa;gammavdW;valency;Eunder;Eover;chiEEM;etaEEM;n.u.
cov r3;Elp;Heat inc.;n.u.;n.u.;n.u.;n.u.
ov/un;val1;n.u.;val3,vval4
C 1.3817 4.0000 12.0000 1.8903 0.1838 0.6387 1.1341 4.0000
9.7559 2.1346 4.0000 34.9350 79.5548 4.9218 6.0000 0.0000
1.2114 0.0000 202.2908 8.9539 34.9289 13.5366 0.8563 0.0000
-2.8983 2.5000 1.0564 4.0000 2.9663 0.0000 0.0000 0.0000
H 0.8930 1.0000 1.0080 1.3550 0.0930 0.8203 -0.1000 1.0000
8.2230 33.2894 1.0000 0.0000 121.1250 3.7248 9.6093 1.0000
-0.1000 0.0000 55.1878 3.0408 2.4197 0.0003 1.0698 0.0000
-19.4571 4.2733 1.0338 1.0000 2.8793 0.0000 0.0000 0.0000
O 1.2450 2.0000 15.9990 2.3890 0.1000 1.0898 1.0548 6.0000
9.7300 13.8449 4.0000 37.5000 116.0768 8.5000 8.3122 2.0000
0.9049 0.4056 68.0152 3.5027 0.7640 0.0021 0.9745 0.0000
-3.5500 2.9000 1.0493 4.0000 2.9225 0.0000 0.0000 0.0000
N 1.2333 3.0000 14.0000 2.1294 0.1322 1.0000 1.1748 5.0000
10.0056 10.8657 4.0000 30.9146 100.0000 6.4603 7.0317 2.0000
1.0433 4.7941 119.9837 0.6005 7.9731 2.2800 0.9745 0.0000
-4.6366 4.0000 1.0183 4.0000 2.8793 0.0000 0.0000 0.0000
S 1.9673 2.0000 32.0600 2.1729 0.3000 1.0336 1.5359 6.0000
10.3008 4.9055 4.0000 52.9998 112.1416 6.5000 8.2545 2.0000
1.4601 9.7177 71.1843 5.7487 23.2859 12.7147 0.9745 0.0000
-11.0000 2.7466 1.0338 6.2998 2.8793 0.0000 0.0000 0.0000
Mg 1.8315 2.0000 24.3050 2.2464 0.1806 0.5020 1.0000 2.0000
10.9186 27.1205 3.0000 38.0000 0.0000 0.9499 5.6130 0.0000
-1.3000 0.0000 220.0000 49.9248 0.3370 0.0000 0.0000 0.0000
-1.0823 2.3663 1.0564 6.0000 2.9663 0.0000 0.0000 0.0000
P 1.5994 3.0000 30.9738 1.7000 0.1743 1.0000 1.3000 5.0000
9.1909 14.2932 5.0000 0.0000 0.0000 1.8292 7.2520 0.0000
-1.0000 10.2596 1.5000 0.2205 16.7429 15.9629 0.0000 0.0000
-2.5000 1.6114 1.0338 5.0000 2.8793 0.0000 0.0000 0.0000
Na 2.0300 1.0000 22.9898 2.3334 0.1481 0.8765 -1.0000 1.0000
11.0000 9.8000 1.0000 0.0000 0.0000 -3.8501 5.9459 0.0000
-1.0000 0.0000 67.5458 100.0000 10.0000 0.2500 0.8563 0.0000
-2.5766 2.5000 1.0338 6.0000 2.5791 0.0000 0.0000 0.0000
Cu 1.9202 2.0000 63.5460 1.9221 0.2826 1.0000 0.1000 1.0000
10.9889 100.0000 1.0000 0.0000 0.0000 2.7875 6.0000 0.0000
-1.0000 0.0000 80.7000 34.9555 0.4988 0.0000 0.8563 0.0000
-5.1872 3.1491 1.0000 4.0000 2.5791 0.0000 0.0000 0.0000
Cl 1.7140 1.0000 35.4500 1.9139 0.2000 0.3837 -1.0000 7.0000
11.5345 10.1330 1.0000 0.0000 0.0000 9.9614 6.5316 0.0000
-1.0000 3.5750 143.1770 6.2293 5.2294 0.1542 0.8563 0.0000
-10.2080 2.9867 1.0338 6.2998 2.5791 0.0000 0.0000 0.0000
X -0.0998 2.0000 1.0080 2.0000 0.0000 1.0000 -0.1000 6.0000
10.0000 2.5000 4.0000 0.0000 0.0000 8.5000 1.5000 0.0000
-0.1000 0.0000 -2.3700 8.7410 13.3640 0.6690 0.9745 0.0000
-11.0000 2.7466 1.0338 4.0000 2.8793 0.0000 0.0000 0.0000
43 ! Nr of bonds; Edis1;LPpen;n.u.;pbe1;pbo5;13corr;pbo6
pbe2;pbo3;pbo4;Etrip;pbo1;pbo2;ovcorr
1 1 158.2004 99.1897 78.0000 -0.7738 -0.4550 1.0000 37.6117 0.4147
0.4590 -0.1000 9.1628 1.0000 -0.0777 6.7268 1.0000 0.0000
1 2 169.4760 0.0000 0.0000 -0.6083 0.0000 1.0000 6.0000 0.7652
5.2290 1.0000 0.0000 1.0000 -0.0553 6.9316 0.0000 0.0000
2 2 153.3934 0.0000 0.0000 -0.4600 0.0000 1.0000 6.0000 0.7300
6.2500 1.0000 0.0000 1.0000 -0.0790 6.0552 0.0000 0.0000
1 3 115.3161 127.1562 61.7072 0.5141 -0.3474 1.0000 18.9948 0.9954
1.5618 -0.3414 8.9489 1.0000 -0.1628 5.6821 0.0000 0.0000
3 3 142.2858 145.0000 50.8293 0.2506 -0.1000 1.0000 29.7503 0.6051
0.3451 -0.1055 9.0000 1.0000 -0.1225 5.5000 1.0000 0.0000
1 4 164.1304 141.3380 102.0464 -1.8021 -0.5696 1.0000 27.6095 0.2487
0.3953 -0.3663 7.1330 1.0000 -0.2557 4.6940 1.0000 0.0000
3 4 128.8596 167.8643 40.0000 0.3819 -0.1539 1.0000 34.9972 0.1900
1.0110 -0.3716 7.0805 1.0000 -0.1265 6.8843 1.0000 0.0000
4 4 160.1592 82.5526 153.9884 0.4110 -0.0934 1.0000 12.4304 0.5899
0.1538 -0.1473 11.9187 1.0000 -0.0753 5.4371 1.0000 0.0000
2 3 160.0000 0.0000 0.0000 -0.5725 0.0000 1.0000 6.0000 0.5626
1.1150 1.0000 0.0000 0.0000 -0.0920 4.2790 0.0000 0.0000
2 4 211.6032 0.0000 0.0000 -0.3415 0.0000 1.0000 6.0000 0.4726
2.7198 1.0000 0.0000 1.0000 -0.1744 5.6399 0.0000 0.0000
1 5 150.8132 59.3363 55.2528 -0.0628 -0.5211 1.0000 18.9617 0.3219
0.3317 -0.2289 7.5946 1.0000 -0.1946 5.9455 1.0000 0.0000
2 5 143.4377 0.0000 0.0000 -0.2944 0.0000 1.0000 6.0000 0.6034
9.5627 1.0000 0.0000 1.0000 -0.0516 7.0960 1.0000 0.0000
3 5 0.0000 0.0000 0.0000 0.5563 -0.4038 1.0000 49.5611 0.6000
0.4259 -0.4577 12.7569 1.0000 -0.1100 7.1145 1.0000 0.0000
4 5 0.0000 0.0000 0.0000 0.4438 -0.2034 1.0000 40.3399 0.6000
0.3296 -0.3153 9.1227 1.0000 -0.1805 5.6864 1.0000 0.0000
5 5 140.8296 84.9350 68.6860 -0.4111 -0.4781 1.0000 17.8574 -0.1336
0.2881 -0.2494 9.8436 1.0000 -0.1806 7.4732 1.0000 0.0000
2 6 58.6896 0.0 0.0000 -0.0203 -0.1418 1.0000 13.1260 0.0230
8.2136 -0.1310 0.0000 1.0000 -0.2692 6.4254 0.0000 24.4461
3 6 87.0227 0.0000 43.3991 0.0030 -0.3000 1.0000 36.0000 0.0250
0.0087 -0.2500 12.0000 1.0000 -0.0439 6.6073 1.0000 24.4461
6 6 32.3808 0.0000 0.0000 -0.0076 -0.2000 0.0000 16.0000 0.2641
4.8726 -0.2000 10.0000 1.0000 -0.0729 4.6319 0.0000 0.0000
1 7 110.0000 92.0000 0.0000 0.2171 -0.1418 1.0000 13.1260 0.6000
0.3601 -0.1310 10.7257 1.0000 -0.0869 5.3302 1.0000 0.0000
2 7 0.1466 0.0000 0.0000 0.2250 -0.1418 1.0000 13.1260 0.6000
0.3912 -0.1310 0.0000 1.0000 -0.1029 9.3302 0.0000 0.0000
3 7 202.5868 164.1808 0.0000 0.5506 -0.5000 1.0000 25.0000 0.4300
0.0912 -0.1285 16.0342 1.0000 -0.2008 6.2678 1.0000 0.0000
4 7 130.0000 0.0000 0.0000 0.2171 -0.1418 1.0000 13.1260 0.6000
6 7 0.1000 0.0000 0.0000 0.2500 -0.5000 1.0000 35.0000 0.6000
0.5000 -0.5000 20.0000 1.0000 -0.2000 10.0000 1.0000 0.0000
7 7 0.0000 0.0000 0.0000 0.2171 -0.5000 1.0000 35.0000 0.6000
2 8 0.0000 0.0000 0.0000 -1.0000 -0.3000 1.0000 36.0000 0.7000
10.1151 -0.3500 25.0000 1.0000 -0.1053 8.2003 1.0000 0.0000
3 8 76.0753 0.0000 0.0000 -0.4452 -0.3000 1.0000 36.0000 0.6433
5.6834 -0.3500 25.0000 1.0000 -0.0539 8.0273 1.0000 0.0000
4 8 0.0000 0.0000 0.0000 -1.0000 -0.3000 1.0000 36.0000 0.7000
6 8 0.1000 0.0000 0.0000 0.2500 -0.5000 1.0000 35.0000 0.6000
7 8 0.1000 0.0000 0.0000 0.2500 -0.5000 1.0000 35.0000 0.6000
8 8 27.8052 0.0000 0.0000 0.4022 0.3000 0.0000 25.0000 0.4894
0.6222 -0.4000 12.0000 1.0000 -0.0500 5.3362 0.0000 0.0000
4 6 0.0000 0.0000 0.0000 -1.0000 -0.3000 1.0000 36.0000 0.7000
1 9 0.0000 0.0000 0.0000 0.2000 -0.1418 1.0000 13.1260 0.5000
0.5000 -0.2000 20.0000 1.0000 -0.1000 9.0000 0.0000 0.0000
2 9 0.0000 0.0000 0.0000 0.2000 -0.1418 1.0000 13.1260 0.5000
3 9 81.4346 0.0000 0.0000 -0.1594 -0.3000 1.0000 36.0000 0.0025
0.2904 -0.2500 12.0000 1.0000 -0.0742 9.3638 0.0000 0.0000
4 9 96.5322 0.0000 0.0000 0.9970 -0.3000 1.0000 36.0000 0.5095
0.7247 -0.2500 12.0000 1.0000 -0.1175 9.9985 0.0000 0.0000
9 9 73.6263 0.0000 0.0000 0.0209 -0.2000 0.0000 16.0000 0.3414
0.4703 -0.2000 15.0000 1.0000 -0.1319 5.9254 0.0000 0.0000
2 10 109.1686 0.0000 0.0000 -0.1657 -0.2000 0.0000 16.0000 1.2500
2.8463 -0.2000 15.0000 1.0000 -0.1111 5.2687 0.0000 0.0000
3 10 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
1.0001 -0.2000 15.0000 1.0000 -0.1000 10.0000 0.0000 0.0000
9 10 118.3052 0.0000 0.0000 -0.1168 -0.2000 0.0000 16.0000 0.0697
2.9176 -0.2000 15.0000 1.0000 -0.1316 5.3624 0.0000 0.0000
10 10 0.2500 0.0000 0.0000 0.1803 -0.2000 0.0000 16.0000 0.3356
0.9228 -0.2000 15.0000 1.0000 -0.1178 5.6715 0.0000 0.0000
1 8 0.0000 0.0000 0.0000 -1.0000 -0.3000 1.0000 36.0000 0.7000
1 10 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
4 10 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
22 ! Nr of off-diagonal terms; Ediss;Ro;gamma;rsigma;rpi;rpi2
1 2 0.1239 1.4004 9.8467 1.1210 -1.0000 -1.0000
2 3 0.0283 1.2885 10.9190 0.9215 -1.0000 -1.0000
2 4 0.1664 1.3100 9.6406 1.0569 -1.0000 -1.0000
1 3 0.0503 1.8006 10.2114 1.3492 1.1992 1.0506
1 4 0.1771 1.8995 9.6891 1.3428 1.2492 1.1154
3 4 0.2000 1.8388 9.5137 1.4587 1.0933 1.1826
1 5 0.1618 1.7943 10.1042 1.7489 1.3150 1.4031
2 5 0.0764 1.5838 10.1462 1.4206 -1.0000 -1.0000
3 5 0.1022 1.9887 10.0605 1.5799 1.4000 -1.0000
4 5 0.1505 1.9000 10.5104 1.8000 1.4000 -1.0000
2 6 0.0100 1.6000 13.2979 1.8670 -1.0000 -1.0000
3 6 0.0809 1.7000 11.4606 1.5177 -1.0000 -1.0000
3 7 0.0611 1.7624 10.2685 1.7989 1.4523 -1.0000
6 7 0.1801 1.8566 9.8498 0.1000 -1.0000 -1.0000
3 8 0.1592 1.8283 11.7256 1.6655 -1.0000 -1.0000
1 9 0.0500 1.7500 12.3500 0.1000 -1.0000 -1.0000
2 9 0.0300 1.5200 12.5000 0.1000 -1.0000 -1.0000
3 9 0.0348 1.7637 12.3562 1.7228 -1.0000 -1.0000
4 9 0.0478 1.7704 12.8051 1.6100 -1.0000 -1.0000
2 10 0.0568 1.6740 9.6297 1.2200 -1.0000 -1.0000
3 10 0.1927 2.2551 11.2308 -1.0000 -1.0000 -1.0000
9 10 0.1402 2.1604 10.9786 1.7505 -1.0000 -1.0000
104 ! Nr of angles;at1;at2;at3;Thetao,o;ka;kb;pv1;pv2
1 1 1 59.0573 30.7029 0.7606 0.0000 0.7180 6.2933 1.1244
1 1 2 65.7758 14.5234 6.2481 0.0000 0.5665 0.0000 1.6255
2 1 2 70.2607 25.2202 3.7312 0.0000 0.0050 0.0000 2.7500
1 2 2 0.0000 0.0000 6.0000 0.0000 0.0000 0.0000 1.0400
1 2 1 0.0000 3.4110 7.7350 0.0000 0.0000 0.0000 1.0400
2 2 2 0.0000 27.9213 5.8635 0.0000 0.0000 0.0000 1.0400
1 1 3 54.7427 21.1992 1.0613 0.0000 2.9950 58.6562 1.1232
3 1 3 78.6632 16.3065 6.3613 -19.9300 1.5183 0.0000 2.2234
1 1 4 78.9895 29.7448 1.4146 0.0000 1.1834 0.0000 2.4298
3 1 4 74.5431 30.9283 1.2618 0.0000 1.1019 0.0000 1.0888
4 1 4 90.0000 15.9388 0.5081 0.0000 1.1155 0.0000 2.5891
2 1 3 50.0000 12.9103 2.5311 0.0000 0.1000 0.0000 1.0000
2 1 4 73.8008 28.9565 1.9450 0.0000 0.2000 0.0000 2.9066
1 2 4 0.0000 0.0019 6.3000 0.0000 0.0000 0.0000 1.0400
1 3 1 71.6401 45.0000 1.2667 0.0000 2.8294 0.0000 1.0000
1 3 3 76.3686 44.8665 1.9461 0.0000 1.0572 68.1072 1.8676
1 3 4 70.4701 35.0124 2.2286 0.0000 2.9000 0.0000 2.4754
3 3 3 89.9293 15.8855 2.0229 0.0000 2.9881 0.0000 1.0237
3 3 4 84.0202 31.3592 1.0534 0.0000 2.9000 0.0000 1.4406
4 3 4 72.3904 15.0722 5.0227 0.0000 3.0072 0.0000 1.0000
1 3 2 90.0000 6.6459 5.2255 0.0000 1.3111 0.0000 3.0000
2 3 3 75.6935 50.0000 2.0000 0.0000 1.0000 0.0000 1.1680
2 3 4 68.4187 33.4407 7.5000 0.0000 0.1000 0.0000 1.0000
2 3 2 85.8000 9.8453 2.2720 0.0000 2.8635 0.0000 1.5800
1 4 1 81.2266 17.5379 1.2324 0.0000 2.8702 0.0000 1.0000
1 4 3 73.8735 39.1639 1.0445 0.0000 2.8701 0.0000 1.7008
1 4 4 71.3629 18.4874 2.3468 0.0000 2.8701 0.0000 1.8255
3 4 3 74.9086 21.9109 2.5904 -18.0069 3.0701 0.0000 1.0000
3 4 4 77.8757 28.9944 1.2740 -0.9193 3.0117 0.0000 1.0000
4 4 4 76.1795 29.2290 1.6529 0.0000 2.9983 0.0000 2.4525
1 4 2 69.0828 11.0941 2.4635 0.0000 0.2025 0.0000 2.3768
2 4 3 77.7697 23.7768 2.7987 0.0000 0.3956 0.0000 3.0000
2 4 4 74.3012 42.0419 1.2591 0.0000 0.5437 0.0000 1.1369
2 4 2 84.3282 13.8208 4.6573 0.0000 0.1000 0.0000 1.0000
1 2 3 0.0000 16.7302 1.1143 0.0000 0.0000 0.0000 1.0000
1 2 4 0.0000 14.7285 3.8173 0.0000 0.0000 0.0000 2.1043
1 2 5 0.0000 15.0000 3.0000 0.0000 0.0000 0.0000 1.0400
3 2 3 0.0000 15.0000 2.8900 0.0000 0.0000 0.0000 2.8774
3 2 4 0.0000 1.4986 0.1000 0.0000 0.0000 0.0000 3.0000
4 2 4 0.0000 2.4033 0.1000 0.0000 0.0000 0.0000 1.8653
2 2 3 0.0000 8.5744 3.0000 0.0000 0.0000 0.0000 1.0421
2 7 3 75.0000 25.0000 2.0000 0.0000 1.0000 0.0000 1.2500
3 7 7 70.0000 25.0000 2.0000 0.0000 1.0000 0.0000 1.2500
3 9 3 96.2265 4.5610 12.0000 0.0000 0.3211 0.0000 1.5204
3 9 3 0.0000 9.1552 7.9919 0.0000 0.1660 0.0000 1.5386
9 3 9 100.0000 10.1065 6.0000 0.0000 1.0000 0.0000 3.6601
2 3 9 55.0417 3.5032 3.9979 0.0000 1.5171 0.0000 1.0400
3 3 9 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
3 9 9 66.7783 14.3146 0.7911 0.0000 1.0000 0.0000 1.2333
3 9 10 96.6924 9.4823 5.7883 0.0000 0.2248 0.0000 2.2640
3 9 10 0.0000 3.8549 3.7230 0.0000 0.1482 0.0000 1.0400
9 10 9 0.0000 11.2336 6.8851 0.0000 1.0000 0.0000 1.0893
9 9 10 90.0000 5.0811 5.2147 0.0000 1.0000 0.0000 1.8538
10 9 10 0.0100 21.1482 0.3506 0.0000 1.0000 0.0000 1.4361
3 2 10 0.0000 0.0100 0.5211 0.0000 0.0000 0.0000 1.3859
3 9 4 100.0000 28.1532 12.0000 0.0000 0.2932 0.0000 1.6489
3 9 4 0.0000 22.7457 2.9039 0.0000 0.5593 0.0000 1.9764
4 9 4 87.0081 27.6432 3.9735 0.0000 4.0000 0.0000 1.4578
4 9 4 0.0000 22.8998 3.1077 0.0000 3.0000 0.0000 1.0696
9 4 9 100.0000 10.1065 6.0000 0.0000 1.0000 0.0000 3.6601
2 4 9 80.0000 3.5601 3.3645 0.0000 1.5171 0.0000 1.0400
3 4 9 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
4 3 9 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
4 4 9 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
4 9 9 66.7783 14.3146 0.7911 0.0000 1.0000 0.0000 1.2333
4 9 10 95.2122 5.7090 12.0000 0.0000 0.2248 0.0000 2.8936
4 9 10 0.0000 9.0054 7.9511 0.0000 0.1482 0.0000 1.6245
4 2 10 0.0000 15.0000 2.8900 0.0000 0.0000 0.0000 2.8774
1 3 9 55.0000 15.0000 1.0000 0.0000 1.0000 0.0000 1.5000
1 4 9 55.0000 15.0000 1.0000 0.0000 1.0000 0.0000 1.5000
64 ! Nr of torsions;at1;at2;at3;at4;;V1;V2;V3;V2(BO);vconj;n.u;n
1 1 1 1 -0.2500 34.7453 0.0288 -6.3507 -1.6000 0.0000 0.0000
1 1 1 2 -0.2500 29.2131 0.2945 -4.9581 -2.1802 0.0000 0.0000
2 1 1 2 -0.2500 31.2081 0.4539 -4.8923 -2.2677 0.0000 0.0000
1 1 1 3 -2.5000 25.4016 1.0000 -4.4850 -1.1000 0.0000 0.0000
2 1 1 3 -0.9763 59.4161 1.0000 -7.7414 -1.0978 0.0000 0.0000
3 1 1 3 -2.5000 52.7614 -1.0000 -4.0134 -0.8614 0.0000 0.0000
1 1 3 1 -1.9125 80.0000 -1.0000 -4.5626 -0.9000 0.0000 0.0000
1 1 3 2 0.6154 8.3019 -0.4870 -2.9336 -0.9000 0.0000 0.0000
2 1 3 1 -2.5000 80.0000 0.9658 -4.4935 -0.9000 0.0000 0.0000
2 1 3 2 -1.0000 31.8695 1.0000 -2.6151 -1.1000 0.0000 0.0000
1 1 3 3 0.7514 34.1941 0.5669 -5.5360 -2.0544 0.0000 0.0000
2 1 3 3 2.5000 80.0000 1.0000 -2.6841 -2.8274 0.0000 0.0000
3 1 3 1 0.2515 79.1495 -0.6263 -4.3647 -3.0437 0.0000 0.0000
3 1 3 2 1.0000 37.1243 1.0000 -2.5000 -3.0476 0.0000 0.0000
3 1 3 3 -1.0092 41.0504 0.3915 -6.0913 -2.7174 0.0000 0.0000
1 3 3 1 -1.6378 -11.8357 0.3815 -3.2104 -2.7536 0.0000 0.0000
1 3 3 2 -2.5000 -9.2805 0.3063 -5.9187 -2.9498 0.0000 0.0000
2 3 3 2 0.2732 -21.6925 -1.0000 -2.5000 -0.9921 0.0000 0.0000
1 3 3 3 2.5000 -17.6041 1.0000 -2.5000 -0.9972 0.0000 0.0000
2 3 3 3 -2.5000 78.0855 -0.8750 -7.8902 -1.2407 0.0000 0.0000
3 3 3 3 -2.5000 -25.0000 1.0000 -2.5000 -0.9000 0.0000 0.0000
1 1 4 2 1.4427 31.7903 0.2054 -8.0000 -1.9825 0.0000 0.0000
2 1 4 2 -1.0000 64.2008 0.3037 -7.5233 -2.1051 0.0000 0.0000
3 1 4 2 1.0000 29.1410 1.0000 -3.2244 -2.5261 0.0000 0.0000
3 1 1 4 -1.0000 65.1457 0.2433 -4.9542 -0.9511 0.0000 0.0000
4 1 1 4 1.0000 87.8413 0.3817 -3.7479 -1.7241 0.0000 0.0000
1 1 4 1 1.0000 12.2873 0.7438 -3.5510 -1.6589 0.0000 0.0000
3 1 4 1 -1.0000 -0.2183 1.0000 -3.5014 -1.8038 0.0000 0.0000
2 1 1 4 1.0000 23.7736 0.4235 -2.7665 -1.9000 0.0000 0.0000
4 1 4 2 1.0000 96.1436 1.0000 -6.9528 -2.0202 0.0000 0.0000
2 1 4 1 -1.0000 88.5527 -0.3433 -7.9806 -1.5996 0.0000 0.0000
0 1 2 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0 2 2 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0 2 3 0 0.0000 0.1000 0.0200 -2.5415 0.0000 0.0000 0.0000
0 1 1 0 0.0000 50.0000 0.3000 -4.0000 -2.0000 0.0000 0.0000
0 3 3 0 0.5511 25.4150 1.1330 -5.1903 -1.0000 0.0000 0.0000
0 1 4 0 0.2176 40.4126 0.3535 -3.9875 -2.0051 0.0000 0.0000
0 2 4 0 0.0000 0.1032 0.3000 -5.0965 0.0000 0.0000 0.0000
0 3 4 0 1.1397 61.3225 0.5139 -3.8507 -2.7831 0.0000 0.0000
0 4 4 0 0.7265 44.3155 1.0000 -4.4046 -2.0000 0.0000 0.0000
4 1 4 4 -0.0949 8.7582 0.3310 -7.9430 -2.0000 0.0000 0.0000
0 1 5 0 0.8251 92.1468 0.7176 -4.2341 0.0000 0.0000 0.0000
0 5 5 0 0.1291 -5.0000 0.9649 -5.0903 0.0000 0.0000 0.0000
0 2 5 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0 6 6 0 0.0000 0.0000 0.1200 -2.4426 0.0000 0.0000 0.0000
0 2 6 0 0.0000 0.0000 0.1200 -2.4847 0.0000 0.0000 0.0000
0 3 6 0 0.0000 0.0000 0.1200 -2.4703 0.0000 0.0000 0.0000
1 1 3 3 -0.0002 20.1851 0.1601 -9.0000 -2.0000 0.0000 0.0000
1 3 3 1 0.0002 80.0000 -1.5000 -4.4848 -2.0000 0.0000 0.0000
3 1 3 3 -0.1583 20.0000 1.5000 -9.0000 -2.0000 0.0000 0.0000
1 1 1 7 0.0000 19.3871 0.0103 -25.5765 -1.7255 0.0000 0.0000
7 1 1 7 0.0000 80.5586 0.1104 -8.0928 -1.7255 0.0000 0.0000
0 1 7 0 4.0000 45.8264 0.9000 -4.0000 0.0000 0.0000 0.0000
0 7 7 0 4.0000 45.8264 0.9000 -4.0000 0.0000 0.0000 0.0000
2 1 3 7 -1.5000 13.7486 0.1710 -3.7686 0.0000 0.0000 0.0000
2 3 7 3 -0.3120 -1.7990 0.2371 -3.2710 0.0000 0.0000 0.0000
1 3 7 3 -1.5000 -2.5000 0.6794 -2.5000 0.0000 0.0000 0.0000
7 3 7 3 -1.5000 7.4600 -0.9075 -9.0000 0.0000 0.0000 0.0000
2 3 9 3 -1.5000 6.8333 -0.1978 -1.4683 0.0000 0.0000 0.0000
2 3 9 4 -0.6181 7.1542 -0.0047 -1.6577 0.0000 0.0000 0.0000
2 4 9 3 -1.5000 1.7820 -1.0000 -5.4916 0.0000 0.0000 0.0000
2 4 9 4 -0.1959 2.3626 -1.0000 -3.0702 0.0000 0.0000 0.0000
2 1 4 9 0.0000 10.0000 0.3000 -6.0000 -1.0000 0.0000 0.0000
2 3 9 10 0.1589 12.5000 0.4388 -1.5000 0.0000 0.0000 0.0000
9 ! Nr of hydrogen bonds;at1;at2;at3;Rhb;Dehb;vhb1
3 2 3 2.1200 -3.5800 1.4500 19.5000
3 2 4 2.0985 -4.5000 1.4500 19.5000
4 2 3 1.7500 -1.5000 1.4500 19.5000
4 2 4 1.9893 -3.2987 1.4500 19.5000
3 2 5 1.5000 -2.0000 1.4500 19.5000
4 2 5 1.5000 -2.0000 1.4500 19.5000
5 2 3 1.5000 -2.0000 1.4500 19.5000
5 2 4 1.5000 -2.0000 1.4500 19.5000
5 2 5 1.5000 -2.0000 1.4500 19.5000
