I am trying to use a ReaxFF from ReactiveMD-force field: C/H/O/Fe/Al/Ni/Cu/S/Cr/N/X, C. Zou et al . , Acta Mater.2015, 83, 102 112, Redirecting. But there’s been an error :
ERROR on proc 0: 1.ff:374: Invalid force field file format (src/REAXFF/reaxff_ffield.cpp:584)
Last command: pair_coeff * * 1.ff C H O Fe N
Thank you in advance. ![]()
Following is my forcefield :
Blockquote
39 ! Number of general parameters
50.0000 !Overcoordination parameter
9.5469 !Overcoordination parameter
1.6725 !Valency angle conjugation parameter
1.7224 !Triple bond stabilisation parameter
6.8702 !Triple bond stabilisation parameter
60.4850 !C2-correction
1.0588 !Povun6 Undercoordination Eq(12)
4.6000 !Triple bond stabilisation parameter
12.1176 !Povun7 Undercoordination Eq(12)
13.3056 !Povun8 Undercoordination Eq(12)
-70.5044 !Triple bond stabilisation energy
0.0000 !Lower Taper-radius
10.0000 !Upper Taper-radius
2.8793 !Fe dimer correction
33.8667 !Valency undercoordination
6.0891 !Plp1 Lone pair param in Eq(8)
1.0563 !Valency angle
2.0384 !Valency angle parameter
6.1431 !Fe dimer correction
6.9290 !Double bond/angle parameter
0.3989 !Double bond/angle parameter:overcoord
3.9954 !Double bond/angle parameter:overcoord
-2.4837 !Fe dimer correction
5.7796 !Torsion/BO parameter
10.0000 !Torsion overcoordination
1.9487 !Torsion overcoordination
-1.2327 !Reserved
2.1645 !Conjugation
1.5591 !vdWaals shielding
0.1000 !Cutoff for bond order (*100)
1.7602 !Valency angle conjugation parameter
0.6991 !Povun3 overcoordination Eq(11b)
50.0000 !Povun3 overcoordination Eq(11b)
1.8512 !Valency/lone pair parameter
0.5000 !ACKS2 softness parameter
20.0000 !Scale factor (d) in dispersion (LJ)
5.0000 !Gauss exponent for explicit electrons
0.0000 !1: disable undecoord term in val angle
0.7903 !Valency angle conjugation parameter
12 ! Nr of atoms; cov.r;valency;a.m;Rvdw;Evdw;gammaEEM;cov.r2#
alfa;gammavdW;valency;Eunder;Eover;chiEEM;etaEEM;n.u.
cov r3;Elp;Heat inc.;bo131;bo132;bo133;softcut;n.u.
ov/un;val1;n.u.;val3,vval4
C 1.3817 4.0000 12.0000 1.8903 0.1838 0.9000 1.1341 4.0000
9.7559 2.1346 4.0000 34.9350 79.5548 5.9666 7.0000 0.0000
1.2114 0.0000 202.5551 8.9539 34.9289 13.5366 0.8563 0.0000
-2.8983 2.5000 1.0564 4.0000 2.9663 0.0000 0.0000 0.0000
H 0.8930 1.0000 1.0080 1.3550 0.0930 0.8203 -0.1000 1.0000
8.2230 33.2894 1.0000 0.0000 121.1250 3.7248 9.6093 1.0000
-0.1000 0.0000 61.6606 3.0408 2.4197 0.0003 1.0698 0.0000
-19.4571 4.2733 1.0338 1.0000 2.8793 0.0000 0.0000 0.0000
O 1.2450 2.0000 15.9990 2.3890 0.1000 1.0898 1.0548 6.0000
9.7300 13.8449 4.0000 37.5000 116.0768 8.5000 8.3122 2.0000
0.9049 0.4056 59.0626 3.5027 0.7640 0.0021 0.9745 0.0000
-3.5500 2.9000 1.0493 4.0000 2.9225 0.0000 0.0000 0.0000
Fe 1.9029 3.0000 55.8450 2.0990 0.1181 0.4304 -1.6836 3.0000
10.8548 2.6084 3.0000 0.0000 18.3725 1.7785 8.6281 0.0000
-1.2000 0.0000 102.1000 25.3430 10.1260 0.7590 0.8563 0.0000
-16.0573 2.6997 1.0338 6.0000 2.5791 0.0000 0.0000 0.0000
Al 2.4443 3.0000 26.9820 2.0089 0.2161 0.5675 -1.6836 3.0000
11.8538 16.3962 3.0000 0.0076 16.5151 -0.2451 6.3319 0.0000
-1.0000 0.0000 67.5458 137.9671 0.2042 0.0000 0.8563 0.0000
-14.9162 3.0000 1.0338 3.0000 2.5791 0.0000 0.0000 0.0000
Ni 1.8244 2.0000 58.6900 1.8442 0.1840 0.8105 0.1000 2.0000
12.3227 3.8387 2.0000 0.0000 0.0000 0.0100 6.1195 0.0000
-1.0000 0.0000 103.2000 50.6786 0.6762 0.0981 0.8563 0.0000
-19.6282 3.6035 1.0338 8.0000 2.5791 0.0000 0.0000 0.0000
Cu 1.9202 2.0000 63.5460 1.9221 0.2826 1.0000 0.1000 1.0000
10.9889 100.0000 1.0000 0.0000 0.0000 2.7875 6.0000 0.0000
-1.0000 0.0000 80.7000 34.9555 0.4988 0.0000 0.8563 0.0000
-5.1872 3.1491 1.0000 4.0000 2.5791 0.0000 0.0000 0.0000
S 1.8328 2.0000 32.0600 1.8815 0.3236 0.7530 1.6468 6.0000
9.0000 4.9055 4.0000 30.0000 112.1416 6.5745 9.0000 2.0000
1.0000 3.4994 65.0000 12.0000 22.1978 15.3230 0.9745 0.0000
-15.7363 2.8802 1.0338 6.2998 2.8793 0.0000 0.0000 0.0000
Cr 1.8834 3.0000 51.9962 2.3133 0.2205 0.4744 -1.6836 6.0000
10.2460 3.2000 3.0000 0.0000 18.3190 1.4000 9.0000 0.0000
-4.1000 2.6997 1.0338 6.0000 2.5791 0.0000 0.0000 0.0000
X -0.1000 2.0000 1.0080 2.0000 0.0000 0.0100 -0.1000 6.0000
10.0000 2.5000 4.0000 0.0000 0.0000 5.0000 999.9999 0.0000
-0.1000 0.0000 -2.3700 8.7410 13.3640 0.6690 0.9745 0.0000
-11.0000 2.7466 1.0338 2.0000 2.8793 0.0000 0.0000 0.0000
N 1.2333 3.0000 14.0000 2.2403 0.1102 0.9732 1.1748 5.0000
9.8276 12.0698 4.0000 30.2790 100.0000 6.1112 6.6645 2.0000
1.0433 0.1000 119.9837 0.7382 6.7108 2.7268 0.9745 0.0000
-2.0000 4.0000 1.0183 4.0000 2.8793 0.0000 0.0000 0.0000
Cl 1.7140 1.0000 35.4500 1.9139 0.2000 0.3853 -1.0000 7.0000
11.5345 10.1330 1.0000 0.0000 0.0000 9.5146 6.6817 0.0000
-1.0000 3.5750 143.1770 6.2293 5.2294 0.1542 0.8563 0.0000
-10.2080 2.9867 1.0338 6.2998 2.5791 0.0000 0.0000 0.0000
45 ! Nr of bonds;Edis1;LPpen;n.u.;pbe1;pbo5;13corr;pbo6
pbe2;pbo3;pbo4;n.u.;pbo1;pbo2;ovcorr
1 1 158.2004 99.1897 78.0000 -0.7738 -0.4550 1.0000 37.6117 0.4147
0.4590 -0.1000 9.1628 1.0000 -0.0777 6.7268 1.0000 0.0000
1 2 169.4760 0.0000 0.0000 -0.6083 0.0000 1.0000 6.0000 0.7652
5.2290 1.0000 0.0000 1.0000 -0.0500 6.9136 0.0000 0.0000
2 2 153.3934 0.0000 0.0000 -0.4600 0.0000 1.0000 6.0000 0.7300
6.2500 1.0000 0.0000 1.0000 -0.0790 6.0552 0.0000 0.0000
1 3 158.6946 107.4583 23.3136 -0.4240 -0.1743 1.0000 10.8209 1.0000
0.5322 -0.3113 7.0000 1.0000 -0.1447 5.2450 0.0000 0.0000
2 3 160.0000 0.0000 0.0000 -0.5725 0.0000 1.0000 6.0000 0.5626
1.1150 1.0000 0.0000 0.0000 -0.0920 4.2790 0.0000 0.0000
3 3 142.2858 145.0000 50.8293 0.2506 -0.1000 1.0000 29.7503 0.6051
10.3451 -0.1055 9.0000 1.0000 -0.1225 5.5000 1.0000 0.0000
1 4 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
0.2350 -0.3500 15.0000 1.0000 -0.2000 8.0000 1.0000 0.0000
2 4 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
3 4 67.5128 0.0000 0.0000 0.1301 -0.3000 0.0000 36.0000 0.0852
1.0000 -0.3500 15.0000 1.0000 -0.0629 7.1208 0.0000 0.0000
4 4 41.4611 0.0000 0.0000 0.2931 -0.2000 0.0000 16.0000 0.2682
0.6294 -0.2000 15.0000 1.0000 -0.0512 6.8013 0.0000 0.0000
1 5 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
2 5 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
3 5 175.2517 0.0000 0.0000 -0.8707 -0.3000 0.0000 36.0000 0.0100
0.9278 -0.3500 25.0000 1.0000 -0.1183 4.6533 0.0000 0.0000
4 5 64.0323 0.0000 0.0000 -0.2720 -0.3000 0.0000 16.0000 0.2822
2.2322 -0.4197 14.3085 1.0000 -0.2524 7.2814 0.0000 0.0000
5 5 65.7742 0.0000 0.0000 -0.4111 -0.3000 0.0000 16.0000 0.2955
2.8637 -0.4197 14.3085 1.0000 -0.1993 4.8757 0.0000 0.0000
1 6 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
2 6 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
3 6 86.9034 0.0000 0.0000 0.3377 -0.2000 1.0000 16.0000 0.0715
2.5302 -0.2500 15.0000 1.0000 -0.1923 4.8493 1.0000 0.0000
4 6 77.1297 0.0000 0.0000 -0.0431 -0.2000 0.0000 16.0000 0.2063
4.3648 -0.2000 15.0000 1.0000 -0.2542 5.5181 0.0000 0.0000
5 6 62.3744 0.0000 0.0000 -0.0066 -0.2000 0.0000 16.0000 0.2283
1.0966 -0.2000 15.0000 1.0000 -0.1072 4.0000 0.0000 0.0000
6 6 90.1410 0.0000 0.0000 -0.3857 -0.2000 0.0000 16.0000 0.3225
1.0927 -0.2000 15.0000 1.0000 -0.1027 4.6972 0.0000 0.0000
2 7 0.0000 0.0000 0.0000 0.2000 -0.1418 1.0000 13.1260 0.5000
0.5000 -0.2000 20.0000 1.0000 -0.1000 9.0000 0.0000 0.0000
3 7 81.4346 0.0000 0.0000 -0.1594 -0.3000 1.0000 36.0000 0.0025
0.2904 -0.2500 12.0000 1.0000 -0.0742 9.3638 0.0000 0.0000
7 7 73.6263 0.0000 0.0000 0.0209 -0.2000 0.0000 16.0000 0.3414
0.4703 -0.2000 15.0000 1.0000 -0.1319 5.9254 0.0000 0.0000
1 8 192.1462 90.5383 55.2528 -0.5652 -0.5211 1.0000 18.9617 0.1958
2.0000 -0.1016 13.8750 1.0000 -0.1579 5.5813 1.0000 0.0000
2 8 188.3744 0.0000 0.0000 -0.6562 0.0000 1.0000 6.0000 0.3870
11.8360 1.0000 0.0000 1.0000 -0.0762 5.0961 1.0000 0.0000
3 8 107.2917 202.9813 40.0000 0.4728 -0.2406 1.0000 22.1005 0.0500
0.6528 -0.3341 7.9877 1.0000 -0.0909 6.9512 1.0000 0.0000
4 8 75.5280 0.0000 0.0000 -0.4815 -0.3390 0.0000 16.0000 0.1769
0.2800 -0.1838 15.0000 1.0000 -0.0758 6.3424 0.0000 0.0000
5 8 123.2631 0.0000 0.0000 -0.4814 -0.3000 0.0000 16.0000 0.1762
4.6653 -0.4197 14.3085 1.0000 -0.1984 5.8018 0.0000 0.0000
6 8 9 0.8688 0.0000 0.0000 0.4233 -0.2000 0.0000 16.0000 0.1000
0.1604 -0.2500 25.0000 1.0000 -0.1028 5.0666 0.0000 0.0000
8 8 86.8868 69.1367 0.0000 -0.9993 -0.4781 1.0000 17.8574 0.0999
0.2799 -0.1677 8.2557 1.0000 -0.1131 6.1440 1.0000 0.0000
2 9 0.0000 0.0000 0.0000 1.0000 -0.3000 1.0000 36.0000 0.5000
0.3000 -0.3500 15.0000 1.0000 -0.2000 8.0000 1.0000 0.0000
3 9 103.1988 13.4351 0.0000 0.3247 -0.2172 1.0000 36.0000 0.0100
1.9519 -0.2293 9.6056 1.0000 -0.2000 5.7127 1.0000 0.0000
8 9 103.3203 0.0000 0.0000 0.6642 -0.3891 1.0000 36.0000 0.0100
0.1888 -0.2339 12.1279 1.0000 -0.1335 5.8332 1.0000 0.0000
9 9 46.2167 0.0000 0.0000 1.0000 -0.3000 0.0000 16.0000 0.0145
0.3576 -0.3000 16.0000 1.0000 -0.1252 5.5224 0.0000 0.0000
1 11 165.1874 148.6965 87.7249 -1.3237 -0.3504 1.0000 27.5446 0.1473
0.1449 -0.2871 7.2074 1.0000 -0.2565 4.4890 1.0000 0.0000
3 11 130.8596 169.4551 40.0000 0.3837 -0.1639 1.0000 35.0000 0.2000
1.0000 -0.3579 7.0004 1.0000 -0.1193 6.8773 1.0000 0.0000
11 11 157.9384 82.5526 152.5336 0.4010 -0.1034 1.0000 12.4261 0.5828
0.1578 -0.1509 11.9186 1.0000 -0.0861 5.4271 1.0000 0.0000
2 11 208.1369 0.0000 0.0000 -0.3949 0.0000 1.0000 6.0000 0.3340
6.0174 1.0000 0.0000 1.0000 -0.1026 5.5235 0.0000 0.0000
2 12 109.1686 0.0000 0.0000 -0.1657 -0.2000 0.0000 16.0000 1.2500
2.8463 -0.2000 15.0000 1.0000 -0.1111 5.2687 0.0000 0.0000
3 12 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
1.0001 -0.2000 15.0000 1.0000 -0.1000 10.0000 0.0000 0.0000
4 12 0.0000 0.0000 0.0000 0.2500 -0.2000 0.0000 16.0000 0.5000
0.5000 -0.2000 15.0000 1.0000 -0.2000 10.0000 0.0000 0.0000
12 12 0.2500 0.0000 0.0000 0.1803 -0.2000 0.0000 16.0000 0.3356
0.9228 -0.2000 15.0000 1.0000 -0.1178 5.6715 0.0000 0.0000
4 11 198.1147 0.0000 0.0000 -1.0100 -0.3000 1.0000 36.0000 0.0050
0.5250 -0.3500 15.0000 1.0000 -0.2494 4.6637 0.0000 0.0000
12 11 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
34 ! Nr of off-diagonal terms; Ediss; Ro; gamma; rsigma; rpi; rpi2
1 2 0.1239 1.4004 9.8467 1.1210 -1.0000 -1.0000
1 3 0.1156 1.8521 9.8317 1.2854 1.1352 0.0706
2 3 0.0283 1.2885 10.9190 0.9215 -1.0000 -1.0000
1 4 0.1500 1.9000 10.0000 -1.0000 -1.0000 -1.0000
2 4 0.0600 1.7000 11.0000 -1.0000 -1.0000 -1.0000
3 4 0.1000 1.8000 9.1989 1.7050 -1.0000 -1.0000
1 5 0.1500 1.9000 10.0000 -1.0000 -1.0000 -1.0000
2 5 0.0600 1.7000 11.0000 -1.0000 -1.0000 -1.0000
3 5 0.3745 1.8180 9.7359 1.4165 -1.0000 -1.0000
4 5 0.3463 1.9794 10.3688 2.4727 -1.0000 -1.0000
1 6 0.1500 1.9000 10.0000 -1.0000 -1.0000 -1.0000
2 6 0.0600 1.7000 11.0000 -1.0000 -1.0000 -1.0000
3 6 0.0514 1.7820 12.8150 1.4000 -1.0000 -1.0000
4 6 0.2667 1.9808 11.4966 2.0682 -1.0000 -1.0000
5 6 0.2647 1.8590 11.5886 1.5854 -1.0000 -1.0000
2 7 0.0300 1.5200 12.5000 0.1000 -1.0000 -1.0000
3 7 0.0348 1.7637 12.3562 1.7228 -1.0000 -1.0000
1 8 0.3314 1.7976 10.5605 1.6918 1.4000 -1.0000
2 8 0.1020 1.7528 9.6276 1.3714 -1.0000 -1.0000
3 8 0.2832 1.8196 10.2295 1.4502 1.4557 -1.0000
4 8 0.0854 1.7474 12.7924 1.9838 -1.0000 -1.0000
5 8 0.3159 1.7365 12.1526 2.2610 -1.0000 -1.0000
6 8 0.1917 1.6885 12.3915 1.7659 -1.0000 -1.0000
2 9 0.1000 1.5000 11.0000 -1.0000 -1.0000 -1.0000
3 9 0.0783 1.7000 10.3076 1.7000 1.7000 -1.0000
8 9 0.2335 2.0105 9.9500 1.7651 -1.0000 -1.0000
2 11 0.1275 1.3000 9.8924 1.0418 -1.0000 -1.0000
1 11 0.1952 1.8813 9.7734 1.3434 1.2545 1.1533
3 11 0.1201 2.4775 9.0171 1.5285 1.0682 1.2716
2 12 0.0568 1.6740 9.6297 1.2200 -1.0000 -1.0000
3 12 0.1927 2.2551 11.2308 -1.0000 -1.0000 -1.0000
4 12 0.1500 2.1500 11.0000 -1.0000 -1.0000 -1.0000
4 11 0.1889 1.6444 12.2047 1.9500 -1.0000 -1.0000
12 11 0.0263 2.0817 9.0879 -1.0000 -1.0000 -1.0000
153 ! Nr of angles;at1;at2;at3;Thetao,o;ka;kb;pv1;pv2
1 1 1 59.0573 30.7029 0.7606 0.0000 0.7180 6.2933 1.1244
1 1 2 65.7758 14.5234 6.2481 0.0000 0.5665 0.0000 1.6255
2 1 2 70.2607 25.2202 3.7312 0.0000 0.0050 0.0000 2.7500
1 1 3 49.6811 7.1713 4.3889 0.0000 0.7171 10.2661 0.4630
2 1 3 65.0000 13.8815 5.0583 0.0000 0.4985 0.0000 1.4900
3 1 3 77.7473 40.1718 2.9802 -25.3063 1.6170 -46.1315 2.2503
1 2 1 0.0000 3.4110 7.7350 0.0000 0.0000 0.0000 1.0400
1 2 2 0.0000 0.0000 6.0000 0.0000 0.0000 0.0000 1.0400
1 2 3 0.0000 25.0000 3.0000 0.0000 1.0000 0.0000 1.0400
2 2 2 0.0000 27.9213 5.8635 0.0000 0.0000 0.0000 1.0400
2 2 3 0.0000 8.5744 0.0000 0.0000 0.0000 0.0000 1.0421
3 2 3 0.0000 15.0000 2.8900 0.0000 0.0000 0.0000 2.8774
1 3 1 73.5312 44.7275 0.7354 0.0000 3.0000 0.0000 1.0684
1 3 3 79.4761 36.3701 1.8943 0.0000 0.7351 67.6777 0.0000
1 3 2 70.1880 20.9562 0.3864 0.0000 0.0050 0.0000 1.6924
2 3 2 85.8000 9.8453 2.2720 0.0000 2.8635 0.0000 1.5800
2 3 3 75.6935 50.0000 2.0000 0.0000 1.0000 0.0000 1.1680
3 3 3 80.7324 30.4554 0.9953 0.0000 1.6310 50.0000 1.0783
4 3 4 63.0740 14.8127 2.9929 0.0000 0.7552 0.0000 1.3634
1 3 4 60.0000 10.0000 1.0000 0.0000 1.0000 0.0000 1.0500
2 3 4 63.4137 5.0000 6.2310 0.0000 1.4521 0.0000 1.0460
3 3 4 73.6721 32.6330 1.7223 0.0000 1.0221 0.0000 1.4351
3 4 4 69.4895 5.7742 8.0001 0.0000 1.7794 0.0000 2.7889
1 3 5 90.0000 5.0000 3.0000 0.0000 1.0000 0.0000 1.1000
2 3 5 90.0000 11.1212 4.3379 0.0000 3.0000 0.0000 3.0000
3 3 5 43.6280 11.0750 6.2000 0.0000 3.0000 0.0000 1.0100
5 3 5 64.5513 10.5987 0.4710 0.0000 3.0000 0.0000 1.6045
3 5 3 84.7469 7.3926 2.9453 0.0000 1.0000 0.0000 1.2535
3 5 5 27.4957 14.3276 0.2771 0.0000 2.3158 0.0000 2.2134
1 3 6 70.0000 25.0000 1.0000 0.0000 1.0000 0.0000 1.2500
2 3 6 29.3808 16.2484 5.8320 5.0000 0.0100 0.0000 1.9017
3 3 6 81.5303 14.3201 4.2623 0.0000 0.3854 0.0000 2.4644
3 6 3 33.8130 15.1818 4.0000 0.0000 0.0354 0.0000 1.3198
6 3 6 88.1216 15.8581 7.0940 0.0000 0.6326 0.0000 1.1340
3 6 6 19.7429 2.9501 6.2770 0.0000 0.0732 0.0000 1.7069
3 7 3 96.2265 4.5610 12.0000 0.0000 0.3211 0.0000 1.5204
7 3 7 100.0000 10.1065 6.0000 0.0000 1.0000 0.0000 3.6601
2 3 7 55.0417 3.5032 9.9790 0.0000 1.5171 0.0000 1.0400
3 3 7 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
3 7 7 66.7783 14.3146 0.7911 0.0000 1.0000 0.0000 1.2333
8 5 8 92.5166 8.8772 2.9319 0.0000 0.2516 0.0000 1.0620
5 8 5 73.8915 23.2173 0.0851 0.0000 0.0100 0.0000 2.6540
5 5 8 69.3869 3.0494 0.0000 0.0000 0.6079 0.0000 1.0000
5 8 8 30.9172 16.7973 5.9170 0.0000 0.9584 0.0000 2.1273
2 8 5 83.4937 25.0000 1.0000 5.0000 0.5409 0.0000 1.1378
5 2 8 0.0000 10.0000 1.0000 5.0000 0.2500 0.0000 1.5000
8 8 8 84.2345 15.5790 3.7715 0.0000 1.3066 0.0000 1.6270
2 6 2 106.3969 30.0000 0.9614 0.0000 1.9664 0.0000 2.2693
2 2 6 0.0000 26.3327 4.6867 0.0000 0.8177 0.0000 1.0404
6 2 6 0.0000 60.0000 1.8471 0.0000 0.6331 0.0000 1.8931
2 6 6 30.3748 1.0000 4.8528 0.0000 0.1019 0.0000 3.1660
1 6 2 97.5742 10.9373 5.2000 0.0000 1.8558 0.0000 1.0000
1 2 6 0.0000 1.2811 1.1741 0.0000 0.9136 0.0000 3.8138
2 1 6 84.0006 45.0000 6.2710 0.0000 3.0000 0.0000 1.0000
8 6 8 0.2000 6.6443 1.2359 0.0000 0.0156 0.0000 1.1250
6 8 6 107.2989 23.4838 0.7435 0.0000 0.2609 0.0000 1.3395
6 6 8 18.7110 13.5233 0.1006 0.0000 0.0747 0.0000 1.3658
6 8 8 54.9369 16.5560 6.0000 0.0000 0.2213 0.0000 1.5255
2 8 6 83.4937 16.7605 0.8242 5.0000 0.5409 0.0000 1.1378
6 2 8 0.0000 10.0000 1.0000 5.0000 0.2500 0.0000 1.5000
2 8 2 90.0601 42.2756 5.3020 0.0000 0.3707 0.0000 1.0071
2 8 8 66.1035 8.0885 0.0424 0.0000 0.7355 0.0000 3.0000
3 5 8 19.4072 10.4590 2.8285 0.0000 1.0074 0.0000 2.3949
3 8 5 83.6415 19.7500 2.9247 0.0000 1.9437 0.0000 1.0348
5 3 8 89.6617 15.3276 2.7567 0.0000 1.6031 0.0000 1.0781
5 3 6 95.3249 30.0000 6.6640 0.0000 2.0000 0.0000 1.0000
3 5 6 4.7439 7.2911 1.8650 0.0000 1.5814 0.0000 1.4132
3 6 5 39.4301 10.2218 1.3968 0.0000 1.8777 0.0000 1.6288
1 1 8 71.4462 27.2223 6.7228 0.0000 0.0050 0.0000 2.6454
1 8 1 92.6710 15.6798 3.1104 0.0000 0.3458 0.0000 2.3207
2 1 8 43.6595 11.8933 5.4490 0.0000 0.0050 0.0000 1.9326
1 8 2 99.1897 14.1666 2.5588 0.0000 0.3542 0.0000 2.5990
1 8 8 89.3910 5.0000 7.0000 0.0000 1.0050 0.0000 1.5000
3 8 3 83.5231 37.5859 0.9881 -0.0100 1.4725 0.0000 1.0641
1 8 3 79.9791 29.5117 7.0000 0.0000 0.0050 0.0000 1.2255
1 3 8 83.1032 23.4174 0.7741 0.0000 1.2168 0.0000 2.7365
3 3 8 60.2631 30.0701 2.1707 0.0000 1.3323 0.0000 1.0192
3 8 8 55.9402 38.2990 3.6930 0.0000 2.2673 0.0000 1.0000
2 3 8 35.9099 19.1501 1.9918 0.0000 0.9342 0.0000 2.7883
1 2 8 0.0000 6.2500 0.0000 0.0000 0.0000 0.0000 1.0400
3 2 8 0.0000 1.0574 0.1000 0.0000 0.0000 0.0000 2.7676
8 2 8 0.0000 7.5000 2.0000 0.0000 0.0000 0.0000 1.0400
8 4 8 0.2000 7.5083 1.3736 0.0000 0.0412 0.0000 1.8149
4 8 4 100.0000 9.2519 0.7752 0.0000 0.1221 0.0000 2.2142
4 4 8 33.4003 16.6274 0.1076 0.0000 0.0825 0.0000 1.0000
4 8 8 77.0475 7.4569 4.9579 0.0000 0.7548 0.0000 2.3345
2 8 4 84.8837 16.4865 0.8240 5.0000 0.5428 0.0000 1.1398
4 2 8 0.0000 10.0000 1.0000 5.0000 0.2500 0.0000 1.5000
3 4 8 29.3282 8.1452 2.8121 0.0000 0.2287 0.0000 1.9412
4 3 8 4.8461 15.5458 2.9681 0.0000 1.0491 0.0000 1.4836
3 8 4 89.9073 7.0973 1.3919 0.0000 0.8210 0.0000 2.9921
3 9 3 72.0610 9.9276 3.7068 0.0000 2.0407 0.0000 1.4632
9 3 9 53.2083 34.6712 10.0000 0.0000 1.4829 0.0000 1.9159
3 3 9 71.6698 44.3637 2.0880 0.0000 1.1760 0.0000 1.5367
3 9 9 56.4467 26.7016 0.3699 0.0000 1.7359 0.0000 1.9750
2 3 9 0.0000 0.0000 1.0000 0.0000 1.0000 0.0000 1.0500
1 3 9 0.0000 0.0000 1.0000 0.0000 1.0000 0.0000 1.0500
8 9 8 70.0000 20.0000 2.0000 0.0000 1.0000 0.0000 1.0000
9 8 9 87.9918 25.0000 3.0000 0.0000 0.5523 0.0000 1.6121
8 8 9 70.0000 20.0000 2.0000 0.0000 1.0000 0.0000 1.0000
8 9 9 53.1529 19.1953 0.3597 0.0000 0.2000 0.0000 1.6208
2 8 9 0.0000 0.0000 1.0000 0.0000 1.0000 0.0000 1.0500
1 8 9 0.0000 0.0000 1.0000 0.0000 1.0000 0.0000 1.0500
5 8 6 105.0000 35.0000 2.2077 0.0000 0.5911 0.0000 2.7573
6 5 8 72.2779 29.1869 0.2831 0.0000 0.9971 0.0000 1.2000
5 6 8 45.7012 27.4289 0.2324 0.0000 1.1218 0.0000 1.7540
4 3 5 29.4269 22.0505 1.8191 0.0000 3.0000 0.0000 2.5264
3 4 5 89.9909 0.0139 1.2646 0.0000 2.7433 0.0000 2.9105
3 5 4 28.1272 10.3178 0.0000 0.0000 1.6706 0.0000 1.9396
4 3 6 56.8615 9.2273 1.7526 0.0000 0.9612 0.0000 1.1817
3 6 4 35.0000 4.5000 3.0000 0.0000 1.3000 0.0000 2.3000
3 4 6 70.0000 4.5000 3.0000 0.0000 1.3000 0.0000 2.3000
8 3 8 76.3546 40.0000 3.3161 0.0000 51.9473 0.0000 1.0000
4 8 5 62.8042 12.1651 0.8881 0.0000 1.0000 0.0000 3.0000
5 4 8 64.5399 0.0100 0.0100 0.0000 0.5378 0.0000 2.9111
4 5 8 13.6043 4.1825 2.6350 0.0000 0.7360 0.0000 3.0000
1 1 11 66.8437 45.0000 1.2491 0.0000 1.1834 0.0000 3.0000
3 1 11 82.7022 45.0000 0.5769 0.0000 1.1019 0.0000 1.0000
11 1 11 90.0000 43.1792 5.0550 0.0000 1.1155 0.0000 1.0204
2 1 11 63.9629 41.6246 1.4921 0.0000 0.2000 0.0000 2.8070
1 2 11 0.0000 196.3000 0.0000 0.0000 0.0000 0.0000 1.0400
1 3 11 69.5983 45.0000 1.4248 0.0000 2.9000 0.0000 2.3286
3 3 11 83.5202 33.7933 0.0337 0.0000 2.9000 0.0000 1.3398
11 3 11 67.1317 42.3748 1.7873 0.0000 3.0072 0.0000 1.5832
2 3 11 72.7348 20.1071 7.5000 0.0000 1.0000 0.0000 1.0746
1 11 1 70.6778 12.3495 3.0486 0.0000 2.8702 0.0000 1.0000
1 11 3 73.9745 21.1329 2.3337 0.0000 2.8701 0.0000 1.7170
1 11 11 71.4579 14.0942 2.8540 0.0000 2.8701 0.0000 1.0631
3 11 3 74.2613 20.9008 2.8607 -18.0069 3.0701 0.0000 1.3874
3 11 11 74.2615 27.8669 1.6736 -0.9193 3.0117 0.0000 1.4381
11 11 11 73.3189 24.9685 2.2561 0.0000 2.9983 0.0000 2.1573
1 11 2 70.2498 13.6111 2.6311 0.0000 0.2025 0.0000 1.0000
2 11 3 74.5739 45.0000 1.4078 0.0000 0.3956 0.0000 3.0000
2 11 11 79.7136 45.0000 0.5316 0.0000 0.5437 0.0000 1.0000
2 11 2 80.2201 6.8385 7.5000 0.0000 1.0000 0.0000 1.0000
1 2 11 0.0000 42.2694 1.1363 0.0000 0.0000 0.0000 1.8036
3 2 11 0.0000 0.1057 40.1000 0.0000 0.0000 0.0000 2.7676
11 2 11 0.0000 1.0100 9.0929 0.0000 0.0000 0.0000 2.1728
2 2 11 0.0000 196.0000 0.0000 0.0000 0.0000 0.0000 1.0400
3 2 12 0.0000 0.0100 52.1100 0.0000 0.0000 0.0000 1.3859
4 4 11 60.6208 0.0005 1.0000 0.0000 1.0000 0.0000 1.0500
4 11 4 60.6940 48.4934 0.0781 0.0000 0.8437 0.0000 1.7269
4 11 11 60.2448 151.0000 0.0000 0.0000 1.0000 0.0000 1.0500
1 4 11 60.9600 26.7607 3.5118 0.0000 0.4951 0.0000 1.2412
4 1 11 60.7474 30.9543 8.3823 0.0000 1.6809 0.0000 0.8828
1 11 4 49.9600 9.1695 17.8776 0.0000 0.0090 0.0000 2.3011
2 4 11 60.6044 37.1068 12.7082 0.0000 1.0347 0.0000 0.9854
4 2 11 60.6454 55.9810 1.8460 0.0000 0.5210 0.0000 1.9247
2 11 4 70.3700 14.2206 29.3305 0.0000 0.9960 0.0000 3.3044
3 4 11 58.8200 26.9630 2.8930 0.0000 1.1971 0.0000 1.6975
4 3 11 60.0096 27.5304 3.3856 0.0000 0.7971 0.0000 2.0245
11 4 11 53.7500 13.6454 4.9011 0.0000 0.5491 0.0000 0.8300
38 ! Nr of torsions;at1;at2;at3;at4;;V1;V2;V3;V2(BO);vconj;n.u;n
1 1 1 1 -0.2500 34.7453 0.0288 -6.3507 -1.6000 0.0000 0.0000
1 1 1 2 -0.2500 29.2131 0.2945 -4.9581 -2.1802 0.0000 0.0000
2 1 1 2 -0.2500 31.2081 0.4539 -4.8923 -2.2677 0.0000 0.0000
1 1 1 3 -0.3495 22.2142 -0.2959 -2.5000 -1.9066 0.0000 0.0000
2 1 1 3 0.0646 24.3195 0.6259 -3.9603 -1.0000 0.0000 0.0000
3 1 1 3 -0.5456 5.5756 0.8433 -5.1924 -1.0180 0.0000 0.0000
1 1 3 1 1.7555 27.9267 0.0072 -2.6533 -1.0000 0.0000 0.0000
1 1 3 2 -1.4358 36.7830 -1.0000 -8.1821 -1.0000 0.0000 0.0000
2 1 3 1 -1.3959 34.5053 0.7200 -2.5714 -2.1641 0.0000 0.0000
2 1 3 2 -2.5000 70.0597 1.0000 -3.5539 -2.9929 0.0000 0.0000
1 1 3 3 0.6852 11.2819 -0.4784 -2.5000 -2.1085 0.0000 0.0000
2 1 3 3 0.1933 80.0000 1.0000 -4.0590 -3.0000 0.0000 0.0000
3 1 3 1 -1.9889 76.4820 -0.1796 -3.8301 -3.0000 0.0000 0.0000
3 1 3 2 0.2160 72.7707 -0.7087 -4.2100 -3.0000 0.0000 0.0000
3 1 3 3 -2.5000 71.0772 0.2542 -3.1631 -3.0000 0.0000 0.0000
1 3 3 1 2.5000 -0.6002 1.0000 -3.4297 -2.8858 0.0000 0.0000
1 3 3 2 -2.5000 -3.3822 0.7004 -5.4467 -2.9586 0.0000 0.0000
2 3 3 2 2.5000 -4.0000 0.9000 -2.5000 -1.0000 0.0000 0.0000
1 3 3 3 1.2329 -4.0000 1.0000 -2.5000 -1.7479 0.0000 0.0000
2 3 3 3 0.8302 -4.0000 -0.7763 -2.5000 -1.0000 0.0000 0.0000
3 3 3 3 -2.5000 -4.0000 1.0000 -2.5000 -1.0000 0.0000 0.0000
0 1 2 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0 2 2 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0 2 3 0 0.0000 0.1000 0.0200 -2.5415 0.0000 0.0000 0.0000
0 1 1 0 0.0000 50.0000 0.3000 -4.0000 -2.0000 0.0000 0.0000
0 3 3 0 0.5511 25.4150 1.1330 -5.1903 -1.0000 0.0000 0.0000
2 3 7 3 -1.5000 6.8333 -0.1978 -1.4683 0.0000 0.0000 0.0000
0 2 8 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
8 8 8 8 2.4661 71.9719 0.0100 -8.0000 0.0000 0.0000 0.0000
2 8 8 2 0.0000 50.0000 0.0000 -8.0000 0.0000 0.0000 0.0000
2 3 8 3 2.5000 2.5000 0.2237 -10.0000 0.0000 0.0000 0.0000
0 1 8 0 0.5000 50.0000 0.5000 -10.0000 0.0000 0.0000 0.0000
0 3 8 0 0.5000 50.0000 0.5000 -8.0000 0.0000 0.0000 0.0000
3 8 8 8 0.2500 90.0000 0.5000 -6.0000 0.0000 0.0000 0.0000
3 8 8 3 0.2500 90.0000 0.5000 -6.0000 0.0000 0.0000 0.0000
1 8 8 1 0.0000 50.0000 0.0000 -8.0000 0.0000 0.0000 0.0000
1 8 8 2 0.0000 50.0000 0.0000 -8.0000 0.0000 0.0000 0.0000
7 ! Nr of hydrogen bonds;at1;at2;at3;Rhb;Dehb;vhb1
3 2 3 2.1200 -3.5800 1.4500 19.5000
3 2 8 2.5000 -1.0000 1.4500 19.5000
8 2 3 2.5000 -1.0000 1.4500 19.5000
8 2 8 2.5000 -2.0000 1.4500 19.5000
3 2 11 2.1215 -7.5000 1.4500 19.5000
11 2 3 1.7500 -4.3286 1.4500 19.5000
11 2 11 2.4000 -2.3575 1.4500 19.5000
Blockquote
the problem seems appeared at the part of “torsions”
but I can’t figure it out
