Hi, Axel,
Thanks for your quick reply, there are only small difference in the intensity. But when i use the different random number (seed) to run the exact same simulation with the same number of cores, the intensities are also not converged, is that also because of the “statistic uncertainty”? or something wrong with my specification in the input script?
Hi, Axel,
also not converged, is that also because of the "statistic uncertainty"? or
have you spent some time reading up on the issues that i mentioned?
if you properly understand what is going on, you should be able to
answer this question yourself.
remember that in your paper/thesis you cannot write: "this is
acceptable because some random dude on the internet told me so".
BTW: there are plenty of publications and text book material on
estimating/quantifying statistical errors in properties derived from
molecular dynamics simulations.
