Hi LAMMPS users and developers!
I’m trying to run a PIMD simulation in LAMMPS. The fix pimd doc page says that the simulation need to be started in this way:
mpirun -np P lmp_mpi -partition MxN -in script
where P=M*N. Since I have to launch M (# of beads) partitions, it seems that I need to use at least M mpi threads. However, this is not feasible in my specific setup (I’m working with a custom pair style connecting to an external program, and having M mpi threads means launching M instances of that program, which leads to OOM).
I’m wondering if it’s possible to e.g. run a simulation with 32 beads on 8 mpi threads, where one thread is responsible for 4 beads. Maybe the forces of 4 beads are evaluated in turn, i.e. first the coordinates of 1st beads are sent for force evaluation, then the 2nd beads (after the results of 1st beads have returned), etc. Time integration occurs after all forces have returned.
If it’s not possible with the current LAMMPS version, I want to get a crude estimate on how difficult it’ll be to implement this (to see if I want to implement this myself, or I should find other solutions).
Thanks!
