Dear exciting developers and users,
I would like to know if the functional TB09 metaGGA is implemented in the exciting-oxygen version.
If it is already implemented, I would like to know how to use it?
thanks in advance
Hi makhlouf,
No, there are no meta GGAs implemented directly in exciting. We are in the process of updating of our LibXC interface and will also add the ability to compute meta GGAs. I expect this to be done some time next year.
Cheers,
Alex
Dear exciting devs,
What’s the status now? Can we use TB09 metaGGA with SOC on the newest version with libxc?
Best regards.
Hi @gerson
I had started the port to LibXC 6 whilst still in the group, however I’m not sure if this got merged.
Use of meta-GGAs requires implementation of the kinetic energy operator. This is being done as a master’s project, and I imagine once that project finishes, metaGGAs will be usable with LibXC 6.
So it’s a work-in-progress.
Cheers,
Alex
Thanks for the quick reply.
I’ve wrote a code DFT2kp, published this year on SciPost, that currently works only on Quantum Espresso, so it is limited to the QE “band quality”.
Now, to improve the code I need better DFT data (fixing the gap, basically), and meta-GGA is one of the interesting routes there. Currently, QE does not support metaGGA with SOC, so I’ve been checking other open-source DFT codes. If exciting gets there, it would interesting to extend my DFT2kp code to work with exciting as well. Currently, the only option I have is VASP. But I’m trying to avoid commercial codes at the moment.
So, for now I’ll bookmark/track/watch this question and I’ll check it again later on.
Cheers,
Gerson
