First of all, thanks for the great work on developing Fireworks! I’ve been using the package for a while, and it’s been a great tool for running my workflows.
I seem to be running into an issue when trying to connect to a mongoDB atlas server with the new version (v1.8.9). Here’s the trace when trying to connect to the mongoDB database using lpad get_fws
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 109, in get_lp
return LaunchPad.from_file(args.launchpad_file)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/utilities/fw_serializers.py", line 286, in from_file
return cls.from_format(f.read(), f_format=f_format)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/utilities/fw_serializers.py", line 254, in from_format
yaml.safe_load(f_str)))
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 258, in from_dict
authsource)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 167, in __init__
self.db = self.connection[dbname]
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1323, in __getitem__
return database.Database(self, name)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/pymongo/database.py", line 110, in __init__
_check_name(name)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/pymongo/database.py", line 51, in _check_name
"character %r" % invalid_char)
pymongo.errors.InvalidName: database names cannot contain the character '.'
authsource)
_check_name(name)
During handling of the above exception, another exception occurred:
File "/Users/mbercx/miniconda3/envs/pmg/bin/lpad", line 10, in <module>
sys.exit(lpad())
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 1171, in lpad
args.func(args)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 216, in get_fws
lp = get_lp(args)
File "/Users/mbercx/miniconda3/envs/pmg/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 121, in get_lp
raise ValueError(err_message)
ValueError: FireWorks was not able to connect to MongoDB. Is the server running? The database file specified was /Users/mbercx/Dropbox/python/sandbox/fireworks/my_launchpad.yaml.
The issue can be reproduced by setting up a conda environment and installing fireworks via pip:
conda create -n test
conda activate test
conda install pip
pip install fireworks dnspython
and trying to get the fireworks from the following launchpad file using lpad get_fws
host: mongodb+srv://tutorial-urpwq.gcp.mongodb.net
port: 27017
username: tester
password: fireworks123
ssl: true
authsource: admin
If I set up a new conda environment and pip install fireworks v1.8.8, everything runs smoothly, so it seems to be related to the final update. Any ideas on how to fix this?
Kind regards,
Marnik
