I am trying to make atom 2 use the born potential to be attracted to atom 1. I cannot seem to find the issue but the atoms will not go toward each other unless I add an outside force. Any help would be greatly appreciated.
units si #material can be metal, in this case use si
dimension 3 #number of dimensions this will run in
#boundary p p p #Periodic(atoms can go on the side of the boundary come back the other way), fixed(atoms dissapear), shrink-wrapped(boundary moves with particles)
boundary f f f
atom_style full
read_data data_1bead_diffusion.tri
pair_style none
bond_style harmonic
angle_style harmonic
group F type 1
group S type 2 #stickiness on the bottom of the model
angle_coeff 1 1.39E-22 180
bond_coeff 1 100 1e-9
timestep 20e-15
reset_timestep 0
atom_modify sort 0 2
run_style verlet
neigh_modify delay 0 every 1 check yes page 500000 one 50000
neighbor 1E-14 bin
dielectric 80.0
pair_style hybrid/overlay coul/debye 1e9 2e-9 born 10e-9
pair_coeff * * coul/debye
pair_coeff 1 1 none
pair_coeff 2 2 none
pair_coeff 1 2 born 1.65 5.3e-8 5.1e-9 0 9
fix 1 all langevin 300 300 3.8507e-12 6030 zero no #axes 1 1 1
fix 2 all nve
thermo 10000
thermo_style multi
dump VMD0 all xyz 50000 Center250.xyz
run 850000
