Issue with model_fields AttributeError in mp-api During Materials Summary Search
Hi everyone,
I’m new to using the mp-api Python client and recently encountered an issue while running example code to query materials summary data from the Materials Project.
Here’s the exact code I used (adapted from the official documentation):
with MPRester(API_key) as mpr:
    docs = mpr.materials.summary.search(
        elements=["Si", "O"],
        band_gap=(0.5, 1.0)
    print(docs)
And the error traceback is as follows:
File ~\.conda\envs\materialproject\Lib\site-packages\mp_api\client\core\client.py:1075, in BaseRester._generate_returned_model(self, doc)
   1067 unset_fields = [field for field in doc.model_fields if field not in set_fields]
   1069 data_model = create_model(  # type: ignore
   1070     "MPDataDoc",
   1071     fields_not_requested=(list[str], unset_fields),
   1072     __base__=self.document_model,  # type: ignore
   1073 )
-> 1075 data_model.model_fields = {
   1076     **{
   1077         name: description
   1078         for name, description in data_model.model_fields.items()
   1079         if name in set_fields
   1080     },
   1081     "fields_not_requested": data_model.model_fields["fields_not_requested"],
   1082 }
   1084 def new_repr(self) -> str:
   1085     extra = ",\n".join(
   1086         f"\033[1m{n}\033[0;0m={getattr(self, n)!r}"
   1087         for n in data_model.model_fields
   1088     )
AttributeError: property 'model_fields' of 'ModelMetaclass' object has no setter
I am running this code on Python 3.12.7
Despite these attempts, the issue persists. As a new user of mp-api, I’m unsure if this is due to a version incompatibility, a bug, or a misunderstanding of the API usage.
Has anyone encountered similar issues or could provide advice on how to fix this? Any help would be greatly appreciated!
Thank you in advance for your time and support!
Thanks for reporting the issue. It’s related to a breaking change in the latest release of pydantic. Please follow this github issue: [Bug]: pydantic 2.10.0 breaks mp-api · Issue #941 · materialsproject/api · GitHub. Downgrading pydantic should help in the meantime.
There’s a release candidate on PyPI now that should address this issue: mp-api · PyPI
The bug was fixed after the 0.43.0rc1 update. Thank you very much.
FYI New release v0.43.0 is out.
