The MP API documentation details how to use the has_props parameter, namely by providing a list of strings:
via:
with MPRester("your_api_key_here") as mpr:
docs = mpr.materials.summary.search(
has_props=["dielectric", "dos"], fields=["material_id"]
However, it looks as if this code throws an error and I need to use the actual Enum object which is much less convenient:
from emmet.core.summary import HasProps
docs = mpr.materials.summary.search(has_props=[HasProps.dielectric, HasProps.dos], fields=["material_id"])
Can you confirm this behavior?
Thanks @Anubhav_Jain for reporting this! I can confirm that it throws the following error. I’m looking into it and will update this thread when a new release of mp-api
is out.
File ~/miniconda3/envs/mp-api/lib/python3.10/site-packages/mp_api/client/routes/materials/summary.py:256, in <listcomp>(.0)
253 query_params.update({"has_reconstructed": has_reconstructed})
255 if has_props:
--> 256 query_params.update({"has_props": ",".join([i.value for i in has_props])})
258 if theoretical is not None:
259 query_params.update({"theoretical": theoretical})
AttributeError: 'str' object has no attribute 'value'
@Anubhav_Jain I just released mp-api==0.42.0
which should fix the issue.
