Hello to everyone,
I’m trying to do an example simulation with snap potentials and kokkos, but the simulation sends an error.
I have the latest Lammps with Kokkos, my GPU is a Nvidia with Pascal architecture. I try to run the in.snap.Ta06A example.
The error in terminal is this
LAMMPS (15 Sep 2022)
KOKKOS mode is enabled (src/KOKKOS/kokkos.cpp:106)
will use up to 1 GPU(s) per node
Kokkos::Cuda::initialize WARNING: running kernels compiled for compute capability 6.0 on device with compute capability 6.1 , this will likely reduce potential performance.
Lattice spacing in x,y,z = 3.316 3.316 3.316
Created orthogonal box = (0 0 0) to (13.264 13.264 13.264)
Created 128 atoms
using lattice units in orthogonal box = (0 0 0) to (13.264 13.264 13.264)
create_atoms CPU = 0.001 seconds
Reading potential file Ta06A.snapcoeff with DATE: 2014-09-05
SNAP Element = Ta, Radius 0.5, Weight 1
Reading potential file Ta06A.snapparam with DATE: 2014-09-05
SNAP keyword rcutfac 4.67637
SNAP keyword twojmax 6
SNAP keyword rfac0 0.99363
SNAP keyword rmin0 0
SNAP keyword bzeroflag 0
SNAP keyword quadraticflag 0
ERROR: Pair style SNAP requires newton pair on (src/KOKKOS/pair_snap_kokkos_impl.h:102)
Last command: run ${nsteps}
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[18635,1],0]
Exit code: 1
I already try to reinstall Lammps with Kokkos and Snap, but the problem continues.
Greetings and thank you
