P R E L I M I N A R I E S
variable Tmp equal 0.68
units lj # Use reduced LJ style units
atom_style atomic # Uncharged point particles
atom_modify map hash # Needed for indexing of clusters etc
lattice fcc 1.0 spacing 1 1 1
region box block 0 4 0 4 0 4 units lattice
create_box 1 box
create_atoms 1 box
variable ra uloop 3
variable rand equal (25373+${ra})
log cryst_t${Tmp}_r${rand}.log
Set the mass of the first (and only) atom type.
mass 1 1.0
Lennard-Jones interactions between particles, 3.5 sigma cut-off. Apply
long range tail corrections to energy and pressure
pair_style lj/cut 3.5
pair_modify tail yes
pair_coeff 1 1 1.0 1.0
M E L T S Y S T E M
velocity all create 2.4 ${rand} mom yes dist gaussian # Assign velocities
timestep 0.002 # simulation timestep
thermo 100 # output thermodynamic data every 100 steps
trajectory first 13000 steps
dump traj_first all custom 100 traj_first_${ra}.dat id type x y z vx vy vz
#first fix
fix 1 all npt temp 2.4 2.4 0.1 iso 5.0 5.0 0.5 mtk yes tchain 5 pchain 5
run 10000
#second fix
fix 1 all npt temp 1.25 1.25 0.1 iso 5.68 5.68 0.5 mtk yes tchain 5 pchain 5
run 1000
#third fix
fix 1 all npt temp 1.25 ${Tmp} 0.1 iso 5.68 5.68 0.5 mtk yes tchain 5 pchain 5
run 2000
#g(r) third fix
compute myRDF1 all rdf 150
fix rdf_calc1 all ave/time 50 10 500 c_myRDF1[*] file rdf_first_${ra}.dat mode vector
run 0
undump traj_first
F R E E Z E S Y S T E M
Define solid atoms. This closely follows ten Wolde Ruiz-Montero and Frenkel Faraday Discuss 1996 104 93-110
Compute components of the per-atom q6 vector
compute q6 all orientorder/atom degrees 1 6 components 6 nnn NULL cutoff 1.3
get number of connections
compute coord_number all coord/atom orientorder q6 0.5
An atom is solid if it has 8 or more connections
variable is_solid atom c_coord_number>=8
group solid dynamic all var is_solid # Must be dynamic to update
do clustering
compute cluster solid cluster/atom 1.3
define chunks one chunk per cluster
compute clus_chunks solid chunk/atom c_cluster
count the size of each chunk
compute size_chunks solid property/chunk clus_chunks count
Find the maximum entry in the vector of chunk sizes
variable max_n equal max(c_size_chunks)
Thermo style which includes this variable
thermo_style custom step temp pe vol v_max_n
thermo 100 # Print the thermo information every 100 steps
Reset the npt fix at a lower temperature (below freezing)
fix 1 all npt temp {Tmp} {Tmp} 0.1 iso 5.0 5.0 0.5 mtk yes tchain 5 pchain 5
print positions and velocities
dump traj all custom 100 traj_${ra}.dat id type x y z vx vy vz
run 100000 # Run for this many steps
g(r) final state
compute myRDF2 all rdf 1024
fix rdf_calc2 all ave/time 1 1 1 c_myRDF2[*] file rdf_final_${ra}.dat mode vector
run 0
clear
next ra
jump SELF
Hello everyone, could someone kindly help me?
This is my code for studying nucleation. In the code, the RDF is calculated twice. However, I can’t understand why the second calculation produces an empty file (with no data) when I use numbers other than 1 1 1 in the command
For example, using 50 10 500, as I did for the first RDF calculation, doesn’t work. Does anyone know the reason for this behavior?
P.S. The code is used to study the nucleation of the system, which starts at T=2.4 in LJ units and is gradually cooled down to T=0.68. The goal is to calculate the q6 parameter and observe how many atoms crystallize during the evolution.
Thank you!
