Hi, I am having some issues using the bond_style zero available in LAMMPS (23 Mar 2016). It is my understanding that by adding bonds to the system and assigning the bond_style “zero”, there should be no additional energy contributions to the system and the bonds are there just for tracking purposes. However, I discovered noticeable deviations in the energy of my system so I made a decided to make a small sample to double check.
In my sample model, I have created a two layer system of copper atoms and have assigned the top half to type 1 and bottom half to type 2 (both Cu EAM). I ran two cases, which I believe should yield similar results, and minimized both structures:
- No interaction between layers with no create_bonds:
- No interaction between layers with bond_style zero:
For run #1, I get a total energy of -14221.6. For run #2, I get a total energy of -13893.1. Since the models are not being time-integrated, I would assume the two values to be much closer than this. Does anyone know where this additional contribution is coming from?
Thank you in advance,
- Nick
CODE:
------------------------ INITIALIZATION ----------------------------
echo screen
atom_style full
variable latparam equal 3.615
----------------------- ATOM DEFINITION ----------------------------
lattice fcc ${latparam}
region substrate block 0 8 0 8 0 16
create_box 2 substrate bond/types 1 extra/bond/per/atom 6
lattice fcc ${latparam} origin 0 0 0 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block INF INF INF INF INF 16
create_atoms 1 region box
region bottom block INF INF INF INF INF 8
region top block INF INF INF INF 8 16
set region top type 2
group top type 2
group bottom type 1
mass 1 63.54
mass 2 63.54
atom_modify sort 0 0
----------------------- POTENTIAL/BOND ------------------------------
pair_style eam/alloy
pair_coeff * * Cu01.eam.alloy Cu Cu
bond_style zero
bond_coeff 1
----------------------- ADD BONDS ------------------------------------
create_bonds top bottom 1 0 3.615
neigh_modify exclude type 1 2
----------------------- CHECK BONDS ------------------------------------
compute peBond all pe bond
----------------------- MINIMIZE -----------------------------------
shell mkdir dump_bond
shell cd dump_bond
timestep 0.01
thermo 1000
thermo_style custom step etotal ke pe enthalpy c_peBond
dump RELAX all custom 1000 Cu_bond_base.*.cfg id type x y z
min_style cg
min_modify dmax 1.0e-2 line quadratic
fix min all box/relax aniso 0.0 vmax 0.01
minimize 0.0 1.0e-4 10000 10000
