Hi everyone,
I have encountered a problem and I would appreciate any help in resolving it. Here are the details:
module load compiler/cuda/12.1
module load compiler/inteloneAPI/mpi/2021.13
module load compiler/inteloneAPI/tbb
module load compiler/inteloneAPI/compiler-rt/2024.2.1
module load compiler/inteloneAPI/compiler/2024.2.1
module load compiler/inteloneAPI/mkl/2024.2
module load compiler/gcc/12.4.0
cmake -C β¦/cmake/presets/basic.cmake
-C β¦/cmake/presets/oneapi.cmake
-D CMAKE_CUDA_COMPILER=/public/software/compiler/cuda/12.1/bin/nvcc
-D LAMMPS_CUDA=yes
-D CMAKE_BUILD_TYPE=Release
-D CMAKE_INSTALL_PREFIX=/public/software/apps/lammps/29Aug2024-intelOneAPI-gpu-4090
-D BUILD_OMP=yes
-D PKG_OPENMP=yes
-D PKG_MOLECULE=yes
-D PKG_MANYBODY=yes
-D PKG_KSPACE=yes
-D PKG_INTEL=yes
-D PKG_SHIK=yes
-D BUILD_SHIK=yes
-D ENABLE_GPU=yes
-D ENABLE_KIM=yes
-D ENABLE_REAXC=yes
-D FFT=MKL
-D FFT_KOKKOS=MKL
-D PKG_GPU=on
-D GPU_ARCH=89
-D GPU_API=cuda
-D CMAKE_CXX_FLAGS=β-msse4.1 -msse4.2β
-D CUDA_TOOLKIT_ROOT_DIR=/public/software/compiler/cuda/12.1
β¦/cmake
This generated the following file contents:
loading initial cache file β¦/cmake/presets/basic.cmake
loading initial cache file β¦/cmake/presets/oneapi.cmake
β Appending /public/software/compiler/gcc/13.3.0/lib64:/public/software/apps/lammps/29Aug2024-inteloneAPI-gpu/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mkl/2024.2/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/opt/mpi/libfabric/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/lib:/public/software/compiler/intel/oneAPIBaseToolkit/compiler/2024.2/lib:/public/software/compiler/intel/oneAPIBaseToolkit/tbb/2021.13/lib to CMAKE_LIBRARY_PATH: /public/software/compiler/gcc/13.3.0/lib64:/public/software/apps/lammps/29Aug2024-inteloneAPI-gpu/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mkl/2024.2/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/opt/mpi/libfabric/lib:/public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/lib:/public/software/compiler/intel/oneAPIBaseToolkit/compiler/2024.2/lib:/public/software/compiler/intel/oneAPIBaseToolkit/tbb/2021.13/lib
β Running check for auto-generated files from make-based build system
β Found OpenMP_CXX: -qopenmp -qopenmp-simd
β Could NOT find FFMPEG (missing: FFMPEG_EXECUTABLE)
β Checking for module βfftw3β
β Package βfftw3β, required by βvirtual:worldβ, not found
β Generating style headersβ¦
β Generating package headersβ¦
β Generating lmpinstalledpkgs.hβ¦
β Could NOT find ClangFormat (missing: ClangFormat_EXECUTABLE) (Required is at least version β11.0β)
β The following tools and libraries have been found and configured:
- Git
- MPI
- CURL
- JPEG
- PNG
- ZLIB
- PkgConfig
- TBB_MALLOC
- MKL
- Threads
- CUDA
- OpenMP
- Python3
β <<< Build configuration >>>
LAMMPS Version: 20240829
Operating System: Linux CentOS 8
CMake Version: 3.20.2
Build type: Release
Install path: /public/software/apps/lammps/29Aug2024-intelOneAPI-gpu-4090
Generator: Unix Makefiles using /usr/bin/gmake
β Enabled packages: GPU;INTEL;KSPACE;MANYBODY;MOLECULE;OPENMP;RIGID
β <<< Compilers and Flags: >>>
β C++ Compiler: /public/software/compiler/intel/oneAPIBaseToolkit/compiler/2024.2/bin/icpx
Type: IntelLLVM
Version: 2024.2.1
C++ Standard: 11
C++ Flags: -msse4.1 -msse4.2 -O3 -DNDEBUG
Defines: LAMMPS_SMALLBIG;LAMMPS_MEMALIGN=64;LAMMPS_OMP_COMPAT=4;LAMMPS_CURL;LAMMPS_JPEG;LAMMPS_PNG;LAMMPS_GZIP;FFT_MKL;FFT_MKL_THREADS;LMP_OPENMP;LMP_INTEL;LMP_INTEL_USELRT;LMP_USE_MKL_RNG;LMP_GPU
Options: -Wno-tautological-constant-compare;-Wno-unused-command-line-argument
β <<< Linker flags: >>>
β Executable name: lmp
β Static library flags:
β <<< MPI flags >>>
β MPI_defines: MPICH_SKIP_MPICXX;OMPI_SKIP_MPICXX;_MPICC_H
β MPI includes: /public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/include
β MPI libraries: /public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/lib/libmpicxx.so;/public/software/compiler/intel/oneAPIBaseToolkit/mpi/2021.13/lib/libmpi.so;/usr/lib64/librt.so;/usr/lib64/libpthread.so;/usr/lib64/libdl.so;
β <<< GPU package settings >>>
β GPU API: CUDA
β CUDA Compiler: /public/software/compiler/cuda/12.1/bin/nvcc
β GPU default architecture: 89
β GPU binning with CUDPP: OFF
β CUDA MPS support: OFF
β GPU precision: MIXED
β <<< FFT settings >>>
β Primary FFT lib: MKL
β Using double precision FFTs
β Using threaded FFTs
β Using builtin distributed FFT algorithms
β Configuring done
β Generating done
β Build files have been written to: /public/sourcecode/lammps1/lammps-stable_29Aug2024_update1/build
Howere, when i run make, here are the output:
[ 0%] Building NVCC fatbin file cuda_compile_fatbin_1_generated_lal_zbl.cu.fatbin
[ 0%] Built target memory.h
[ 0%] Built target fmt_core.h
[ 1%] Built target nvc_get_devices
[ 1%] Building NVCC fatbin file cuda_compile_fatbin_1_generated_lal_atom.cu.fatbin
[ 1%] Building NVCC fatbin file cuda_compile_fatbin_1_generated_lal_amoeba.cu.fatbin
[ 2%] Built target variable.h
[ 2%] Building NVCC fatbin file cuda_compile_fatbin_1_generated_lal_beck.cu.fatbin
/public/software/compiler/gcc/12.4.0/lib/gcc/x86_64-pc-linux-gnu/12.4.0/β¦/β¦/β¦/β¦/include/c++/12.4.0/ext/type
_traits.h(196): error: parameter pack β_Tpβ was referenced but not expanded
using __promoted_t = decltype((typename __promote<_Tp>::__type(0) + β¦));
_traits.h(196): error: expected an expression
/public/software/compiler/gcc/12.4.0/lib/gcc/x86_64-pc-linux-gnu/12.4.0/β¦/β¦/β¦/β¦/include/c++/12.4.0/type_tra
I want use lammps with GPU, how can i fix this issue.
Thank you in advance for your assistance!
