Issues with spacegroup 71 calculations with mp-ids `mp-109XXXX`
A few years ago I noticed an issue with a wren model I tried on MP looking at spacegroup 71 but didn’t have any particular way to attribute the poor predictive performance to actual data points in MP:
Today I was looking at the alexandria dataset and MP to compare to what extent they overlap and noticed that when comparing the vasp energy per atom for the structures in alexandria that have have a aflow-style protostructure label found in MP there was a distinct anomalous population. Further investigation exposed that they were almost entirely in spacegroup 71 and had mp-109XXXX mp-ids. outside this there are a few random errors between MP and alexandria but this is the dominant systematic issue.
I think that this mp-109XXXX should be investigated further and potentially dropped from future db releases if found to be inconsistent.
Thanks @CompRhys!
There are a lot of possibilities for computational / methodological differences which might lead to this discrepancy, but it’s obviously suspect given the consistency of the space group / A_2 B C structure prototype of these.
I’ll try rerunning a few to see if there are marked changes in the total energies. In the meantime, would you mind sending a dict of Alexandria total energies with MPIDs they’re matched to?
Also for clarity, I’m turning up 2,116 possibly problematic structures that match your criteria with this query:
with MPRester() as mpr:
    summary_docs = mpr.materials.summary.search(spacegroup_number=71,fields=["material_id","origins"])
    to_check = []
    for doc in summary_docs:
        if (mpid := str(doc.material_id)).startswith("mp-") and mpid.split("mp-")[-1].startswith("109"):
            for entry in doc.origins:
                if entry.name == "structure":
                    to_check.append(str(entry.task_id))
                    break
    task_docs = mpr.materials.tasks.search(task_ids=to_check)
task_docs = [
    task for task in task_docs
    if task.output.structure.get_space_group_info()[1] == 71
Let me know if those IDs (also attached) match for you.
suspect_task_ids.json (28.9 KB)
eda_mp_wbm_alex.py (4.9 KB)
alex_mp_final_struct_aflow_prototypes.csv.xz (2.0 MB)
Here are the scripts I was using to analyze, in order to be able to upload here I have uploaded just the overlapping alex entries that duplicate protostructures in MP all other files are downloaded from mbd on the fly if needed. The first df_comb on line 61 will have the MP vasp energies and alexandria equivalents in the same df.
Thanks for looking at this, I’m quite satisfied with finding this during eda as I have really not been able to attribute the above error to anything concrete before today.
Additionally mp-1247730, mp-1248716, mp-1255731, mp-1258701, mp-1259896, mp-1264151, and mp-1262938 look suspect to me for similar discrepancies
These id’s are potentially also worth looking at based on similar divergences but can’t really spot anything systematic
['mp-1006115',
 'mp-1046037',
 'mp-1066',
 'mp-1066771',
 'mp-1071438',
 'mp-1072579',
 'mp-1076286',
 'mp-1076923',
 'mp-1077305',
 'mp-1077403',
 'mp-1077617',
 'mp-1078456',
 'mp-1079041',
 'mp-1079338',
 'mp-1079563',
 'mp-1079782',
 'mp-1080576',
 'mp-1080840',
 'mp-1084754',
 'mp-1094902',
 'mp-1096246',
 'mp-1096312',
 'mp-1096751',
 'mp-1102209',
 'mp-1102353',
 'mp-1102385',
 'mp-1102535',
 'mp-1102751',
 'mp-1102920',
 'mp-1103074',
 'mp-1104405',
 'mp-1105011',
 'mp-1105430',
 'mp-1105578',
 'mp-1105616',
 'mp-1105650',
 'mp-1178650',
 'mp-1178654',
 'mp-1178963',
 'mp-1179239',
 'mp-1179506',
 'mp-1179622',
 'mp-1179649',
 'mp-1179733',
 'mp-1179833',
 'mp-1179990',
 'mp-1181307',
 'mp-1181342',
 'mp-1181556',
 'mp-1181670',
 'mp-1181833',
 'mp-1182363',
 'mp-1182706',
 'mp-1182806',
 'mp-1184489',
 'mp-1184513',
 'mp-1184716',
 'mp-1185472',
 'mp-1185480',
 'mp-1185587',
 'mp-1185609',
 'mp-1185611',
 'mp-1185783',
 'mp-1186796',
 'mp-1186929',
 'mp-1187075',
 'mp-1187833',
 'mp-1188245',
 'mp-1188638',
 'mp-1189473',
 'mp-1190896',
 'mp-1190933',
 'mp-1191162',
 'mp-1191193',
 'mp-1191764',
 'mp-1191949',
 'mp-1192293',
 'mp-1192449',
 'mp-1192608',
 'mp-1192665',
 'mp-1192781',
 'mp-1192972',
 'mp-1193274',
 'mp-1193565',
 'mp-1193924',
 'mp-1194072',
 'mp-1194245',
 'mp-1194558',
 'mp-1194710',
 'mp-1201305',
 'mp-1204701',
 'mp-1205943',
 'mp-1206073',
 'mp-1206079',
 'mp-1206109',
 'mp-1206156',
 'mp-1206190',
 'mp-1206232',
 'mp-1206253',
 'mp-1206275',
 'mp-1206317',
 'mp-1206328',
 'mp-1206336',
 'mp-1206377',
 'mp-1206385',
 'mp-1206390',
 'mp-1206433',
 'mp-1206459',
 'mp-1206475',
 'mp-1206575',
 'mp-1206696',
 'mp-1206726',
 'mp-1206740',
 'mp-1206835',
 'mp-1206869',
 'mp-1206888',
 'mp-1206934',
 'mp-1206939',
 'mp-1206950',
 'mp-1206966',
 'mp-1207047',
 'mp-1207051',
 'mp-1207133',
 'mp-1207258',
 'mp-1207266',
 'mp-1207280',
 'mp-1207296',
 'mp-1207306',
 'mp-1207310',
 'mp-1207311',
 'mp-1207313',
 'mp-1207314',
 'mp-1207315',
 'mp-1207322',
 'mp-1207329',
 'mp-1207340',
 'mp-1207368',
 'mp-1207991',
 'mp-1208078',
 'mp-1208306',
 'mp-1208309',
 'mp-1208313',
 'mp-1208315',
 'mp-1208342',
 'mp-1208426',
 'mp-1208624',
 'mp-1208775',
 'mp-1209146',
 'mp-1209898',
 'mp-1209992',
 'mp-1210245',
 'mp-1210439',
 'mp-1210706',
 'mp-1210906',
 'mp-1210939',
 'mp-1211109',
 'mp-1211305',
 'mp-1211341',
 'mp-1211445',
 'mp-1211453',
 'mp-1211623',
 'mp-1212042',
 'mp-1212055',
 'mp-1212104',
 'mp-1212274',
 'mp-1212351',
 'mp-1212378',
 'mp-1212929',
 'mp-1213020',
 'mp-1213329',
 'mp-1213433',
 'mp-1213437',
 'mp-1213556',
 'mp-1213623',
 'mp-1213831',
 'mp-1214061',
 'mp-1214268',
 'mp-1214460',
 'mp-1214610',
 'mp-1214861',
 'mp-1214985',
 'mp-1215073',
 'mp-1215080',
 'mp-1215084',
 'mp-1215087',
 'mp-1215157',
 'mp-1215925',
 'mp-1219657',
 'mp-1219827',
 'mp-1219839',
 'mp-1221574',
 'mp-1221614',
 'mp-1221882',
 'mp-1222042',
 'mp-1222217',
 'mp-1224215',
 'mp-1224523',
 'mp-1224726',
 'mp-1225074',
 'mp-1225348',
 'mp-1229022',
 'mp-1238763',
 'mp-1245761',
 'mp-1247730',
 'mp-1247838',
 'mp-1247881',
 'mp-1248716',
 'mp-1251411',
 'mp-1255731',
 'mp-1258701',
 'mp-1259896',
 'mp-1262938',
 'mp-1264151',
 'mp-1330336',
 'mp-1337078',
 'mp-1337126',
 'mp-1339913',
 'mp-1347973',
 'mp-1361141',
 'mp-1371261',
 'mp-1371686',
 'mp-1372590',
 'mp-1376614',
 'mp-1376797',
 'mp-1378207',
 'mp-1381342',
 'mp-1385813',
 'mp-1386638',
 'mp-1386900',
 'mp-1391114',
 'mp-1392021',
 'mp-1392145',
 'mp-1393434',
 'mp-1393717',
 'mp-1399051',
 'mp-1400737',
 'mp-1404622',
 'mp-1404786',
 'mp-1405076',
 'mp-1405864',
 'mp-1406711',
 'mp-1406815',
 'mp-1414055',
 'mp-1416168',
 'mp-1425089',
 'mp-1444833',
 'mp-1445086',
 'mp-1517779',
 'mp-1517791',
 'mp-1518619',
 'mp-1519303',
 'mp-1519404',
 'mp-1520433',
 'mp-1521374',
 'mp-1522661',
 'mp-19485',
 'mp-20448',
 'mp-20644',
 'mp-20700',
 'mp-21383',
 'mp-21458',
 'mp-2272170',
 'mp-2279',
 'mp-23907',
 'mp-27884',
 'mp-2814',
 'mp-2840',
 'mp-37537',
 'mp-510140',
 'mp-510613',
 'mp-541126',
 'mp-542606',
 'mp-542621',
 'mp-542633',
 'mp-568714',
 'mp-574507',
 'mp-582399',
 'mp-582464',
 'mp-607826',
 'mp-640044',
 'mp-640458',
 'mp-647604',
 'mp-671957',
 'mp-672441',
 'mp-673165',
 'mp-673954',
 'mp-674158',
 'mp-675106',
 'mp-675126',
 'mp-675871',
 'mp-675893',
 'mp-675946',
 'mp-676985',
 'mp-677135',
 'mp-677260',
 'mp-677510',
 'mp-689577',
 'mp-694615',
 'mp-722045',
 'mp-724868',
 'mp-725071',
 'mp-725133',
 'mp-725152',
 'mp-725918',
 'mp-726838',
 'mp-727231',
 'mp-728349',
 'mp-728567',
 'mp-729608',
 'mp-730082',
 'mp-730563',
 'mp-731625',
 'mp-753915',
 'mp-756644',
 'mp-756779',
 'mp-763017',
 'mp-770668',
 'mp-778269',
 'mp-780121',
 'mp-781020',
 'mp-781462',
 'mp-787551',
 'mp-795937',
 'mp-796795',
 'mp-798767',
 'mp-799684',
 'mp-802090',
 'mp-802184',
 'mp-806032',
 'mp-806082',
 'mp-817993',
 'mp-820801',
 'mp-850880',
 'mp-861726',
 'mp-861952',
 'mp-862739',
 'mp-865177',
 'mp-866089',
 'mp-886266',
 'mp-888449',
 'mp-888651',
 'mp-908109',
 'mp-973155',
 'mp-976591',
 'mp-977365',
 'mp-978096',
 'mp-989467',
 'mp-989699',
 'mvc-11882']
Hi @CompRhys - I’m not finding systematic discrepancies between the task docs on MP and my rerun static calcs. On average, the total energies per atom differ by:
  • signed: -5.4 meV/atom
  • unsigned: 22.9 meV/atom
So obviously some differences but nothing systematic. Likewise, the standard deviations between old and new calcs of the total energies is 67.5 meV/atom. I can trace some of the larger energy differences to different final magnetic configurations
Worth noting I ran these 1,767 MPIDs:
(df_comb["material_id_mp"].str.startswith("mp-109")) & (df_comb["spg_mp"]==71)
Hard for me to say why Alexandria’s energies differ so much for these without seeing their VASP inputs
thanks for checking! I’ll continue to look at them and report if I can trace the source of the discrepancy
Just to be clear: the structures are identical between Alexandria and MP right? If the Alexandria set contains re-relaxed structures (starting from MP initial or final structures), then there’s a possibility for a different relaxation trajectory. This becomes likelier if there are pseudopotential discrepancies.
I’ll look into this more since it’s quite suspicious that there’s such a marked discrepancy
alex-examples.json (53.1 KB)
mp-matching-examples.json (8.0 KB)
So here are 3 corresponding pairs for MP and Alexandria. The Structures in MP have volumes around 10x that of Alexandria equivalents. Looking at the MP structures on the MP site they don’t really match with my expectation’s for the chemistry due to the large distances between the 1D chains (mp-1093584: CrReW2 (Orthorhombic, Immm, 71)) in contrast to
which at a surface level seem okay.
did you try decreasing the volume to something close to alexandria and rerunning some relaxations to see what comes out? I tried it for one K2RbNa structure mp-1096543: K2RbNa (Orthorhombic, Immm, 71) and it stayed at a lower volume and a lower energy than the MP structure .
If you just take the MP structure and rerelax it, it mostly stays the same so it’s in a local minimum. I ran slightly more precise settings than mp-relax set but mostly the same.
just to revive this thread, it seems fairly clear that MP has about 2k saddle-point structures with IDs in the mp-109XXXX range that failed to converge to the true ground state found in the Alexandria dataset. they should probably be deprecated from the next DB release and/or a warning message shown on their MP detail pages. @Anubhav_Jain
Tagging @Aaron_Kaplan since he was the one looking into this earlier
