It is difficult to converge when calculating the carrier mobility at low temperatures and low concentrations
Hello,Alex
It is difficult to converge when calculating the carrier mobility at low temperatures and low concentrations. According to your reply in the previous question, I have put dos_estep=0.001 ,but the calculation is too large to complete when calculating low temperature. So I used dos_estep=0.005 for the calculation, but it is still difficult to converge.
Best wishes
amset.log (10.6 KB)
hi, I also met the same problem, I calculated the same result as you, did you solve the problem?
