import numpy as np
import matplotlib.pyplot as plt
from matplotlib.animation import FuncAnimation
from matplotlib.widgets import Slider
— COSMETIC USER TOGGLE —
SHOW_SURFACE = True # Set to True to see the virtual surface skin, False to turn it off
1. FIXED QUANTUM SEQUENCE DATA MATRIX (1 TO 120) WITH STRINGS
Complete element lookup table for the corner display readout text box
element_names = {
1: (“Hydrogen”, “H”), 2: (“Helium”, “He”), 3: (“Lithium”, “Li”), 4: (“Beryllium”, “Be”),
5: (“Boron”, “B”), 6: (“Carbon”, “C”), 7: (“Nitrogen”, “N”), 8: (“Oxygen”, “O”),
9: (“Fluorine”, “F”), 10: (“Neon”, “Ne”), 11: (“Sodium”, “Na”), 12: (“Magnesium”, “Mg”),
13: (“Aluminium”, “Al”), 14: (“Silicon”, “Si”), 15: (“Phosphorus”, “P”), 16: (“Sulfur”, “S”),
17: (“Chlorine”, “Cl”), 18: (“Argon”, “Ar”), 19: (“Potassium”, “K”), 20: (“Calcium”, “Ca”),
21: (“Scandium”, “Sc”), 22: (“Titanium”, “Ti”), 23: (“Vanadium”, “V”), 24: (“Chromium”, “Cr”),
25: (“Manganese”, “Mn”), 26: (“Iron”, “Fe”), 27: (“Cobalt”, “Co”), 28: (“Nickel”, “Ni”),
29: (“Copper”, “Cu”), 30: (“Zinc”, “Zn”), 31: (“Gallium”, “Ga”), 32: (“Germanium”, “Ge”),
33: (“Arsenic”, “As”), 34: (“Selenium”, “Se”), 35: (“Bromine”, “Br”), 36: (“Krypton”, “Kr”),
37: (“Rubidium”, “Rb”), 38: (“Strontium”, “Sr”), 39: (“Yttrium”, “Y”), 40: (“Zirconium”, “Zr”),
41: (“Niobium”, “Nb”), 42: (“Molybdenum”, “Mo”), 43: (“Technetium”, “Tc”), 44: (“Ruthenium”, “Ru”),
45: (“Rhodium”, “Rh”), 46: (“Palladium”, “Pd”), 47: (“Silver”, “Ag”), 48: (“Cadmium”, “Cd”),
49: (“Indium”, “In”), 50: (“Tin”, “Sn”), 51: (“Antimony”, “Sb”), 52: (“Tellurium”, “Te”),
53: (“Iodine”, “I”), 54: (“Xenon”, “Xe”), 55: (“Caesium”, “Cs”), 56: (“Barium”, “Ba”),
57: (“Lanthanum”, “La”), 58: (“Cerium”, “Ce”), 59: (“Praseodymium”, “Pr”), 60: (“Neodymium”, “Nd”),
61: (“Promethium”, “Pm”), 62: (“Samarium”, “Sm”), 63: (“Europium”, “Eu”), 64: (“Gadolinium”, “Gd”),
65: (“Terbium”, “Tb”), 66: (“Dysprosium”, “Dy”), 67: (“Holmium”, “Ho”), 68: (“Erbium”, “Er”),
69: (“Thulium”, “Tm”), 70: (“Ytterbium”, “Yb”), 71: (“Lutetium”, “Lu”), 72: (“Hafnium”, “Hf”),
73: (“Tantalum”, “Ta”), 74: (“Tungsten”, “W”), 75: (“Rhenium”, “Re”), 76: (“Osmium”, “Os”),
77: (“Iridium”, “Ir”), 78: (“Platinum”, “Pt”), 79: (“Gold”, “Au”), 80: (“Mercury”, “Hg”),
81: (“Thallium”, “Tl”), 82: (“Lead”, “Pb”), 83: (“Bismuth”, “Bi”), 84: (“Polonium”, “Po”),
85: (“Astatine”, “At”), 86: (“Radon”, “Rn”), 87: (“Francium”, “Fr”), 88: (“Radium”, “Ra”),
89: (“Actinium”, “Ac”), 90: (“Thorium”, “Th”), 91: (“Protactinium”, “Pa”), 92: (“Uranium”, “U”),
93: (“Neptunium”, “Np”), 94: (“Plutonium”, “Pu”), 95: (“Americium”, “Am”), 96: (“Curium”, “Cm”),
97: (“Berkelium”, “Bk”), 98: (“Californium”, “Cf”), 99: (“Einsteinium”, “Es”), 100: (“Fermium”, “Fm”),
101: (“Mendelevium”, “Md”), 102: (“Nobelium”, “No”), 103: (“Lawrencium”, “Lr”), 104: (“Rutherfordium”, “Rf”),
105: (“Dubnium”, “Db”), 106: (“Seaborgium”, “Sg”), 107: (“Bohrium”, “Bh”), 108: (“Hassium”, “Hs”),
109: (“Meitnerium”, “Mt”), 110: (“Darmstadtium”, “Ds”), 111: (“Roentgenium”, “Rg”), 112: (“Copernium”, “Cn”),
113: (“Nihonium”, “Nh”), 114: (“Flerovium”, “Fl”), 115: (“Moscovium”, “Mc”), 116: (“Livermorium”, “Lv”),
117: (“Tennessine”, “Ts”), 118: (“Oganesson”, “Og”), 119: (“Ununennium”, “Uue”), 120: (“Unbinilium”, “Ubn”)
def get_block(z):
s_elements = [1, 2, 3, 4, 11, 12, 19, 20, 37, 38, 55, 56, 87, 88, 119, 120]
if z in s_elements:
return “s”
if z <= 10 or (13<=z<=18) or (31<=z<=36) or (49<=z<=54) or (81<=z<=86) or (113<=z<=118):
return “p”
if z <= 30 or (39<=z<=48) or (71<=z<=80) or (103<=z<=112):
return “d”
return “f”
R_TORUS = 2.5
raw_elements_list =
for z in range(1, 121):
hemisphere = “North” if z % 2 != 0 else “South”
name_str, sym_str = element_names.get(z, (f"Element {z}“, f"El{z}”))
raw_elements_list.append({
“z”: z,
“block”: get_block(z),
“hemisphere”: hemisphere,
“name”: name_str,
“symbol”: sym_str
2. MATCHING WINDOW SETUP & WEBELEMENTS COLOR MAPS
plt.style.use(‘dark_background’)
fig = plt.figure(figsize=(11, 9))
ax = fig.add_subplot(111, projection=‘3d’)
plt.subplots_adjust(bottom=0.25)
block_colors_map = {
“s”: “#3b82f6”, # Blue
“p”: “#f97316”, # Orange
“d”: “#ef4444”, # Red
“f”: “#22c55e” # Green
Backdrop wireframe matrix mesh
theta_mesh = np.linspace(0, 2np.pi, 60)
phi_mesh = np.linspace(0, 2np.pi, 60)
TM, PM = np.meshgrid(theta_mesh, phi_mesh)
X_mesh = (R_TORUS + R_TORUS * np.cos™) * np.cos(PM)
Y_mesh = (R_TORUS + R_TORUS * np.cos™) * np.sin(PM)
Z_mesh = R_TORUS * np.sin™
Renders wireframe or solid surface skin based on top toggle state configuration
if SHOW_SURFACE:
surface_object = ax.plot_surface(X_mesh, Y_mesh, Z_mesh, color=‘cyan’, alpha=0.06, shade=True)
else:
ax.plot_wireframe(X_mesh, Y_mesh, Z_mesh, color=‘cyan’, alpha=0.03, linewidth=0.5)
Initialize lines for the chronological segments of our single tracking thread
north_path_line, = ax.plot(, , , color=‘cyan’, linestyle=‘-’, linewidth=2.0, alpha=0.9, label=‘North (Solid)’)
south_path_line, = ax.plot(, , , color=‘magenta’, linestyle=‘–’, linewidth=2.0, alpha=0.9, label=‘South (Dashed)’)
inner_south_line, = ax.plot(, , , color=‘magenta’, linestyle=‘–’, linewidth=2.0, alpha=0.9)
inner_north_line, = ax.plot(, , , color=‘cyan’, linestyle=‘-’, linewidth=2.0, alpha=0.9)
scatter_nodes = ax.scatter(, , , s=90, edgecolors=‘white’, depthshade=True)
text objects to handle dashboard box readouts and node labels seamlessly
readout_text = ax.text2D(0.02, 0.95, “”, transform=ax.transAxes, color=‘white’,
fontsize=12, fontweight=‘bold’, bbox=dict(facecolor=‘black’, alpha=0.6, edgecolor=‘dimgray’))
text_labels_pool =
current_screw_angle = 0.0
3. PURE GEOMETRIC VORTEX ENGINE (DYNAMIC TIERS LENGTH STEPPING)
def get_pure_helical_coords(t_val, total_turns, screw_angle_deg):
theta = np.pi / 2 - (t_val * np.pi)
phi = (t_val * total_turns * np.pi) + np.radians(screw_angle_deg)
x = (R_TORUS + R_TORUS * np.cos(theta)) * np.cos(phi)
y = (R_TORUS + R_TORUS * np.cos(theta)) * np.sin(phi)
z = R_TORUS * np.sin(theta)
return x, y, z
def render_dynamic_toroid_spiral(screw_angle_deg, total_turns):
pts = 400
x1, y1, z1 = get_pure_helical_coords(np.linspace(0, 0.5, pts), total_turns, screw_angle_deg)
north_path_line.set_data(x1, y1)
north_path_line.set_3d_properties(z1)
x2, y2, z2 = get_pure_helical_coords(np.linspace(0.5, 1.0, pts), total_turns, screw_angle_deg)
south_path_line.set_data(x2, y2)
south_path_line.set_3d_properties(z2)
x3, y3, z3 = get_pure_helical_coords(np.linspace(1.0, 1.5, pts), total_turns, screw_angle_deg)
inner_south_line.set_data(x3, y3)
inner_south_line.set_3d_properties(z3)
x4, y4, z4 = get_pure_helical_coords(np.linspace(1.5, 2.0, pts), total_turns, screw_angle_deg)
inner_north_line.set_data(x4, y4)
inner_north_line.set_3d_properties(z4)
4. INTERACTIVE MASTER DRIVER LOOP
ax_slider = plt.axes([0.25, 0.08, 0.5, 0.03], facecolor=‘dimgray’)
node_slider = Slider(ax_slider, ‘Atomic Nodes Added’, 1, 120, valinit=78, valfmt=‘%d’, color=‘magenta’)
def render_frame(frame):
global current_screw_angle, text_labels_pool
current_screw_angle = (current_screw_angle + 1.2) % 360.0
max_active_nodes = int(node_slider.val)
# Clean previous node text objects to refresh efficiently without stacking ghosts
for txt in text_labels_pool:
txt.remove()
text_labels_pool = []
total_turns = round(4.0 + (max_active_nodes / 120.0) * 12.0)
render_dynamic_toroid_spiral(current_screw_angle, total_turns)
# Update active dashboard box display metrics configuration dynamically
last_el = raw_elements_list[max_active_nodes - 1]
readout_text.set_text(
f"Active Element Node Profile:\n"
f"Symbol: {last_el['symbol']} | Name: {last_el['name']}\n"
f"Atomic Number Z: {max_active_nodes}\n"
f"Quantum Orbital Block: {last_el['block'].upper()}-Block"
x_nodes, y_nodes, z_nodes, color_list = [], [], [], []
for i in range(max_active_nodes):
el = raw_elements_list[i]
progress = i / max_active_nodes if max_active_nodes > 1 else 0.0
if el["hemisphere"] == "North":
path_t = progress * 0.5
else:
path_t = 1.0 - (progress * 0.5)
xn, yn, zn = get_pure_helical_coords(path_t, total_turns, current_screw_angle)
x_nodes.append(xn)
y_nodes.append(yn)
z_nodes.append(zn)
color_list.append(block_colors_map[el["block"]])
# Append fast text labels directly hovering above active coordinate nodes
tl = ax.text(xn, yn, zn + 0.12, el["symbol"], color='white',
fontsize=8, ha='center', va='bottom', alpha=0.85)
text_labels_pool.append(tl)
if x_nodes:
scatter_nodes._offsets3d = (x_nodes, y_nodes, z_nodes)
scatter_nodes.set_facecolors(color_list)
scatter_nodes.set_edgecolors('white')
else:
scatter_nodes._offsets3d = ([], [], [])
return north_path_line, south_path_line, inner_south_line, inner_north_line, scatter_nodes
ax.set_xlim(-5.5, 5.5)
ax.set_ylim(-5.5, 5.5)
ax.set_zlim(-3.0, 3.0)
ax.axis(‘off’)
ax.view_init(elev=25, azim=45)
ani = FuncAnimation(fig, render_frame, interval=20, blit=False, cache_frame_data=False)
plt.show()
