Hi All,
I tried to heat up the nickel surface by using Nose-Hoover thermostat, and then turn off the thermostat and run 3 more ps to ensure that the microcanonical ensemble has reached steady-state. What i have observed that the temperature is fluctuating from 2144 to 2576 K. My target temperature is 2400. I know that we cannot expect constant temperature and some fluctuation is OK, but i think that 400 K is too high. Below one is my code. I do not if there is any way to decrease the fluctuation. Can you please help me?
Rose
atom_style atomic
lattice fcc 3.52
region box block 0 5 0 5 0 5
create_box 1 box
create_atoms 1 box
pair_style eam
pair_coeff * * Ni_u3.eam
#Settings
neighbor 0.3 bin
neigh_modify delay 5
region region1 block 0.0 17.6 0.0 17.6 0.0 17.6 units box
# temp controllers
compute newtemp all temp
# equilibrate
velocity all create 2400.0 5812775 temp newtemp
fix 2 all nvt temp 2400.0 2400.0 0.1 tchain 3
fix_modify 2 temp newtemp
thermo 25
timestep 0.001
run 3000
#thermo_modify temp newtemp
thermo_style custom step temp ke pe etotal time vol
timestep 0.001
run 3000
