Dear Colleagues,
I am happy to announce the release of kim-api-v1.7.2 available immediately at:
This release includes various bug fixes and improvements.
The NEWS entry for this release is:
=== kim-api-v1.7.2 ======================================================
* Updated copyright years in files
* Rewrite of INSTALL file to provide a significantly improved description and
instructions for build and installation of the KIM API
* Fix error checking bug in ex_test_Ar_multiple_models Test
* Improve the build and install process to better follow standard conventions
for library soname values.
* Increased the maximum number of species supported by the example Tests to 200
* Fixed bug in example Tests related to maximum number of supported species
* Updated 'make clean' so that it removes all old library files in the source
directories
* Fixed default make target for Parameterized Models
* Fixed a bug in the installation process associated with the use of DESTDIR
* Fixed a regular expression error in the build system
* Fixed memory leak in internal KIM API code
* Added sanity check to make sure that the 'xxd' utility is available
* vc_forces_numer_deriv now outputs configuration energy
* Documentation updates
