Hello everyone,
I am trying to use the following potential:
EAM_Dynamo_ChamatiPapanicolaouMishin_2006_Fe__MO_960699513424_000 for one of my simulations.
I am new to openKIM but I believe that everything went smoothly in the installation.
The problem I am facing is that upon running LAMMPS I get the following error:
ERROR: KIM Model name not found (../kim_init.cpp:193)
My current version of kim-api is kim-api-2.2.1-gcc-4.8.5-lut4ypy .
I saw some discussions in this forum that sometimes the potentials have not been updated to the current OpenKIM version so I was wondering that is the issue or if is there anything I am doing wrong. The reason I am asking is that I tried a couple of random potentials and I am still getting the same error.
Thank you very much for your time
Alessandro
Hi Alessandro,
Can you please provide a little more detail on how you installed the kim-api, openkim-models, and lammps packages? That may provide the clues necessary to help you.
Ryan
Yes of course,
The kim-api library and openkim-models were installed by my system administrator using Spack so to be available on all of our computing nodes.
LAMMPS package was installed by using make yes-KIM followed by make mpi
Before running the simulation the modules are load by typing in the terminal:
module load kim-api-2.2.1-gcc-4.8.5-lut4ypy
module load openkim-models-2021-01-28-gcc-4.8.5-uvzowgs
Hi, Thanks that is helpful.
With the traditional build approach in LAMMPS, I think you also need to have a step like
make lib-kim args="-p /usr/local" # use an existing KIM API installation at the provided location
See: 3.7. Packages with extra build options — LAMMPS documentation
I think (but can’t remember for sure) that this would need to go before the make yes-KIM step.
Thanks Ryan,
Unfortunately, the error persists. Any other possible sources on why lamps fail to locate the potentials?
What version of LAMMPS are you using? In the latest version (I don’t remember exactly when this was added) you should see a listing of the directories where LAMMPS is looking for KIM models.
You should see a line like this:
#=== KIM is looking for 'Portable Models' in these directories ===
followed by a listing of directory path(s).
Can you check to see if this output is there, and if so, what directory is listed and is that the one where the spack openkim-models files are located?
Ryan
I am using LAMMPS (14 May 2021)
I don’t recall seeing that line (would it be located in the log.lammps file?)
However, the the model-drivers, portable-models and simulator-models folders are found here
/cm/shared/apps/spack/opt/spack/linux-centos7-haswell/gcc-4.8.5/openkim-models-2021-01-28-uvzowgsfdqtxrnrgmx5bitfzw5qveapd/lib/kim-api
Also, I don’t know if it helps but this is the kim.log file generated:
2022-01-06:18:04:47EST * 0 * information * 0x15e3670 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1685160 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1643960 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1685340 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1687340 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1687380 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1687220 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x16872a0 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 1 * information * 0x1687220 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '7_Collections'.
2022-01-06:18:04:47EST * 0 * information * 0x1687300 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1643a80 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x16458a0 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x16438e0 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x16459e0 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1643a00 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1643860 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 0 * information * 0x1643920 * KIM_LogImplementation.cpp:110 * Log object created. Default verbosity level is 'information'.
2022-01-06:18:04:47EST * 1 * information * 0x1643860 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '16_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x15e3670 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '0_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1685160 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '12_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643920 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '30_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643960 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '28_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1685340 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '14_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1685340 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '15_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687340 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '1_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687380 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '13_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687340 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '2_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16872a0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '6_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687220 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '3_Collections'.
2022-01-06:18:04:47EST * 2 * information * 7_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687220'.
2022-01-06:18:04:47EST * 1 * information * 0x1687300 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '11_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687380 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '4_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687220 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '9_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687220 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '10_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687300 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '8_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1687220 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '5_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643a80 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '25_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16458a0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '20_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16459e0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '31_Collections'.
2022-01-06:18:04:47EST * 2 * information * 10_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687220'.
2022-01-06:18:04:47EST * 1 * information * 0x16438e0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '26_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643a00 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '22_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643a80 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '27_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643a80 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '29_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16438e0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '21_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16458a0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '24_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643920 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '17_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x1643a00 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '18_Collections'.
2022-01-06:18:04:47EST * 2 * information * 15_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1685340'.
2022-01-06:18:04:47EST * 2 * information * 16_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643860'.
2022-01-06:18:04:47EST * 1 * information * 0x16438e0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '19_Collections'.
2022-01-06:18:04:47EST * 1 * information * 0x16438e0 * KIM_LogImplementation.cpp:242 * Log object renamed. ID changed to '23_Collections'.
2022-01-06:18:04:47EST * 2 * information * 12_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1685160'.
2022-01-06:18:04:47EST * 2 * information * 28_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643960'.
2022-01-06:18:04:47EST * 2 * information * 14_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1685340'.
2022-01-06:18:04:47EST * 2 * information * 0_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x15e3670'.
2022-01-06:18:04:47EST * 2 * information * 1_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687340'.
2022-01-06:18:04:47EST * 2 * information * 30_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643920'.
2022-01-06:18:04:47EST * 2 * information * 9_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687220'.
2022-01-06:18:04:47EST * 2 * information * 8_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687300'.
2022-01-06:18:04:47EST * 2 * information * 5_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687220'.
2022-01-06:18:04:47EST * 2 * information * 13_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687380'.
2022-01-06:18:04:47EST * 2 * information * 2_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687340'.
2022-01-06:18:04:47EST * 2 * information * 6_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16872a0'.
2022-01-06:18:04:47EST * 2 * information * 11_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687300'.
2022-01-06:18:04:47EST * 2 * information * 3_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687220'.
2022-01-06:18:04:47EST * 2 * information * 27_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643a80'.
2022-01-06:18:04:47EST * 2 * information * 29_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643a80'.
2022-01-06:18:04:47EST * 2 * information * 20_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16458a0'.
2022-01-06:18:04:47EST * 2 * information * 4_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1687380'.
2022-01-06:18:04:47EST * 2 * information * 31_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16459e0'.
2022-01-06:18:04:47EST * 2 * information * 22_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643a00'.
2022-01-06:18:04:47EST * 3 * error * 12_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 2 * information * 25_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643a80'.
2022-01-06:18:04:47EST * 2 * information * 23_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16438e0'.
2022-01-06:18:04:47EST * 2 * information * 26_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16438e0'.
2022-01-06:18:04:47EST * 2 * information * 24_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16458a0'.
2022-01-06:18:04:47EST * 2 * information * 18_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643a00'.
2022-01-06:18:04:47EST * 3 * error * 3_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 29_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 2 * information * 21_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16438e0'.
2022-01-06:18:04:47EST * 3 * error * 28_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 2 * information * 17_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x1643920'.
2022-01-06:18:04:47EST * 3 * error * 10_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 30_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 2 * information * 19_Collections * KIM_LogImplementation.cpp:246 * Log object renamed. ID changed from '0x16438e0'.
2022-01-06:18:04:47EST * 3 * error * 16_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 0_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 15_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 1_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 13_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 7_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 2_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 11_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 9_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 14_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 20_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 8_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 5_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 22_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 25_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 26_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 6_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 24_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 21_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 19_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 27_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 31_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 23_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 4_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 18_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
2022-01-06:18:04:47EST * 3 * error * 17_Collections * KIM_CollectionsImplementation.cpp:730 * Unable to find item.
OK, that feature was added in September 2021. Since you are building from source, is it possible for you to use the 14-December-2021 patch release? Then you should see the lines I mentioned in the log and/or the screen output.
