I intend to use the the following potential for my simulation:
MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_002 metal
However, I have this error message;
ERROR: KIM Model name not found (src/KIM/kim_init.cpp:234)
Last command: kim init MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_002 metal
This my first time using OpenKIM and I test it on one of the KIM examples (in.melt.kim)and it worked smoothly.
Currently, I am running the lasted editions on both lammps (2Aug2023) and OpenKIM (2.3.0-1)
Can you please let me know what I am doing wrong?
Thank you so much!
You most likely need to install the model first. Hopefully you used a method other than Conda to install the KIM API (currently the Conda installation does not support installing models that are not in the openkim-models package).
Try the following shell command:
kim-api-collections-management install user MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_002
The model you are trying to use is not in the openkim-models package, that’s why you have to install it separately using the kim-api-collections-management utility.
Were you able to run the command I gave you? If it succeeds, your LAMMPS script should work.
Hello Ilia,
when I ran your command, I got this error message:
CMake Error at CMakeLists.txt:7 (project): The CMAKE_CXX_COMPILER: /usr/bin/c++ is not a full path to an existing compiler tool.
Then I searched about this CMAKE_CXX_COMPILER error, and I found that I need to run the following command: CC=gcc-X CXX=g+±X FC=gfortran-X cmake … -DCMAKE_BUILD_TYPE=Release
However, I got another error message:
CMake Error at /usr/share/cmake-3.27/Modules/CMakeDetermineCXXCompiler.cmake:48 (message):
Could not find compiler set in environment variable CXX: g+±X.
I tried some solutions such as; sudo apt install gcc g++, but still the last message remains.
I guess there are some problems with my cmake.
Please let me know what you think of this!
Thank you so much!
or some other method (such as building from source or Conda)?
I should also take a step back to point out that, if you already have the ‘openkim-models’ package installed, you should be able to use version 000 of the potential. It is included in ‘openkim-models’
MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_000
The only functional difference between 000 and 002 is a bugfix that only affects some MEAM models, and the bug only occurs when multiple “kim init” commands are issued in a single script. This happens when using the ASE interface to LAMMPS, or in some specialized situations, but in general use it should not be an issue.
Dear Ilia,
Sorry for the late reply!
Thank you so much for your support!
The problem has been solved and the (MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_002) works now.
However, when I continue running the rest of the script I received this error;
terminate called after throwing an instance of ‘std::logic_error’
what(): basic_string: construction from null is not valid
Btw, I had the same error when I ran the (MEAM_LAMMPS_LeeLeeKim_2006_FeN__MO_432861766738_000) model.
I have already test my script on Windows system (without the openkim model) and it was working fine.
Do you have any ideas regarding how to solve this issue?
Thank you for your help!
You say that your test script without OpenKIM is working on Windows. Is this the same machine you are running the OpenKIM version of the script on? If not, can you try without OpenKIM on your current machine?
If indeed your script on the same machine works without OpenKIM, but not with OpenKIM, can you attach the entire log.lammps file of the run that results in the error?
