I am trying to simulate an organic liquid with 10k atoms based on OPLS-AA using LAMMPS on a NVIDIA Tesla V100 GPU node with 24 CPUs.
First I used LAMMPS without GPU and KOKKOS packages and with 12 OMP threads and I had 10 ns/day performance.
Then I compiled LAMMPS with GPU package using the following command
cmake ../cmake -DPKG_GPU=yes -DGPU_API=cuda \
-DGPU_PREC=mixed -DGPU_ARCH=sm_70 \
-D BUILD_MPI=yes -D BUILD_OMP=yes -D PKG_MOLECULE=ON \
-D PKG_COMPRESS=ON -D PKG_KSPACE=ON
and I had a performance of 30 ns/day for 6 MPI tasks and 4 OMP threads.
Since GPU package does not support all styles, I then try to compile LAMMPS with KOKKOS package using the following command
cmake -C ../cmake/presets/kokkos-cuda.cmake \
-C ../cmake/presets/basic.cmake \
-D BUILD_MPI=yes -D PKG_OPENMP=yes \
-D Kokkos_ARCH_PASCAL60=no -D Kokkos_ARCH_VOLTA70=yes \
-D Kokkos_ENABLE_OPENMP=yes -D PKG_MOLECULE=ON \
and after running using the command
export OMP_PROC_BIND=spread
export OMP_PLACES=threads
export OMP_NUM_THREADS=12
export MPI_NUM=2
mpirun -np $MPI_NUM /home/ji39tip/lammps-kokkos/build/lmp \
-in run.in -k on g 2 -sf kk
I had the follwoing error
[node128:439598] *** End of error message ***
Kokkos::Cuda::initialize ERROR: likely mismatch of architecture
I have no experience with GPU computations and I am very confused with this error since the same architecture I used to configure the GPU package sm_70 did not lead to this error, while setting VOLTA70 for KOKKOS leads to the error.
A difference between the compilation with GPU and KOKKOS packages is an error related to this line in CMakeLists.txt
# silence nvcc warnings
if((PKG_KOKKOS) AND (Kokkos_ENABLE_CUDA) \
AND NOT (CMAKE_CXX_COMPILER_ID STREQUAL "Clang"))
set(CMAKE_TUNE_DEFAULT "${CMAKE_TUNE_DEFAULT}" "-Xcudafe
--diag_suppress=unrecognized_pragma,--diag_suppress=128")
endif()
This gives an error saying -Xcudafe is not known. Since it seems to only "silence nvcc warnings ", I have omitted this line from CMakeLists.txt to compile.
I am thankful very any hints.
