using “-D PKG_KOKKOS=yes” (which is where my new styles need to be unit tested) adds “-Xcudafe;–diag_suppress=unrecognized_pragma” but also using “-D ENABLE_TESTING=on” switches compiler from nvc++ to g++ so i get “unrecognized command-line option ‘-Xcudafe’” and “unrecognized command-line option ‘–diag_suppress=unrecognized_pragma’” errors
mkdir tmp; cd tmp
git clone GitHub - lammps/lammps: Public development project of the LAMMPS MD software package
mkdir lammps/build; cd lammps/build
cmake …/cmake -D ENABLE_TESTING=on
-D PKG_KOKKOS=yes -D Kokkos_ENABLE_CUDA=yes
-D Kokkos_ARCH_HOSTARCH=POWER9 -D Kokkos_ARCH_GPUARCH=VOLTA70
-D Kokkos_ENABLE_OPENMP=yes -D BUILD_OMP=yes
-D Kokkos_ENABLE_SERIAL=yes -DKokkos_ARCH_VOLTA70=ON
-D PKG_MOLECULE=yes -D PKG_KSPACE=yes ;
cmake --build .
[ 72%] Building CXX object CMakeFiles/lammps.dir/home/t/tperkins/mmurp027/scratch/tmp/lammps/src/KOKKOS/region_block_kokkos.cpp.o
[ 72%] Linking CXX static library liblammps.a
[ 72%] Built target lammps
[ 73%] Building CXX object CMakeFiles/lmp.dir/home/t/tperkins/mmurp027/scratch/tmp/lammps/src/main.cpp.o
[ 73%] Linking CXX executable lmp
[ 73%] Built target lmp
[ 73%] Built target gtest
[ 73%] Building CXX object _deps/googletest-build/googlemock/CMakeFiles/gmock.dir/src/gmock-all.cc.o
[ 73%] Linking CXX static library ../../../lib/libgmock.a
[ 73%] Built target gmock
[ 73%] Building CXX object _deps/googletest-build/googlemock/CMakeFiles/gmock_main.dir/src/gmock_main.cc.o
[ 73%] Linking CXX static library ../../../lib/libgmock_main.a
[ 73%] Built target gmock_main
[ 74%] Building CXX object _deps/googletest-build/googletest/CMakeFiles/gtest_main.dir/src/gtest_main.cc.o
[ 74%] Linking CXX static library ../../../lib/libgtest_main.a
[ 74%] Built target gtest_main
[ 74%] Building CXX object unittest/utils/CMakeFiles/test_tokenizer.dir/test_tokenizer.cpp.o
g++: error: unrecognized command-line option ‘-Xcudafe’
g++: error: unrecognized command-line option ‘--diag_suppress=unrecognized_pragma’
gmake[2]: *** [unittest/utils/CMakeFiles/test_tokenizer.dir/build.make:76: unittest/utils/CMakeFiles/test_tokenizer.dir/test_tokenizer.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:3025: unittest/utils/CMakeFiles/test_tokenizer.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
i dont see a ctest executable in build dir yet. how are kokkos pair and dihedral styles unit tested with gpu on ? am i doing something wrong with cmake ??
