LAMMPS 27 Aug + USER-CUDA make errors
I’m trying to build the latest LAMMPS 27 Aug code with USER-CUDA package and experience some errors during the build. I generally solved them for my machine but don’t know how universal this solution is. My config is Suse Linux Enterprise 11 SP1 + Intel Compilers + MPICH2 + Tesla M2050.
So, I built the library liblammpscuda.a with default settings in lammps/lib/cuda, set “make yes-USER-CUDA”, modified lammps/src/MAKE/Makefile.linux with paths to MPICH2 and launch “make linux”.
Typical errors during the make process are undefined identifiers and references like
cuda.cpp(74): error: identifier “CUDA_ARCH” is undefined
if(shared_data.compile_settings.arch!=CUDA_ARCH) printf("\n\n # CUDA WARNING: Compile Settings of cuda and cpp code differ! \n # CUDA WARNING: arch: cuda %i cpp %i\n\n",shared_data.compile_settings.cufft, CUDA_ARCH);
…/…/lib/cuda/liblammpscuda.a(atom_vec_cuda_cu.o): In function global constructors keyed to _Z26AtomVecCuda _CountDataItemsj': tmpxft_00000ca0_00000000-1_atom_vec_cuda.cudafe1.cpp:(.text+0xfe): undefined reference to cudaCreateChannelD
esc’
Researching the cause, I found the misprint in the file ./lib/cuda/Makefile.lammps. Instead of “CUDA_INSATLL_PATH = /usr/local/cuda” there should be “CUDA_INSTALL_PATH = /usr/local/cuda”. That misprint causes a lot of make errors.
Next, as stated here (http://lammps.sandia.gov/threads/msg22446.html) lammps/lib/cuda/Makefile.common should be included in lammps/src/Makefile.package but actually it is not, so I added to lammps/src/Makefile.package the lines
include /opt/lammps-27Aug11/lib/cuda/Makefile.lammps
include /opt/lammps-27Aug11/lib/cuda/Makefile.common
After that I was able to build LAMMPS with USER-CUDA.
Next possible error (it disappeared when I fixed the other ones so I’m not sure that it is the error) is that in ./src/USER-CUDA/fft3d_cuda.h line 92 you should add the else condition
#else
typedef struct {
float re;
float im;
} FFT_DATA;
#endif
Otherwise, there will be errors like “identifier “FFT_DATA” is undefined” in the case you don’t use Cuda FFT realization (-DFFT_CUFFT).
Don’t forget to reinstall the USER-CUDA package after changing the source:
make no-USER-CUDA
make yes-USER-CUDA
Hope this will help to someone to build LAMMPS with USER-CUDA package.
Nikita Tropin | Scientist
Comments below. I think Christian needs to chime in on some of this.
I'm trying to build the latest LAMMPS 27 Aug code with USER-CUDA package and
machine but don't know how universal this solution is. My config is Suse
lammps/lib/cuda, set "make yes-USER-CUDA", modified
lammps/src/MAKE/Makefile.linux with paths to MPICH2 and launch "make linux".
references like
cuda.cpp(74): error: identifier "CUDA_ARCH" is undefined
../../lib/cuda/liblammpscuda.a(atom_vec_cuda_cu.o): In function `global
_CountDataItemsj':
reference to `cudaCreateChannelD
esc'
./lib/cuda/Makefile.lammps. Instead of "CUDA_INSATLL_PATH = /usr/local/cuda"
there should be "CUDA_INSTALL_PATH = /usr/local/cuda". That misprint causes
I fixed this typo. It will be part of a patch later today.
Next, as stated here (LAMMPS Molecular Dynamics Simulator)
Makefile.common should not be necessary. Only what is in
lib/cuda/Makefile.lammps. If there is something missing
in the latter file, then we need to add it. Christian?
Next possible error (it disappeared when I fixed the other ones so I'm not
#else
typedef
struct {
float re;
float im;
FFT_DATA;
#endif
Otherwise, there will be errors like "identifier "FFT_DATA" is undefined" in
the case you don't use Cuda FFT realization (-DFFT_CUFFT).
I'll let Chrisitian comment on the FFT issues ...
steve,
#else
typedef
struct {
float re;
float im;
FFT_DATA;
#endif
this is likely due to our recent FFT changes since FFT_NONE
now implies FFT_KISSFFT and thus there will always be an
FFT library compiled in.
i can have a look at it as well (since i am mostly responsible for this),
if desired. i just can't do it right away due to working on getting the
OpenMP stuff pushed through.
cheers,
If I don't include lammps/lib/cuda/Makefile.common in lammps/src/Makefile.package I have the error during make
So, lammps/lib/cuda/Makefile.common provides at least the following needed options:
-DUNIX -DCUDA_PRECISION=1 -DCUDA_ARCH=20
Hi
I didnt check the latest version out yet, but I will test the changes that were made to the Make system and try to fix them.
Christian
-------- Original-Nachricht --------
