Dear Sir/Madam,
I have followed below mentioned steps to compile lammps-9Dec14 with USER-MISC package.
src]$ make yes-user-misc
Installing package user-misc
then done: make mpi
I have pasted make package-status output here for your reference:
Dear Sir/Madam,
then done: make mpi
Dear Sir/Madam,
USER-MISC package.src]$ make yes-user-misc
Installing package user-miscthen done: make mpi
make package-status 2>&1 | tee LOG-make-package-status-On18Mar2015-1
Installed NO: package ASPHERE
Installed NO: package BODY
Installed NO: package CLASS2
Installed NO: package COLLOID
Installed NO: package DIPOLE
Installed NO: package FLD
Installed NO: package GPU
Installed NO: package GRANULAR
Installed NO: package KIM
Installed NO: package KOKKOS
Installed YES: package KSPACE
Installed YES: package MANYBODY
Installed NO: package MC
Installed NO: package MEAM
Installed NO: package MISC
Installed YES: package MOLECULE
Installed NO: package MPIIO
Installed NO: package OPT
Installed NO: package PERI
Installed NO: package POEMS
Installed NO: package QEQ
Installed NO: package REAX
Installed NO: package REPLICA
Installed NO: package RIGID
Installed NO: package SHOCK
Installed NO: package SNAP
Installed NO: package SRD
Installed NO: package VORONOI
Installed NO: package XTC
Installed NO: package USER-ATC
Installed NO: package USER-AWPMD
Installed NO: package USER-CG-CMM
Installed NO: package USER-COLVARS
Installed NO: package USER-CUDA
Installed NO: package USER-EFF
Installed NO: package USER-FEP
Installed NO: package USER-INTEL
Installed NO: package USER-LB
Installed YES: package USER-MISC
src/fix_srp.cpp and USER-MISC/fix_srp.cpp are different
Installed NO: package USER-MOLFILE
Installed NO: package USER-OMP
Installed NO: package USER-PHONON
Installed NO: package USER-QMMM
Installed NO: package USER-REAXC
Installed NO: package USER-SPH
As diff is :
166c166
< // int *tag = atom->tag;
---//int *tag = atom->tag;
The executable is lam_mpi
While I am executing below mentioned command :
time mpirun -np 4 lammps-9Dec14/src/lmp_mpi < graphene.tip4p.LAMMPS.in
Getting below mentioned error:
# ------------- Equilibration ----------------
fix pistonkeep bothpistons setforce 0.0 0.0 NULL
fix piston1thrust piston1 aveforce NULL NULL 0.01 # squeezing the water
between two pistons at about 150 MPa each
fix piston2thrust piston2 aveforce NULL NULL -0.01
fix 1 water shake 1.0e-4 100 0 b \{waterbond\} a {waterangle}
fix 1 water shake 1.0e-4 100 0 b 1 a ${waterangle}
fix 1 water shake 1.0e-4 100 0 b 1 a 1
ERROR: Invalid fix style (../modify.cpp:762)Supporting files are : geometry.dat, CH.airebo_real
Kindly suggest me the solution for this issue.
I will be greatly obliged for solution.
as you can see, your input stops at the fix shake line. now you should
read the documentation for fix shake carefully and the solution should
be obvious and you'll be embarrassed to have even asked for something
this obvious.
(don't, but keep checking the documentation
carefully before asking in the future).
axel..
...and check this chapter of the manual, too.
http://lammps.sandia.gov/doc/Section_errors.html
Reading the doc page for fix shake (as Axel suggests) will
tell you that command is the RIGID package, which you
did not build with.
