Dear Lammps developers and users,
I am getting significantly better energy conservation in Lammps compared to Gromacs for SPC/E water under an NVE ensemble with a simple cut-off. I enquired on the Gromacs mailing list, and in turn it was asked whether there is something going on behind the scenes in Lammps which is helping to achieve this?
The total energy drift is about 20 kJ/mol/ns/molecule in Lammps, while it is catastrophically exponential in Gromacs (raising 20 kJ/mol/ns/molecule after the initial 50ps). I have done my best to match the conditions of simulation for both software.
Both software:
Update neighbour list at every step
Apply COM velocity correction every 10 steps
Same temperature
Same LJ combining rule
Same cut-off
Same time-step
Same shake tolerance (also tested LINCS in Gromacs)
Same equilibration time (500ps)
Same atomic starting positions
Same energies (total, PE, KE) after equilibration (easily within 1 standard deviation of fluctuations measured during the final 100ps of equilibration)
I realise even 20 kJ/mol/ns/molecule is poor but it’s enough for my current short calculations, and so if anyone could provide any insight as to why Lammps should be so much more stable I would very much appreciate learning more. I’d like to rule out any possibility that I’m inadvertently doing something in the Lammps input file which helps energy conservation, or that Lammps automatically tries to help somehow.
I include all details regarding input files for Lammps (and Gromacs, for your reference) below. If you need any further information, I would be happy to provide it.
Thank you.
With best regards,
James
The Lammps input file is as follows:
Lammps input
units real
atom_style full
read_data lammps.data # Same position configuration as Gromacs
pair_style lj/cut/coul/cut 12
pair_coeff 1 1 0.1554 3.166 # kcal/mol = 0.65 kJ/mol
pair_coeff * 2 0.0000 0.0000
bond_style harmonic
angle_style harmonic
bond_coeff 1 1000.00 1.0
angle_coeff 1 100.0 109.47
neighbor 0.0 bin
neigh_modify every 1
timestep 0.002
fix 1 all shake 0.000001 20 0 b 1 a 1
fix NVT all nvt temp 300.0 300.0 0.5
velocity all create 300 432567 dist uniform
fix linmom all momentum 10 linear 1 1 1
thermo_style custom step temp etotal ke pe
variable mystep equal step*0.002
variable myetotal equal etotal
variable mype equal pe
variable myke equal ke
variable myevdwl equal evdwl
variable myecoul equal ecoul
variable mytemp equal temp
fix printenergy all print 100 “{mystep} {myetotal} {mype} {myke} {myevdwl} {myecoul}” file sim.energy.equil
fix printtemp all print 100 “{mystep} {mytemp}” file sim.temp.equil
NVT equilibration
run 250000
NVE production
unfix NVT
fix NVE all nve
reset_timestep 0
fix printenergy all print 100 “{mystep} {myetotal} {mype} {myke} {myevdwl} {myecoul}” file sim.energy.prod
fix printtemp all print 100 “{mystep} {mytemp}” file sim.temp.prod
run 250000
